Question about Fisher Dishwashers
Fisher paykel 603 dishdrawer heating element turns on when not in washing cycle
  • 351 Answers
SOURCE: Problems with Fisher & Paykel Nemo model DW681.
is there somthing stuck in the wash motor,can you hear a humming noise ? if yes remove motor and see if you can turn it by hand.hopr this helps.
Posted on Mar 14, 2008
SOURCE: Fisher & Paykel DEGX2 Dryer. Need heating element changed?
I had the same problem. Everyone continued to tell me that I needed a new heating element, clean lint trap, etc. However, I took the front off of the dryer and located the heating element. On the front of the heating element, in between two wires, there is a red button. Push the button and you might hear a click that sounds similar to a circuit breaker. It is a reset button for the heating element. Try that and it might help.
Posted on Jul 27, 2009
  • 10 Answers
SOURCE: Fisher & Paykel GW612 Top Loading Washing
Hi there
That fault is the pump blocked error (no change in water level).
i have a quick and easy way to solve this problem.
first turn the machine off then tilt the machine back and lean it on something(a chair or wall), look underneath, in the top right hand corner of the plastic outer boul you will see a small pump motor it has a fan on it spin this fan and if it is hard to turn that means there is somthing stuck in the drain pump keep turning the fan and try to free whatever is stuck in the pump, then try the machine on spin again all goin well the object in the pump should come out with the drain water(doing this will not harm the machine) if the object is still stuck you will need to get the water out of the machine (bailing or siphioning will work) and tilt the machine back again and take the wires off the pump and there should be a white tab on the boul holding the pump on pull this tab and twist the pump anticlockwise about a quarter turn(you will need a few towels or a boul or bucket to catch the water) and it should come off exposing the blockage.
Hope this solves your Problem.
Nick
Posted on Aug 03, 2009
  • 784 Answers
SOURCE: Fisher Paykel dishwasher drawer won't stop.
Let's go to diagnostic test mode to see if you can retrieve the the actuator hence the tube out.
1- Press Lock button and start/pause key until the display showing up.
2- Press Power to show HO.
3- Press start button to advance the display until you see P2 for draining, if you pass, keep doing it to get it back in a loop.
4- When at P2, press lock to turn on, press a again to turn off.
5- Listen to the sound of the pump. If you hear nothing that means the pump is dead or stuck.
6- The Motor has 2 directions: one for, Rinse and one for Drain. When you done with the diagnostic, press the power button to get out of the mode.
7- If this is the case, unplug the power then remove the rack, the bottom stanless steel plate with holes then take out the rotor to clean up. It is a good design the stator is outside of the tube, so you don't have to worry too much about the complication.
8- Make a note of all the positions so you can put them back the same as they were. Good luck
Posted on Sep 09, 2009
Why does our dishdrawer tripout the safety switch in the fuse box?we have tried different electrical outlets in the house same result?
User Guides, Installations & Parts Manuals - Fisher & Paykel
https://www.fisherpaykel.com/nz/support/user-manuals/
Fisher & PaykelFind and Download User Guides and Installations Manuals for your Fisher & PaykelAppliances: ... This will help getting a quicker and more accurate result.
Expert Tips, Troubleshooting & FAQs - Fisher & Paykel ...
https://www.fisherpaykel.com/au/support/expert-tips/
Fisher & PaykelExpert Tips. Select a product type to see solutions to most common problems you may encounter with your appliance. Search. -Select-, Built In Ovens, Electric ...
[PDF]user guide DishDrawer Ph7 Eng - Fisher & Paykel
https://www.fisherpaykel.com/.../590199D%20DishDraw...
Fisher & Paykelguide', you can download it from our local website, listed on the back cover. Refer to ...Preference options and how to change their settings ... standard safety regulations.Fuse cover. Fuse. Electrical connection (GB IE only) ... Do not use an extension cord or a portable electrical outlet device (e.g. multi-socket outlet box).
[PDF]Controls (models with LCD) - Fisher & Paykel
Dec 25, 2015 | Fisher and Paykel 24 in. DS-603 Built-in...
Fisher & Paykel Double Dishdraw (DD60DCX6). 1 Draw gets stuck mid cycle & continues to wash, no beeps, water not hot. Can you tell me which parts need replacing. Previously other draw
Coulg be a faulty heater. The unit will continue to wash for 2 hours before it gives an F4 fault message. Check the resistance of the heater element. There may be a solder link that is designed to fail if the temperature ever gets too high. Otherwise it could be a faulty controller board. Post back if you can narrow the diagnosis.
Jan 27, 2015 | Fisher and Paykel Dishwashers
Fisher Paykel Nautilus dishwasher
There is a drying cycle that runs for around an hour once the DD has finished its final rinse . It should show it on the LCD
Jun 03, 2014 | Fisher Paykel Fisher & Paykel DishDrawer...
Dishdrawer f2 error
This is linked to a rotor problem. Check this video and clean the cavity. If no difference then need to replace the rotor.
http://www.appliancerepairlesson.com/2011/02/25/fisher-and-paykel-dishwasher-dish-drawer-repair/
Feb 16, 2014 | Fisher and Paykel 23 in. DD-603 Built-in...
Fisher and Paykel Dishdrawer-DS605SS F4 fault code
No temperature increase has been recorded when the element is on.
The element is not connected.
The element has gone open circuit.
Temperature sensor or electronics ADC has failed.
Oct 04, 2012 | Fisher and Paykel DishDrawer DS605FDSM...
My dishdrawer gives a F4 code. What does it mean?
The F4 code means that the machine has sensed that the water temperature is not rising while the heating element is energized. There are tests to perform to determine if this condition is caused by a faulty heater plate or the machine's controller. The heater element relay can be energized in the diagnostic test mode, and if the heater does not come on, the heater plate can be tested with an ohm meter. Changing a heater plate is a fairly complex job and you would want to consult a service manual for the proper procedures.
From below website you can learn how to go to diagnostic mode and the reference chart
http://www.fisherpaykelparts.net/techsheets/603.pdf
Thank You
Sep 06, 2010 | Fisher and Paykel (IWL12)
Dishwashers Logo
Top Fisher Dishwashers Experts
Tony Houde
Tony Houde
George Merkley
George Merkley
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Fisher Dishwasher Expert? Answer questions, earn points and help others
