Question about Photography
My picture is frozen ,I can't continue watching my film or turn it off please fix it!
  • kakima Dec 13, 2016
    Hi Wendy Kagi, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    What make and model camera?
  • Wendy Kagi
    Wendy Kagi Dec 13, 2016
    I have an Apple Ipad which has been efficient until just now in connecting my device up with Netflix but suddenly the picture has frozen!
I took a self portrait with my fuji instax mini 7s but when the film came out, it was just white. I waited a few more minutes but it still didn't have the picture i took. What's wrong?
It comes out white cause you just took the picture. It takes a few moments to "develop" the picture that will be on the card. If you don't see nothing maybe the lens was covered...but it most likely be black as in something was on the card and developed.
how to load film here:
http://www.youtube.com/watch?v=Vq8JguPxq3w
see more here:
http://www.youtube.com/watch?annotation_id=annotation_90634&feature=iv&src_vid=Vq8JguPxq3w&v=-00VbGm3uzs
Sep 15, 2012 | Fujifilm Instax MINI 7s Instant Film...
My pentax k1000 works great except for when I first load the film. Every time I first load the film, the rewind knob wont rotate when I snap pictures. Everything on the inside is intact and usually I have...
I'm not sure I see a problem here. There is enough slack in the film that the first few exposures can spool out of the canister without it turning. If in doubt, close the back and then _lightly_ turn the rewind crank to take up the slack. Don't force it, just turn it until you feel resistance. Then advance the film and see whether the rewind knob turns.
Feb 28, 2011 | Pentax K1000 35mm SLR Camera
TV turns on, but a picture from previous channel I was watching is frozen to the screen. I've unplugged cable cable card and connection to cable service and picture is still frozen on screen. Will not...
sounds like a burn-in but are you saying that you can view another picture but no clear because the previous picture is still there. A burn-in is a tv being left on a fixed object like a picture and left there so long this is what you see when you change channels the image burned on the screen, is this what you have?
Jan 06, 2011 | Hitachi 42HDS69 42 in. Plasma Television
My cameras advance lever will not spring back and allow the film to move to the next frame. How do i fix it?
push the film release on the bottom of the camera and try to continue forward then. If you are trying to get 27 pictures on a 24 exp. roll you may have advanced your film so far that it is stuck on the piece of tape that attaches the film to the spool. Take only 24 pictures.
May 20, 2010 | Ricoh KR-5 SUPER II 35mm SLR Camera
Problem with PS3 system
check for a weak connection try different outlet or check settings
May 02, 2010 | Sony Playstation 3 (PS3) Console
Frozen picture and no button response
Hi John.
Try unplugging the TV for about 30 minutes to an hour (reset TV) to see if this fixes your issue. If it does not, leave the TV unplugged all night and see if it will operate normally. Hope this helps.
May 22, 2017 | Westinghouse LTV-32w3 HD Television
Frozen image on nikon coolpix L18
We were in the middle of taking pictures on our Nikon L18 and it was in continuous shot mode and the picture froze on the screen...I called tech support and they wanted me to turn the camera in so it could i fixed..it was a BRAND NEW CAMERA!!!!
yeah so we just took the batteries out and let it reset...see if that works.
Apr 06, 2009 | Nikon COOLPIX L18 Digital Camera
Frozen Camera
Common problem.
Part called "Aperture Base" went bad and needs to be replaced.
Apr 02, 2009 | Minolta Maxxum 7000 35mm SLR Camera
LG LST-5100P set top box. Several times a day have
cap-grant, my friend has the same problem with set top box. When I phone maker I was told it is due to poor and weak signal. You must have 80% signal strength to maintain good picture. When signal strength dropped picture would freeze and had to be turned off at the power point to restart as nothing would work. So I guess what my experience says is you may need better aerial to boost signal and prevent dropout Leonard210
Oct 05, 2007 | Televison & Video
Photography Logo
123 people viewed this question
Top Photography Experts
Tony
Are you a Photography Expert? Answer questions, earn points and help others
