Question about Panasonic Televison & Video
Panasonic make LCD TH-32C30D TV having fault. Screen doesn't glow, since Power supply board is working, How should repair it ?
    Top Expert:
  • Panasonic Master
  • 74,999 Answers
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Posted on Dec 13, 2016
PANASONIC LCD TH-L32C10 Repair Black Screen and Blinking Power Black Screen and Blinking Light
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Aug 02, 2016 | Panasonic TH-L32C10 32 inch Multi System...
The on/off switch doesn't work on our 37inch Panasonic plasma tv
There should be some fault with its main power supply regulator board. Check it. If you are not familiar with electronics, do not attempt to repair. Whether you suffer fatal electrical shock! Instead, contact the nearest service center.
Feb 05, 2013 | Panasonic Viera TH-42PX80U Plasma TV
Panasonic Viera TH-50PZ80U no back light
There is no backlight CCFL lamps to Plasma displays, like LCD ones. If there is no screen with plasmas, the Z-Sustain board should be checked and replaced. This is actually a skilled work, and not a user repairable one, if the user is not experienced to work with plasma displays. Check this link and see whether you can do it by yourself. The link have enough details about the faults to Panasonic brand TVs.
Jan 17, 2013 | Panasonic Viera TH-50PZ80U Plasma TV
A Toshiba Flat Screen (52"
U tries check the power source and unplug,replug the tv back like about an hour later.For the tv to do a resetting itself back to the factory setting.No,fans in LCD or Plasma flat tvs.If this tv a LCD flat screen tv than the tv have power supply board problems,this tv doesn't have fan design into it.After it goes off the tv power LED light indication on the tv bazel frame are blinking?Yes that the tv have a power supply board can't sustance power voltages to the tv anymore.The tv power supply board that the board where the power a/c cord plug into it.Tries websites like, to buy a whole new refurbish power supply board for the replacement.Or have the tv service by a athorized LCD tvs and Plasma tvs shops.
Aug 17, 2011 | Toshiba 52HL167 52 in. LCD HDTV
Panasonic viera Plasma TV model TH-P42X10A The tv
The power supply board of the television is dead, u know basic electronics' and soldering? Most of the times, the power supply board just have dead leakages gases capacitors.These capacitors always bulges up on it top,or puff up on it top.Replaced these gases leakages capacitors will get your TV power stable,and work again.Or tries websites like, to buy a whole refurbish power supply board for the replacement.
I hope this will help in solving the problem....
Aug 01, 2011 | Panasonic Televison & Video
Received a panasonic th-42pz80u from my father in law. He said it did not work. I plugged it up and it worked for a few hours. Now I get nothing when I plug it up. Is there anything I can do to restore...
Try using a different outlet, if that doesn't work see if you have another power cable that is the same power as the one on the T.V. and try that. If that doesn't work then there is probably a problem on the board near where the power plugs in. It could be fixed by a firmware update or it may need to actually be repaired.
May 04, 2011 | Panasonic Viera TH-42PZ80U Plasma TV
I have a panasonic TH-42PZ80U plasma tv. The indicator like is blinking 10 times. I have tried powering the unit down and and resetting it by holding the power button in for 10 seconds. I have heard...
Blinking 10 times or what ever the blinks is,if is on the LED power light indication?Yes,this problems is not the tv Tuner signal board problems.It is the tv power supply board is the problems.Repairing this problems for a friend this by replacing the power supply board before it work.It also a Panasonic Virera Plasma tv too.Try website like to buy a whole refurbish power supply board for the replacement.
Jan 09, 2011 | Panasonic Viera TH-42PZ80U Plasma TV
Plasma 50 inches dont turn on
The power supply board is dead.Tries the websites like, to buy the refurbish power supply board for the replacement.
Jun 22, 2010 | Panasonic Viera TH-50PX80U Plasma TV
Panasonic 42" Plasma Television 2008 (4-blinks)
I have seen a fault where the Plasma display was giving sparkling green dots, and then the set would shut down after about 10 minutes. After waiting for about 40 minutes, I would re-start and the process would work the same, and then the set would shut down.
I tried freezing the boards one by one with freeze-spray, and heating with a heat gun to see where the thermo fault could be. I had no success.
Fortunately I had access to a scrapper set of the exact same model. After spending many hours with the process if elimination, I worked the fault down to be the screen itself! Unfortunately, with the scrapper set that I had its screen was very weak. Swapping the screens between the two sets proved that the original screen has failed.
I don't want to discourage you. You may be down to the point of what I reached!
Jerry G.
Feb 10, 2009 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Televison & Video Logo
Top Panasonic Televison & Video Experts
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
