Question about Dayton Heating & Cooling
Furnace has water under it, why? Its a Dayton gas furnace.
For a month now there is water that will puddle up around the base of the furnace, it takes a couple days to make enough water to notice. Dry it out and same symptom a couple days later.
    Master:
  • 286 Answers
There are several questions that need to be answered about what type of system you have, but i found this posting that may help:
As your gas furnace runs, is there water leaking at the base? Is the furnace's air filter wet, too?There are a few things that could be happening here. But if you have a high-efficiency furnace, here's the most common cause: a condensation leak.
We'll explain why a furnace creates condensation, and what's causing it to leak out of your furnace.
Note: You'll know if you have a high-efficiency furnace if:
  • The yellow energy guide tag says your furnace's efficiency is 90% or higher AFUE.
  • The vent/flue pipe is white PVC as opposed to metal.
Why a high-efficiency furnace creates condensation
How in the heck does a high efficiency furnace create condensation/water anyway?
It's all about how the furnace extracts heat from combustion gases.
A lower-efficiency furnace extracts some heat from combustion gases and then quickly vents them out the flue pipe.
But a high-efficiency furnace, to extract more heat, has 2 heat exchangers. These allow the furnace to extract heat from the gases for a longer period of time. This causes the combustion gases to cool and then condense.
That condensation then exits out your home through a drain. But if that water is pooling around the furnace, there's a problem preventing it from draining properly.
Causes of a condensation leak around a high-efficiency furnace
  • Clogged condensation tubing
  • Clogged condensation drain
  • Breaks in the condensation line
  • Issues with the condensate pump (if you have one)
You'll need a furnace technician to diagnose which of these is the issue and then fix it.
Other causes of leaking water around a furnace
If you have a conventional, standard-efficiency furnace...then its flue pipe may be incorrectly sized.
If you have a whole-house humidifier connected to the furnace...there may be an issue which is causing the humidifier to leak into your furnace. Your humidifier should be getting annual maintenance from a professional to prevent this.
Posted on Dec 14, 2016
I have a Dayton gas furnace FG8B07512MU12A. It has a new control board and worked fine for the last 6 months. Now when the fan goes on the air put out is cool not warm. The card shows a slow blinking...
Is the manual gas valve open, either plumbed or on gas valve? It may sound dumb, but it happens. Are the wires connected to the gas flow solenoid securely?
When the heat call initiates heat cycle, can you observe the ignitor? If it tries to ignite, is there gas entering the burner? How clean is the gas orifice? If the orifice is plugged, best to simply replace it.
Dec 18, 2011 | Dayton Gas Furnace Heater
No problems, would like to find out the best way to remove blower for cleaning on an intertherm gas furnace mgh 075 ina mobile home
Generally ther is two screws at the base of the blower housing which hold it in place, remove the screws and pull, slide the entire assembly out. You will have to disconnect the electrical wiring to the blower and possibly the limit switch on the side if equip.
Aug 23, 2011 | Dayton Gas Furnace Heater
I have a Dayton gas wall heater, about 1982, and the thermostat is "worn out." The last 2 digits of the thermostat [Honeywell] serial number is also worn to the point of being illegible. The...
The only thing you can do is get the modol and serial number off the furnice it self go to your local parts store and thay will tell you if that part is available ore not,thay will be abel to tell you for sure.
Jan 20, 2011 | Dayton Gas Furnace Heater
No ignition on dayton gas furnace. how hard is it to install new gas valve on a dayton furnace
not hard but before replacing check pilot light and thermocouple for proper function and setting if pilot light not in right position thermocouple wont open gas valve if electronic ignition check for power and proper gap on igniter also check stat for proper function
Oct 31, 2009 | Dayton Gas Furnace Heater
We have a dayton gas furnace model #3E463A. thought the control box was gone. got new one we furnace starts up the power goes on, fan starts no green pulsing light on control no ignition
When your furnace starts...the Ventor motor(exhaust fan) starts up....within a short time (seconds) the Pressure switch closes proving that the Fan is indeed running and the vent is not blocked...if this doesnt happen the furnace will not poweer the ignitor or fire at all....Check the vent pipe outside and look for obstructions or dirt on the screen inside the pipe...the condensate from the fuirnace may not be draining at all...due to plugged condensate drain lines...find this tube coming out of the furnace front...bottom of upper compartment usually , and pull it off the tap....if water starts coming out then your drain is plugged downstream of the furnace.
Oct 25, 2009 | Dayton Gas Furnace Heater
I want to convert a model 3e476b propane counter
The Dayton brand belongs to WWGrainger if the parts are available that would be the only place.
Oct 02, 2009 | Dayton Gas Furnace Heater
Dayton 3e735 standing wall furnace
Wall furnace? maybe and maybe not! if there is a way it would be on the gas valve and be labeled (though it might be hard to read). often the adjustment screw is under another screw but always labeled.
Feb 03, 2009 | Dayton Gas Furnace Heater
Fault Code on Dayton Gas Furnace
This happens when the furnaces tries to light to many times and doesnt succeed. If you stand in front of the furnace while it is coming on, you will be able to hear the problem. If its an electronic start, there will be a clicking sound, followed by the gas valve opening to start it. If it has a pilot light, make sure it is lit, then listen for the gas to come out, it will make a hissing sound. If no gas is coming out, first double check to see if the gas is turned on to the unit, if it is, then its possibly the gas valve. Oh, if it is electronic, and you hear gas, but dont see a glow inside the furnace, or no glow or gas, it could be the ignite. Hope this helps.
Jan 07, 2009 | Dayton Gas Furnace Heater
Dayton gas furnace
try cleaning the flame sensor and the burner , check out the pressure switch might be blocked in the tubes
Dec 07, 2008 | Dayton Gas Furnace Heater
Heating & Cooling Logo
49 people viewed this question
Top Dayton Heating & Cooling Experts
Paul Carew
Mack Baxter
Dan Webster
Dan Webster
Are you a Dayton Heating and Cooling Expert? Answer questions, earn points and help others
