Question about Garden
I purchased a Stihl 036 chain saw at a yard sale. I have cleaned the carb, fuel tank and filter and the air filter. I filled the fuel tank with fresh gas/oil mixture (50:1 ratio), installed new spark and have spark to the plug but it still will not start. I adjusted the low and high needles to l 1/2 turns out. Any suggestions?
    President:
  • 2,220 Answers
Your “Product Instruction Manual’ can be downloaded here:
http://www.stihlusa.com/stihl_ownersmanuals/036_Manual.pdf
Page 39 lists “H” and “L” initial carburetor settings Careful needle valves if over tightened closed (CW) the adjustment screw faces are easily marred; marred adjustments are difficult to impossible to set properly. Your settings may be to rich.
Was this saw perhaps operated in a lean condition (metal transfer from the piston to cylinder wall)? This may be caused by many things including; leaky intake connections at the engine or carburetor; leaky crankcase seals; or running on gasoline containing no 2-cycle oil.
1. Remove the spark plug wire and plug. Remove the muffler, hold a light at the plug hole and inspect the cylinder through the exhaust port. Is it smooth and shiny or does it appear speckled with dull gray spots or smears?
2. Pull the starter slowly, inspect the piston as it rises and falls. Is it a dull gray without scratches and gouges?
3. Hold the light at the exhaust port and look through the spark plug hole, inspect the cylinder above the exhaust port. Is it shiny and smooth or speckled with gray spots or smears?
Any spots or smears on the cylinder or deep scratches and gouges in the piston indicate the saw was operated in a lean condition. Repair of this on a home owner quality saw often exceeds replacement cost. A repair estimate by an independent saw shop should be considered.
If still not able to start please reply below and we will continue. HTH
Lou
Posted on Jan 21, 2010
    Problem Solver:
  • 14 Answers
It probable wont start because the air gap is to wide, or the piston cyclinder are scored, this is very common in stihl chain saws and cut saws. Air gap should be about a buisness card, and if it is the other you will need to replace the piston and cylinder.
  • 491 Answers
CLEAN OUT FUEL LINES
Posted on Jul 20, 2009
How do you get to the oil filter and how do you clean it and change it.
How to clean the chainsaw's air filter - YouTube
? 3:11
https://www.youtube.com/watch?v=wozSufvtbfE
May 30, 2012 - Uploaded by iScaper1
Tips for removing and cleaning the air filter on a Stihl MS250chainsaw. ... A very dirty air cleaner, a little maintenance can help them live longer ... Poulan Chainsaw Review- Should youbuy one? ... chainsawbars.co.uk - cleaning the air filter andchanging spark plug ... Get video URL at current time.
Mac 3200 chainsaw oil tank repair - YouTube
? 3:21
https://www.youtube.com/watch?v=XXlm-o8sD6A
Jul 17, 2012 - Uploaded by conan6868
Repairing oil tank. ... Could You Fix This Mini Mac Chain Saw! ...The chainsaw guy takes the McCulloch Mini Mac ChainsawChallenge 9 23.
Mucculloch 3516 chain saw assembly - YouTube? 49:25https://www.youtube.com/watch?v=Xm4YL3pDG8cJan 20, 2014 - Uploaded by Dragracer64In this video I take a box of dirty chain saw parts that has been sitting in my attic for about 12 ... Is there supposed to be a filteron the line in the chain oil tank? .... How to replace MCCULLOCH chainsaw MAC 3516 fuel line.How to replace MCCULLOCH chainsaw MAC 3516 fuel line ...? 1:32https://www.youtube.com/watch?v=GMjXYKza-NYJan 13, 2013 - Uploaded by Lambda ITCMCCULLOCH chain saw MAC 3516 chainsaw fuel line replacement. Three fuel lines. 1) First line in the tank ...
Dec 27, 2015 | McCulloch Garden
My chain saw starts but won't keep running what is wrong with it
Sparkplug ,If not. Try saw on half Choke, if works check filter in tank.
Jan 22, 2015 | Stihl 16" Chainsaw Bar Chain Saw 018 025...
Saw has new vent wont run after hot unless i loosen cap
The vent is not working properly or was installed incorrectly, so there is no negative air entering the tank to take up the space of the fuel leaving it for the combustion chamber. Perhaps your tank cap has a vent as well that isn't working.
Aug 05, 2012 | Stihl Chain Saws, 017, 019, 021, 023 & 025
Saw idles somewhat but bogs down and quits (no power) when using throttle
check fuel filter, fuel tank vent, air filter, main jets could be blocked, leak in the fuel line between carb and tank, diaphragms fatigued in carb.
Mar 21, 2012 | Husqvarna Chain Saw Handle Models 50 51...
I have a stihl 076av all of a sudden she will not start getting plenty spark been running as should
The fuel lines may have become airlocked.This can happen if the tank is run dry. If the saw has a primer bulb, alternatively press it several times and then try to pull start the engine with choke on. Repeat this several times. The primer bulb should feel spongy and fill with fuel.
If you're up to it, you can dismantle the carburettor and clean any dirt from valves.The carburettors on chainsaws, hedge cutters etc are very fiddly with delicate diaphragms, valves and springs so you have to be careful to avoid damage or loosing parts.
Ensure air filter is clean. Foam elements can be washed with hot water and detergent, squeezed dry in a cloth and re-oiled with a teaspoon of engine oil spread through the foam. Paper elements can be cleaned with compressed air blown from the inside of the filter but ideally should be replaced.
Check fuel lines aren't kinked or blocked restricting fuel flow.
Ensure fuel filter isn't dirty. This is probably located at the end of the fuel line in the tank.
Check the throttle cable is actuating the throttle plate in the carburettor.
Check whether there is a vent on the tank or on fuel cap. There is usually a valve on this to allow air into tank to replace fuel as it leaves for the carburettor. Ensure this isn't blocked.
Hope this helps !
Apr 07, 2011 | Stihl Chainsaw 051 075 076 Drum Chain Saw...
I have an older stihl 028. The saw starts and idles nice. As soon as you throttle up or put it under load, it bogs out, It also seems a little smokier, Can ya help? I cleaned the carb and jets and...
First check your fuel filter. Its on the end of the pick up tube in the fuel tank. Could be clogged. this is a relatively easy and inexpensive place to start. Make sure the fuel supply isnt pinched anywhere along the way.
Could be a scored cylinder. A scored cylinder is common problem with all makes of chainsaws. If you dont take special care to keep the air filter clean and in perfect working condition, the wood chips and dust will enter the combustion chamber and score the cylinder walls, ruining the rings causing a loss of compression.
The piston could also have been damaged from running to lean of fuel to air mixture causing heat damage to the piston and cylinder.
Hope this was helpful. If so, gimme a thumbs up vote!
Thank You
Oct 08, 2010 | Stihl 16" Chainsaw Bar Chain Saw 018 025...
Yard machine ym26ss straight shaft trimmer. New gas,
Fuel starvation - 'lean fuel' condition
Basic things to check:
1) spark plug
2) spark arrestor in muffler
3) fuel lines and tank filter
4) turn adjustment needles out (counterclockwise) 1/4 to 1/2 turn
Chain Saws:
5) check impulse tube and intake boot for cracks or leaks
*if all of the above are OK and/or do not improve performance then:
Remove Carburetor
6) replace gaskets/diaphragms
a) use a spray carb cleaner to clean jets, holes, and body of carb
b) fuel pump diaphragm goes against the carb body,
then the gasket towards the outside
c) metering gasket goes against the carb body,
and the diaphragm goes towards the outside
Nov 12, 2009 | Yard Machines Garden
Stihl 021 running poorly
Couple of things I would check first. Place a funnel in a can with a paper napkin covering bottom of funnel. Pour the gas from the saw into the funnel. If there is a lot of trash in there, remove the fuel line from tank. Clean the filter with carb. cleaner. Then clean the tank with carb. cleaner. If you still have problem. Replace the Air inlet tube, (clear tube with screw type device close to carb).
Apr 15, 2009 | RTO Spur Sprocket For Stihl 017, 021...
Stihl 021 is hard to start, runs very briefly after ignition.
My guess is since you have ignition, it is a fuel issue: 1- the carb or the fuel lines or pump are plugges with dirt, 2- fuel pump is not working,3- carb needs cleaned 4- air filter is plugged which is very common also. When the saws sit for 6 months or so, the cylinder tends to get gummed up cause our gas is SO good & when this happens with one of my saws, I put spray lube in the spark plug hole & turn it over. When I am thinking, I store my saws with the gas tank down, so that gas isnt running into the carb/engine.
Apr 11, 2009 | Standard Oregon Chainsaw Chain For Stihl...
Stihl chainsaw
Hi
First remove the cover,air filter and the carburator.Then remove the gas tank cap and the fuel filter from inside of gas tank,at the end of fuel line.Take off the fuel line from the hole of the gas tank(at the top),replace the fuel line,put all back together and start the engine.
best regards savumihai71
Feb 13, 2009 | Husqvarna Chain Saw 20" Bar
Garden Logo
1,866 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
