This is very frustrating and I am on level 865. Please help!!! I have not been able to play for about three or four days. I am using a Kocaso tablet.
SOURCE: Loading Games
I used to have the same problem and Nintendo said it was beause the optical lasers were not lined up straight. Send it to Nintendo and you will get it back in 3-5 days.
SOURCE: pes 2009 stopped loading
Delete The Update File From Game Data Utility And Redownload It Works Fine After. But Online Mode Does Not Work Anymore...
More And More Game Now Days Need All This Updatein Hardly Any Of It Works All I Ask For Is Workin Game's.. You Pay £39.99 For Wot Broken Games?
SOURCE: Wii VC games won't play on hdtv
I had the same Black Screen problem and I finally have a fix for it!
When using component video cables and a HDTV: Go into the Wii's system settings, under Screen, change TV Resolution to HDTV (480p) instead of Standard TV (480i) and change to Widescreen (16:9) under Widescreen Settings.
This worked for me, good luck!
SOURCE: it always goes in a white screen and never works
although i will not condone game piracy as appears to be the case here, maybe you should update the firmware,
http://www.r4i-sdhc.com/downloade.asp
keeping in mind it's this sort of blatent piracy that kills the game industry.
If its only 3 mnths old should still be under WARRANTY take it back
if its not under warranty
Turn Off the computer now as soon as you hit the power button, keep on holding Alt key & keep on tapping F10 key ie: Alt+F10, it will open the recovery console select full factory restore and follow on screen instruction. (Note:this will erase all datas on the computer) or
During the boot process you will see on the screen to press a certain key to enter setup usually delete or the F2 key this will differ depending on which bios you have
Press and hold that key during the boot up process to enter BIOS using the arrow keys you can load failsafe defaults or load optimized defaults press escape then press f10 to save to cmos to restart
hope it helps
Here are a few things you can do or try
Restart the computer. If you are already in Windows, you can do this from the Windows Start menu, go to Turn off computer and click Restart. As the computer restarts, watch for a progress bar at the bottom of the screen. press F8 about once every second. Immediately press F8 before the progress bar reaches the right side of the screen. From the Windows Start-up menu, highlight Safe Mode and press Enter. Wait for your desktop to appear, and then make the necessary repairs (for example, uninstall programs or devices). When the repairs are done, restart the computer, and allow it to boot normally.
Alternate:
From the Windows Start menu, click Run. In the Open field, type MSCONFIG and click Ok. On the BOOT.INI tab, check /SAFEBOOT. Click Restart when prompted. Turn Off the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10 key,ie: Alt+F10, it will open the recovery console ,select full factory restore and follow on screen instruction. (Note:this will erase all datas on the computer) or During the boot process you will see on the screen to press a certain key to enter setup Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart click start all programs accessories scroll to system tools from there you should see a system restore click next a sytem date should open up select the date you want to restore your computer to or if you want a full factory restore or Turn Off the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10 key,ie: Alt+F10, it will open the recovery console ,select full factory restore and follow on screen instruction. (Note:this will erase all datas on the computer) or During the boot process you will see on the screen to press a certain key to enter setup Press and hold that key during the boot up process to enter BIOS you can load failsafe defaults or load optimized defaults ,press escape then press f10 to save to cmos to restart
Hope this helps don
