Error code c2484 c6000 - Office Equipment & Supplies
2 Suggested Answers
  • 8619 Answers
SOURCE: c6000 error code
Error C6000 is displayed when your machine fails to reach the correct temparature at a specific time.
This is a Fuser Unit Problem, try to reset it by--
First open top cover then turn on power.
press system menu/counter
arrow down to service
press and hold start, # then enter keys
arrow down to maintenance
press enter
arrow down to Sim 163
press enter
select execute
press enter
turn off power then back on
If the reset doesn't work then get your unit checked for fuser unit and fuser unit heat issues.
Please do rate this solution as FixYa and revert for further assistance.
Posted on May 09, 2009
How to solve C6000 problem in Taskalfa 180/220?
Code C6000 Description Fuser heater break
The temperature does not reach 70 °C/ 158°F in 15 s before secondary stabilization.
Temperature rise of 1°C/1.8°F does not occur in 5 s before secondary stabilization (except during printing). Causes Poor contact in the fuser thermistor connector terminals.
Fuser thermistor installed incorrectly.
Fuser thermostat triggered.
Fuser heater installed incorrectly.
Broken fuser heater wire. Error Codes Kyocera Mita TASKalfa 180 Code C6000
Oct 28, 2015 | Office Equipment & Supplies
How do I reset xerox C6000?
C6000 km-1820.3gp - YouTube
? 0:55
Oct 6, 2010 - Uploaded by natasmanda01 Cancelamento dos codigos de erros c6000, c6400 e c6020 da kyocera ... HOW TO RESET AND HARD RESET KYOCERA HYDRO XTRM ...
Printer Resetter: Solving error C6000 on Kyocera Mita printers
Aug 8, 2013 - c6000. error. Error Message Check Ink U041 · Xerox WorkCentre C2424 DADF Error ... SSC Service Utility Software to reset Epson printers.
Oct 19, 2015 | Xerox Phaser Office Equipment & Supplies
How to repair fixing unit of copier machine it replies Error C6000
I assume that your printer is a Kyocera Mita and probably one from their KM range. I proceed on this basis.
It is possible to reset this using U163 in Maintenance Mode to reset the code. If the error still persists it is to do with the fuser unit. I found many error codes for many printers and the particular page of relevance to you is here:
Error Codes Kyocera Mita KM2540 Code C6000
It is for the KM2540 but you can change models easily using the drop down menu in the centre of and near the top of the page.
Hope this is helpful, if so would you please register that with Fixya
Dec 03, 2014 | Office Equipment & Supplies
Have error: C6000 on call for service c6000
The error code(C6000) Maybe the broken fixing heater wire. In fixing warm-up, the time to reach 50 degree(C)/122 F exceeds 10s, the time to reach the primary stabilization exceeds 10s or the time to reach secondary stabilization exceeds 24s. Or the Fixing heater M or s installed incorrectly. Check and re-install if necessary or replace the fixing heater M or S
Aug 23, 2014 | Kyocera Mita KM-2050 Printer
Kyocera 2050 errore code c6000 problam
Error C6000 is a fuser error.
Solution 1:
  • Turn it off
  • Wait 5 minutes
  • Turn it on and the code will be clear.
Solution 2:reset the fuser
  • First open top cover then turn on power.
  • press system menu/counter
  • arrow down to service
  • press and hold start, # then enter keys
  • arrow down to maintenance
  • press enter
  • arrow down to Sim 163
  • press enter
  • select execute
  • press enter
  • turn off power then back on
Solution 3:
  • You need to replace the fuser
Sep 25, 2013 | Kyocera Office Equipment & Supplies
KM 2810 error C6000
kyocera mita KM-2810 error code C6000 how to re-set and fix it
Feb 06, 2013 | Office Equipment & Supplies
Ererre c600 km 2035
Are you sure the error isn't C6000, which is a fixing unit error? If it is a C6000 then it maybe able to be reset in simulation mode if the fixing unit hasn't failed. Verify error code.
Dec 23, 2010 | Kyocera Mita RADF-11 REVERSING...
KM-2035 error call service c6000
Hello sir; Just follow my instruction, I will help you to get rid off the error code; With front door open press10871087 then enter 163 press "start" key, final press " stop/clear " key to get out reset procedure.
Aug 23, 2009 | Kyocera Mita Office Equipment & Supplies
32 people viewed this question
