Question about Carrier Base Series 2 Stage Heat/ 1 Stage Cool 5 Day Programmable Heat Pump Thermostat
How to change temp. settings on a carrier thermostat from Celsius to Fahrenheit.
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 61 Answers
Whats the model and serial # of the thermostat
Posted on Sep 20, 2017
3 Suggested Answers
tborn6
  • 700 Answers
SOURCE: My outdoor heat will not
you need to go oside and look for a red reset button on the unit. you tripped the high ressure switch when you let your filter get that dirty. go check on this and when your done if it still is not working then ask me more.
Posted on Jan 25, 2009
  • 4736 Answers
SOURCE: My carrier comfort zone II
I suspect that if you change the battery in the thermostat. All will be right again.
Thanks for choosing FixYa.
Posted on Aug 27, 2011
Need to change thermostat from Celsius to Fahrenheit
The first link is operators manual.
The second is installation and contains the procedure to set many functions including the display temperature.
https://customer.honeywell.com/resources/techlit/TechLitDocuments/69-0000s/69-2577ES.pdf
See page 15 function set 14. This sets F or C temperature
https://customer.honeywell.com/resources/techlit/TechLitDocuments/69-0000s/69-2578ES.pdf
hope this helps?
Jun 23, 2017 | Honeywell Heating & Cooling
How to change Honeywell TH3210d1004 thermostat from Celsius to farenheit
Press and hold up and down temp buttons together to enter settings menu. Then press up to option 14. Press down to change to option 0 (Fahrenheit). 1 is Celsius. Press up and down together to save and exit. Good Luck!!
Apr 21, 2017 | Honeywell Heating & Cooling
How to change a dometic thermostat from Celsius to Fahrenheit
hold down both temp up and temp down buttons for7-10 seconds
Aug 29, 2014 | Dometic Heating & Cooling
Temp dispayed in celsius.
Inside the thermostat (behind) are 3 tiny DIP switches.Switch #3 should be set to OFF or click it to the left to display *F.You can use a tiny scerwdriver
Nov 07, 2011 | Honeywell Electronic Programmable...
Thermostat read out changed to cel instead of faren. .. How do I change it back?
hello cwest.... If your thermostat is reading Celsius instead of Fahrenheit press the 'Set Time' & 'Hold Temp' buttons at the same time to toggle it back to read Fahrenheit again.
J.
Jul 16, 2011 | White Rodgers 0754-1 Electric Water Heater...
I have a white rodgers thermostat wall unit and i cant get the air conditioner to work properly it wont go above 32 and it says it 32 in the house but its 100 and i live three flights so you know heat ...
Your thermostat is set for Celsius and 32 in Celsius is 90 Fahrenheit. Set it to 22 degrees and that should get you to about 73 degrees Fahrenheit. The t-stat is set for Celsius or Fahrenheit on the back of the unit, there should be a small switch that reads C and F, set it for F and you are good to go.
Jun 18, 2011 | Heating & Cooling
My thermostat now reads in Celsius. How do I change it back to Farenheit? IF80-54
Try the following, Cheers, Joseph
°F/°C CONVERTIBILITY - Press and hold SET TIME and
HOLD TEMP buttons until the temperature display is in
Celsius (°C). To display Fahrenheit (°F), repeat the pro-
cess. 5:30AM.)
Jan 06, 2011 | White Rodgers White-Rodgers 1F85RF-275...
Change from celsius to fahrenheit
You can switch the temperature mode between Fahrenheit to Celsius as follows:
While depressing the AUTO button, depress the OFF button for 3 seconds or more. The display will change from Fahrenheit to Celsius, or from Celsius to Fahrenheit."
Jun 02, 2009 | 2003 Kia Sorento
Can't change my thermostat from fahrenheit to celsius.
When you do your system setup, Function 320 controls your temp. format. Set Function 320 to 1(celsius); Then press DONE. This will solve your problem.( Function 320 is defaulted to 0-Farenheit).
Feb 15, 2009 | Honeywell Programmable Thermostat Heater
Carrier Base Series 2 Stage Heat/ 1 Stage Cool 5 Day Programmable Heat Pump Thermostat Logo
242 people viewed this question
Top Carrier Heating & Cooling Experts
Dan Webster
Dan Webster
Bill Long
Are you a Carrier Heating and Cooling Expert? Answer questions, earn points and help others
