Bravo xl not draining and spinning properly - Washing Machines
Why does my Maytag Bravo XL washer only spin dry my wash load intermittently. It seems if that if I have heavy items in the mix, it doesn't spin.
if it can't spin out a heavy load but it does spin when empty it sounds like the transmission is bad or the belt is bad,did you ever smell a burning rubber smell?if so this is from overloading,the loads are to big and it cooks the belt and if the tranny. isn't bad and it is the belt you will take out the tranny. in the long run,cut back on the size loads you put in,if you have two loads do it in two loads,easiest way is look at the bottom of the tranny. if you see any oil then the tranny. is blown take the belt off if it looks shinny or glazed it's bad just change the belt,also when it's in spin you can slide the motor back a little,it's spring loaded so it can slide back in forth if it seems to spin faster when you pull the motor back the belt is bad.
Dec 01, 2017 | Maytag Washing Machines
My Maytag bravo washer won't drain and is buzzing from what I think is a drain pump. Do I need to replace that part and if so what is it?
it may be the pump but buzzing sounds normally indicate a faulty solenoid
if the pump is trying to spin , it could be from something in the impeller ( button , bra wire , bobby pin , coin etc) in which removal of the item will again allow the pump to work
the solenoid that allows the pump to work or water to get to the pump may be the fault
May 13, 2016 | Maytag Washing Machines
My bravo washer is not starting a cycle when I press start button. Also water is still in tub from last load that did not drain.
Sounds like you washer is trying to spin out and becoming unbalanced and cutting off.. Move timer to spin and see if water spins out. If so try running a load and say with it so if it becomes unbalanced you can arrange clothes before returning timer runs out.
Feb 20, 2016 | Maytag Dryers
How can I spin and drain my normal size load. I have an LG front loading washer m/n WM2455H and it will not spin and drain. I hear the hum of the pump, so it isn't that. Went through all troub
It is most likely the drain motor even though you hear it humming. The LG drain motor impellers usually wear out on the motor shaft, and the impellers then just end up wobbling. The result; a drain motor that no longer drains water.
Sep 13, 2014 | LG WM2455HG XL Front Load Stackable...
Lg front loader when during the cycle is the bleach dispenced
bleach? do u mean detergent? normally machines run pump/then start to fill.water will pass through drawer then they heat /wash/drain/spin then refil for rinse conditioner/spin rinse drain fast spin end pretty much
Aug 08, 2014 | LG WM2101HW Front Load Washer, White, 4.0...
Why does my maytag Bravo top load washer not drain or spin error code OL, if I change cycles to rinse and spin it drains
The controller unit has probably failed. This controls other items like drain pumps, heaters, motor etc. Because the machine can drain on a different cycle, the drain pump is fine. The cycle you use may be the only one the controller is broken for, try different wash/drain cycles. If you want to fix it you need to change out the controller, which is an expensive part compared to others.
Oct 17, 2013 | Saws
Maytag bravo quiet series 300: Stopped at spin:
We have a Maytag Bravo Quiet Series 300 washing machine, the door latch is broken. I have the replacement part ( the locking mechanism) but I need can not figure out how to get the top of the washer to flip up to give me access to top front of the machine to remove the old part and replace it with the new.
How do I flip back the top (not the door) of this machine?
Jan 15, 2010 | Maytag Washing Machines
GE Externa Tritan XL (7 yrs old): Standing dirty water
Hello, there isnt much that you can do, there could be a number of problems. It could be a slight blockage somewhere from your drainage hoses to your pump. It could also not be spinning properly. If you want to drain the rest of the water out you will need to get your drainage hose and lay it flat on the floor to a drain, this will stop things getting smelly. You just may have to get a repair man in, I hope this helps.
Nov 07, 2009 | GE 24 in. Profile PDW7800 Built-in...
Ld code on Bravo washer what does it mean
The "LD" code or "long drain" indicates a pump/drain related issue. Check the drain line for kinks or obstructions. Check the pump. Remove the hoses from the pump and use a flashlight to look into the suction port. Make sure nothing is clogging the pump (like the occasional stray sock) and check the pump impeller. Make sure the impeller has no broken/missing blades and that it spins freely. If any blades are missing/broken or if you can't get the impeller to spin freely, the pump is defective. Hopefully it's just a clogged drain line, pump, or jammed impeller. Sorry for your trouble and I hope this helped. Best wishes.
Sep 14, 2009 | Maytag Bravos MTW6600T Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
