Question about Singer Sewing Machines
My singer confidence bobbin winder turns couple rotations then lcd screen goes blank and winder quits - how do I fix this problem?
    Legend:
    An expert who has written 200 answers of more than 400 characters.
  • Singer Expert
  • 631 Answers
I don't know, but I can suggest a workaround to you. I'm not in live with their bobbin winding system anyway, but that's personal. You can purchase a bobbin winder; you can get one for about $25 from WalMart, and if you order it online and pick it up at a store, delivery is free. It does a much better job anyway.
Posted on Dec 28, 2016
  • 3 Answers
SOURCE: Bobbin stuck on bobbin winder, how do I get it off? it will not budge!
Is thread under bobbin? can you turn it? can you pull the thread off the bobbin and then remove it? Bobbin that comes with machine may not be right one. Right one has a light blue tint and a slightly domed top.
Posted on Jul 08, 2007
textile
  • 10 Answers
SOURCE: Problem with winding thread onto
first you must make sure the winder shaft is turning by moving it to the right a little and see if you can turn it by hand.
If it is turning ok then there is a rubber ring on the other end of the winder shaft and it should come in contact with the drive which turnes it ,if it is worn it might need a new rubber.
Posted on Aug 19, 2008
  • 980 Answers
SOURCE: I have a singer 503A. The bobbin winder will not
When you have the winder rubber on try and turn the winder by hand, if it does not move the chances are the winder has seized, if the winder wheel is moving but not the spindle then the grip (thread) has worn, if you cannot move the whole winder by hand and it has seized you need to get some WD40 and spray a few drops down the spindle, take an electric drill and put it over the top of the spindle and switch it on slowly and it will probably free it off, be aware of oil splashing out.
you mighjt get a digram from www.tandtrepair.com
Posted on Feb 24, 2010
  • 1116 Answers
SOURCE: How do I use the automatic bobbin winder on Singer
Here is a guide for bobbin winding and threading the 457 - http://www.sewusa.com/Threading_Diagrams/Threading_Pages/Singer_Sewing_Machine_Threading/singer_457_stylist_threading_diagram.htm
Posted on Feb 25, 2010
  • 539 Answers
SOURCE: My bobbin won't catch on the bobbin winder, the metal post spins but the plastic singer style bobbin won't spin with it. What's wrong?
You can turn the screw on the top of bobbin winder tad to right. Also, you may want to try a metal Universal bobbin, but try first option I gave first. Jimmy
Posted on Apr 02, 2012
My Singer Slant-o-Matic 500a sewing machine will not wind a bobbin. The winding pin barely started to turn, then no motion. Also, the wheel doesn't seem to tighten.
Your machine is an older mechanical machine, so have you cleaned and oiled it recently? Usually, older machines' oil will gunk up over time and stop things from moving like they should. Use only Fresh, good quality sewing machine oil. Do NOT oil belts, cams, rubber, or plastic parts. Slowly rotate the handwheel and place a couple drops of oil every place where metal rubs metal. To speed up the process, direct hot air from a handheld hairdryer into the internal metal parts.
singer 500a bobbin winding
How to Inspect Rubber Bobbin Winder Wheel Singer 500 503 Sewing Machine
BrianSews Singer Slant Matic 500a the Rocketeer
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=5&ved=0ahUKEwjqkcWf7KrMAhVB4GMKHVwoA-MQFggvMAQ&url=http%3A%2F%2Fwww.singerco.com%2Fuploads%2Fdownload%2F1308_500.pdf&usg=AFQjCNFEBkPQttXzueRCWGluOe-YBmF5Wg&cad=rja
Apr 23, 2016 | Singer Sewing Machines
Why does my Singer 3820 bobbin winder not disengage the sewing foot now?
sounds like the clutch is stuck I would take it into a repair shop
Aug 05, 2014 | Singer 3820 Mechanical Sewing Machine
I cannot thread the bobbing....threads for a few seconds stops and locks up with a buzzing sound.
Is it the correct bobbin? Is it sitting snugly on bobbin winder? Does the winder spin freely when it is empty?
Nov 03, 2013 | Singer Confidence 7463 Computerized Sewing...
Singer curvy
Three possible causes: 1.Bobbin not push fully down the bobbin winder spindle
2.Need to push bobbin winder spindle to the left before you can wind the bobbin
3.The bobbin winder spindle rubber ring has worn out. This will need a local technician to fix it.
Aug 16, 2013 | Sewing Machines
My singer quantum 9940 bobbin will not fill even. What seems to be the problem?
There's a small screw on top of bobbin winder on your machine. Turn screw to adjust pressure where bobbin meets the winder when winder is pushed to right to wind it. Test with small turns until you are satisfied with appearance. Make sure nice, even fill- as you know, imbalanced bobbin will reak havoc. Jimmy
Apr 09, 2012 | Singer Sewing Machines
The bobbin may be stripped, or the bobbin winder might be stripped; try it with a different bobbin, to rule out the bobbin being the issue; if that doesn't work, look closely at the bobbin winder to see if it has been damaged. You may be able to adjust it's shape with a pliers
Apr 02, 2012 | Singer 3116 Simple
I have a singer inspiration 4228. When I tried to
If you have pushed the winder over and it is not turning either the winder rubber has worn down one side, or there is residue on the winder rubber, or the bwinder has seized through lack of oil which is quite common, with the winder in the off position see if you can spin it by hand, if you can't then chances are it has seized, put some WD40 oil on the top of the spindle and leave it overnight, then put an electric drill over the top of the spindle and switch on slowly, that usually works.
Mar 05, 2010 | Kenmore 11101 Mechanical Sewing Machine
Feb 24, 2010 | Singer Sewing Machines
Bobbin rewind problems
Either the winder rubber is worn down one side, or the spindle has seized, take the top off and check and see if you can turn the winder by hand, if not then it has seized and the only way to free it is to put a couple of drops of WD40 on the spindle, put an electric drill on the end of the spindle and start the drill very slowly.
Feb 07, 2010 | Singer 8280 Mechanical Sewing Machine
Problem with winding thread onto the bobbin (small free- arm Singer 100 sewing machine). Once bobbin winder shaft is pushed to the right nothing happens-bobbin rod does not start turning so I cannot wind...
Aug 18, 2008 | Singer Featherweight 140Q
Sewing Machines Logo
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
