How do I drain clothes in the bravo Xl - Washing Machines
2 Suggested Answers
  • 16194 Answers
SOURCE: maytag bravos model mvwx500xw0 will not drain and spin properly
This could be a lot of things. One of them is the belt on the bottom that connects the transmission to the motor, of course it could be the transmission/clutch.
Posted on Feb 23, 2014
I have a maytag bravos xl top loader with the water saver i cannot find a detergent that doesnt get rid of the soap it covers my black clothes
powder detergents are generally the reason for that as they use a clay base to carry the active detergent and it is that base that is the problem
Try using a liquid detergent
next try using a wash bag that you put clothes in to put in the wash as that also stops marks and fluff from getting onto black or dark colored cloths
Feb 27, 2017 | Maytag Washing Machines
Fabric softener not dispensing. Water floods over the top and leaks out to floor
The dispenser should be removable. It uses syphon method to drain. Take it out and clean it.
Apr 11, 2016 | Maytag MVWB850YW Bravos XL HE White Top...
Washer drain pump continually runs even with power off.
have a technician check the power board as the pump power is not terminating when the machine switches off.
Jun 27, 2015 | Maytag Bravos XL 4.6 cu. ft....
Maytag Bravos XL HE Leaks Adjacent to Bleach Dispenser, how do I fix this?
Fill it with water by hand and see what happens. Tape paper towels in the suspected area. Makes it easier to see. Part 2 ans: so the water is over powering the drain...that sucks. You are right, the valve is probably letting too much water out. I don't know if it is adjustable but I do know it'll probably cost a lot for an itty-bitty brass valve. If money is not a problem replace the valve. If you are a DIY'er, I'd try to use some sort of clamp on the hose leading into the dispenser and close it just enough to slow the flow down. Another idea is to open the drain up by cutting away some of the screen if it has one. A better source than me is to go to repairclinic.com and email them. They have a lot more experience than me. I did appliance repair as a side to handyman for 20 years & fixed just about everything for 50. I never had any formal training.
Jun 19, 2015 | Maytag Washing Machines
Maytag bravos model mvwx500xw0 will not drain and spin properly
Feb 22, 2014 | Maytag MVWX500XW - Bravos XTM HE Top Load...
My Maytag Bravos XL electric dryer doesn't dry clothes. When I try to run a second cycle it seems like it's too hot and won't start again until it cools.
Make sure your vent pipe is clean and filter is clean. Air flow is number one reason for dryer failure, Check the whole inside of the dryer for lint build up and in the exhaust pipe. The dryer has to vent the humid air in order to dry the clothing. If it can't do that, it overheats and also the humidity stays inside the dryer.
Oct 27, 2013 | Maytag Dryers
Maytag bravos washer will not complete cycles
Remove clothes from drum. Siphon out (or wet vac out) visible water in the drum. Blow into drain hose. This back flushes the system. After hearing gurgling and seeing bubbles come up thru the drum, you know its a fairly clear line. Now take your wet vac and siphon out remaining water by connecting it to the drain line using duct tape. The lights will correct themselves and your washer will now work normally. At least this is how I fixed mine without disconnecting anything or making a big mess. Good luck.
Apr 17, 2012 | Maytag Bravos MTW6600T Top Load Washer
My maytag bravos 580 quit working. It stopped towards the beginnging of a cycle. It kept beeping and lights went around and around the dial. It wont let me change the cycle and wont shut off unless I...
Hello & Welcome to FixYa
LD error code means long drain, you can try to check the drain hose and clean it completely. Also take out the agitator and check any stuck clothes there. After this if the problem is back then replacing the pump is recommended repair. Please get back to me if you have any other questions.
Kevin
Jan 16, 2011 | Maytag Bravos MTW6600T Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
