Question about LSI Logic Computers & Internet
Where dose my orange wire go I forgot n lost my book, logic eq500
1992 Nissan D21 , left turn signal dose not work , changed bulb and relay , still dose nor work. What next?
Next is probably the turn signal switch. If you have a voltmeter, however, you could be more likely to find the problem, using it to test for voltage at places in the circuit. So I guess you might also need a wiring diagram along with the voltmeter...
If you have neither a voltmeter or a wiring diagram, use logic to think the right turn works so the fuse is good, and if the right turn works, power is going to the switch, and out correctly for the right side, but seems nothing for the left, ( DID YOU CHECK NOT EVEN A BULB DIMLY LIT ON THE LEFT SIDE, FRONT OR BACK? AND ALSO THE LEFT TURN DASH INDICATOR IS NOT LIT?) If nothing lights up for left side, the power is probably lost right in the 25 year old turn switch. That's where you would check for power out (on the proper wires) with a voltmeter- no power means switch is bad. But if the power comes out of the turn switch for left side, then you have to look further along in the wiring , probably not far from the switch connector if the dash indicator bulb is also not lit....It probably is your turn switch.
Nov 25, 2016 | Nissan Cars & Trucks
I have a 1991Dodge Dakota what dose the code number 12411155 mean
Code....
12 - logic module lost power. Previous codes erased.
41 - Alternator field control circuit open or shorted.
11 - ECU lost battery power
55 - End of codes
Jan 16, 2016 | Cars & Trucks
Does the Blinking Light on the Asic Main logic board mean bad Logic Board?
Check all the capacitors one might be bad find out if it is bad it should bulge on top of the capacitors
Nov 04, 2017 | Magnavox Televison & Video
I lost my printer book so i don' t know the code for 6500 error
It might be due to some fault in the logic assembly.
Make sure you call some canon technician to look after the logic assembly and if possible,replace it!
Cheers!!!
Oct 18, 2010 | Canon PIXMA MP830 All-In-One InkJet...
Nintendo D S Lost in case six month on Holiday. Put on charge orange light come;s on it go;s Out straight away total dead
possibly a faulty battery or 1 or 2 of the fuses on the logic board have blown and need to be changed. f1 is situated near the top of the board by the charger socket and f2 near the bottom of the slot 1 game socket, have a look around the board and u will find them, they are marked or a new logic board is needed.
Jan 08, 2010 | Nintendo DS Lite
GDO - Do I need a new Logic Board or is it something simpler?
No, the problem is the photoelectric eyes. Check that they are properly aligned.
Aug 02, 2009 | Kitchen Appliances - Others
Amilo Pro V2035 - Broken Headphone Jack Stuck inside Headphone socket
Also remove the battery and any other removeable plates below the notebook to check for additional screws. Check if there are any rubberized "feet" or plugs covering access to still more screws. Keep screws and their locations organized in case they are different length.
Aug 12, 2008 | Fujitsu AMILO Pro V1000 Notebook
Rcu 450
The book says the following should work for JVC TVs 012 013 054 060 065 066 067 123 157 158 159 182
Apr 20, 2008 | Televison & Video
Front display
I read the manual and it seems that changing the color is not an option. Sorry.
Sep 08, 2007 | Pioneer DEH-1430R CD Player
Computers & Internet Logo
60 people viewed this question
Top LSI Logic Computers & Internet Experts
David Payne
David Payne
Are you a LSI Logic Computer and Internet Expert? Answer questions, earn points and help others
