Question about Panasonic Heating & Cooling
How do I turn on my air con Panasonic CS-w18DKR
I can't work out why the remote control won't turn on the air con, the batteries are working
bobotfel
  • 236 Answers
SOURCE: I have a Fujitsu Split
Try to disconnect the supply from circuit breaker for 10sec. and "on" again, if it doesn't work you need at qualified technician for that problem.
Posted on Apr 16, 2008
bobotfel
  • 236 Answers
SOURCE: AIR CON REMOTE CONTROL NOT WORKING
replace your receiver board it may be defective.
Posted on May 16, 2008
tbirdfan1
  • 3051 Answers
SOURCE: remote doesn't work on air con
Should be current detect pcb faulty, or compressor drawing too much current.
I don't have your model a/c, but panasonic fault codes stay pretty much the same
Normally panasonics have this info on the inside of the access panel.
Plus fault codes from the indoor unit make it easier to look up.
if the compressor is running, check the amps and refrig pressures.
Posted on Sep 19, 2009
Therinnaiguy
  • 1420 Answers
SOURCE: Getting the batteries out of the remote unit for a
Try sliding the remote cover all the way off
Posted on Nov 20, 2009
Therinnaiguy
  • 1420 Answers
SOURCE: How do I change the battery in the remote control
slide the cover of the remote up higher. It is hiding the batteries.
Posted on Nov 26, 2009
My Panasonic split air conditioner has stopped cooling - model:CU-W18DKR. The internal unit and internal fan operate normally. The external unit fan does not run like normal and no compressor sounds f
Sounds like a faulty outdoor controller board. If you are in Australia, call Prime Electronics or Statewide Appliances for spares.
Part number: NPCWA743383
• To make a diagnosis
1. Timer LED start to blink and the unit automatically stops the operation.
2. Press the CHECK button on the remote controller continuously for 5 seconds.
3. "- -" will be displayed on the remote controller display.
Note: Display only for "- -". (No transmitting signal, no
receiving sound and no Power LED blinking.)
4. Press the "TIMER" or button on the remote controller. The code "H00" (no abnormality) will be displayed and signal will be transmitted to the main unit.
5. Every press of the button (up or down) will increase abnormality numbers and transmit abnormality code signal to the main unit.
6. When the latest abnormality code on the main unit and code transmitted from the remote controller are matched, power LED will light up for 30 seconds and a beep sound (continuously for 4 seconds) will be heard. If no codes are matched, power LED will light up for 0.5 seconds and no sound will be heard.
7. The breakdown diagnosis mode will be canceled by pressing the CHECK button continuously for 5 seconds or without any operation the remote control for 30 seconds.
8. The LED will be off if the unit is turned off or the RESET button on the main unit is pressed.
Or better yet, get a tech to check first.
Feb 10, 2015 | Panasonic Single Split System - Wall...
Airconditioner blowing not cold
Yes. its the run capacitor that is bad. as far as the filter, evaporator and condenser coil is clean and compressor is okay as you said. get the exact type and model of the capacitor and replace... let me know... all the best.
Jan 30, 2014 | Panasonic Heating & Cooling
Panasonic CS-A12DKD Air conditioner does not
This could be an inoperative reversing valve or bad reversing valve solenoid coil.
Oct 31, 2013 | Panasonic Heating & Cooling
I have an old Kelvinator air conditioning. Not sure what the model is since I have lost the manual, but from the remote control I can see some code looking like the model number: 6711A20012M. A few weeks...
You're right! It's receiving sensor problem with your PCB. Only repairman who knows electronic tech could only repair. I could say the cost of repair in Indian Rupees IRS.850/- maximum. Hope it's helpful?
Dec 25, 2010 | Heating & Cooling
My panasonic airconditioner c9kkzw timer is always blinking and automatically turned off every hour. its driving me crazy becasue my kids won't asleep.. please please help me, tried turn and off but to no...
I think, you have set the timer for one hour. No problem, remove battery from remote and reset it and same way isolate the power to your air conditioner for 5 seconds and reset it. Now all pre programmed would have been canceled. Now you can set your temp as you like.
And another reason may be your compressor getting heated after an hour, due to dust blocked in your out door coil. Hence, please serive the unit at once. Thanks.
Dec 15, 2010 | Panasonic CS-A12C Air Conditioner
I have a Panasonic CS/CU-W18DKR - on cooling it works fine, auto aswell as fan, but on heating when it is on manual fan control it used to blow all the time, but not for some reason it only blows...
When the unit heats inside, the outdoor unit cools, and if the outdoor cooling coil gets too cold the system turns off indoor fan, and changes gas flow direction to de-ice the outdoor coil. Ensure both coils, and the filters are clean and if there is still a problem check system gas pressure for leaks.
Apr 18, 2010 | Heating & Cooling
May 12, 2008 | LG Art Cool LA121CNP wall/window Air...
Heating & Cooling Logo
26 people viewed this question
Top Panasonic Heating & Cooling Experts
Bill Long
Fotis Papastamatiou
Dennis Boxerman
Are you a Panasonic Heating and Cooling Expert? Answer questions, earn points and help others
