Drain bravo xl - Washing Machines
Bravos XL F5 error
Here is a link to the error codes for your machine. There are several F5 error codes. F5 E4 Lid not opened between cycles F5 E3 Lid unlock fault F5 E2 Lid lock fault F5 E1
Lid switch fault
Oct 31, 2017 | Washing Machines
Fabric softener not dispensing. Water floods over the top and leaks out to floor
The dispenser should be removable. It uses syphon method to drain. Take it out and clean it.
Apr 11, 2016 | Maytag MVWB850YW Bravos XL HE White Top...
Washer drain pump continually runs even with power off.
have a technician check the power board as the pump power is not terminating when the machine switches off.
Jun 27, 2015 | Maytag Bravos XL 4.6 cu. ft....
Maytag Bravos XL HE Leaks Adjacent to Bleach Dispenser, how do I fix this?
Fill it with water by hand and see what happens. Tape paper towels in the suspected area. Makes it easier to see. Part 2 ans: so the water is over powering the drain...that sucks. You are right, the valve is probably letting too much water out. I don't know if it is adjustable but I do know it'll probably cost a lot for an itty-bitty brass valve. If money is not a problem replace the valve. If you are a DIY'er, I'd try to use some sort of clamp on the hose leading into the dispenser and close it just enough to slow the flow down. Another idea is to open the drain up by cutting away some of the screen if it has one. A better source than me is to go to and email them. They have a lot more experience than me. I did appliance repair as a side to handyman for 20 years & fixed just about everything for 50. I never had any formal training.
Jun 19, 2015 | Maytag Washing Machines
My Maytoag Bravos Top load washer drains really
Is the drain hose kinked or clogged? Is the drain hose installed properly? look in the installation Instructions, Press POWER/CANCEL to clear display........ hope this helps.....
Jul 09, 2009 | Maytag Bravos MTW6600T Top Load Washer
Washing Machines Logo
24 people viewed this question
Top Washing Machines Experts
