Why when I ran a/c it would leak water from out of inside unit and shut off or rather day I would have to go and try the breaker it's on its in breakerer
    Master:
  • 286 Answers
You probably have a plugged condensate drain line, you will need to clear that out. It may be that the coil is also icing up. That could be due to a plugged air filter or a low refrigerant charge in the system.
Posted on Dec 14, 2016
Therinnaiguy
  • 1420 Answers
SOURCE: no cooling after power out, indicator lights pattern not in manual
The Mitsubishi units have to be reset by turning off the indoor units by switching the remote or thermostat to off. Then turn off the breaker to the outside unit(s). After 30 seconds,turn on the breaker and then you can turn on the remote for cool. If no lights come on on the inside units, most likely you have blown a fuse soldered on the main PC board. At this point, call your technician. A goos tech will be able to wire in an in-line fuse holder so if it should happen again, you can easily replace the fuse. If you do see a light or two come on at the indoor unit but the outdoor unit does not start after 3 or 4 minutes, sounds like you will need to call a technician. Most likely you have a blown fuse on the main PC board of the outside unit. It is not an easy one to replace. Good Luck!
Posted on Sep 04, 2007
  • 56 Answers
SOURCE: evaporative air conditioner not working
Wish there was more that I could do to help but you may need to have someone or yourself check for anything shorted/grounded and also make sure the voltage is correct to the solenoid.
Posted on Feb 14, 2009
TheMobilian
  • 8220 Answers
SOURCE: Ac Problems
You must have too many things running on that circuit. Check your connection to the power box.Loose connection on the receptacle can cause the breaker to trip or too many things running on the same circuit. If the breaker is old it might need to be replaced.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Posted on May 10, 2009
  • 116 Answers
SOURCE: Coleman A/C-Heat Pump Start and Stop Run Problems
well you have it great job! on the out door unit when it will not shut off disconnect the yellow wire on the stat wires coming from inside if unit stops stat bad if not contactor "points' if they look pitted or buzz change them #1 reason for compressor failure high amp draw thru bad contactor hope this helps aboout 15.00 at hvac store seperate wires with zip ties so dont get mixed up if only one set of points then 30amp single pole 24vac coil contactor
Posted on Jun 04, 2009
SOURCE: Carrier air conditioner
i have nothing on my thermostat. I was going to install a programable thermostat so I disconnect my old one. When I couldn't use the new one I reinstalled the old one and now it's like there is no power to it. Checked circuit breakers and found none tripped and tried thermostat in upstairs since I have two thermostats and it works fine there What next???
Posted on Jul 22, 2009
MasterTemp 250 blowing breaker...
Could have a soft breaker.
Have a technician check the amperage draw at breaker pane.
May 21, 2014 | Pentair Mastertemp Heater
The power will not shut off
Usually in a miele dishwasher when the power does not shut off this is due to a leak condition in which the pump is trying to pump any access water due to a leak out of the unit in which the drain pump of the unit will run continueously to avoid water to come out of the sealed bottom and spill all over your floor. One of the first things that would distinguish if this were the case in your unit, would be if you could hear the drain pump running. This can also happen if you have a clog either in the drain pump or in the drain line or in the port hole where the drain pushes the water into your disposal. If you do not hear the drain pump running. As to the door latch it basicly tells the control that the door is either opened and not to turn on the cycle or closed and then to turn on the cycle and begin to wash. You can also check to assure that you have no leaks by pulling the unit out by deinstalling the unit and removeing the bottom base panel to see if there is any water inside. If you find there is no water and no clogs and you do not hear the drain pump working message me back for further diagnosis. I await your reply.
Thank you
Rick
Nov 02, 2011 | Miele 24 in. Incognito G843SCVi Built-In...
I have a carrier air conditioner 38TKB024. About 15 years old I think. Accidentally ran it with the cover still on after the winter. shut it off after about a day when I realized. Went to try it the...
You probably just blew the fuses or tripped the circuit breakers. There may be fuse right beside the unit in a box with a door on it. The fuses will be in a cartridge inside the box. You will need to change them both unless you have a ohm meter to check them. Also check your circuit breakers. The will more than likely be in your main circuit box. It will be two joined together, probably 20a or 30a. Trip them all the way back and then forward and try the unit again.
Jun 11, 2011 | Carrier KCA101P Air Conditioner
My SM11 model Steamist was installed above our shower/steam room. It is 2 years old. While in use recently, it made a loud sound like a low-pitch popping sound or low boom. Imagine somebody inside a...
The heating elements had burned up in the unit therefor creating a dead short on that circuit. Main breakers on homes and buildings are VERY sensitive and will sometimes trip before the smaller branch cicuit breakers will . So the popping you heard was the heating elements breaking down inside the unit it can be some what noisy.
Nov 03, 2010 | Steamist 1100 Sm11 Large Capacity Steam...
Unit is plugged into a GFI outlet.Work for a while,but now,when reach the hottest point pop the outlet. I tried different outlet and it does the same
If it is popping the GFI reset on the outlet, there may be a leak inside it. GFI's usually only trip in the presence of water creating a path to ground. It could be just starting to leak and shutting off before enough comes out to see. You could try plugging it in to a normal outlet, but you must BE CAREFUL! If there is a leak, don't touch it or unplug it until you kill the power to it by tripping the breaker, pulling the fuse, or unplugging an extension cored at a safe distance. Obviously, if you have a leak, take the necessary steps to fix it.
Jan 11, 2010 | RTO Waste King AH-780-UL Quick&Hot Instant...
Won't drain and unit will not shut off
water will not go into my dishwasher any solutions
Nov 16, 2009 | Asko D1776 Stainless Steel Built-in...
Jun 04, 2009 | Coleman Mach III Air Conditioner
Whirlpool over the Stove Microwave
This sounds like the unit is defective and if I were you I would return for replacment!
Dec 16, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Water leaking from portable air conditioner
Sounds like the drain line is blocked you would have to take this unit apart in order to check this. I would use a can of air to blow out the leakage. Also make sure the unit is level
Jan 23, 2008 | Heating & Cooling
Heating & Cooling Logo
32 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
