Home | Bosch | 24 in. SHU66C05 Stainless Steel Built-in Dis... | I just finished a ser...
Bosch 24 in. SHU66C05 Stainless Steel Built-in Dishwasher
Problem for Bosch 24 in. SHU66C05 Stainless Steel Built-in Dishwasher
I just finished a service
By rlismom on Jul 20, 2009
I just finished a service call for my 5312UC/UC12. The tecnician says he saw water leaking under neath the machine but hoses were secure and no visible crack to the motor housing, The machines pump works but very little water is actually put into the tub, hence no dishwashing. This technician says that this is a repair that most technicians avoid because it takes a long time and costs alot and violated some sort of warranty. He recommend replacement after only 7 years!
Solution #1
posted on Jul 28, 2009
Not Rated)
blue124yes
Rank: Apprentice
Rating: 0%, 0 votes
This leekage may come from thermostads water isolation ring, just under rezistance leads. There must be a ceramic holder to fix it to rezistance. İf it is broken, thermostad may go down, or rezistance leads isolation (lastic washer) may leak water (you must fix from under machines by turning bolt between to rezistance leads...
Hope you fix it.
Was this helpful?
Yes
No
Solution #2
posted on Jul 20, 2009
Not Rated)
boschrepair
Rank: Master
Rating: 89%, 7 votes
i am Bosch service tech you don't need a new machine the d/w is set up so if water leaks it will leak in the plastic base you have to pull it from the cavity to fix it if you have a braided water line and a little slack on the electrical you can do it. if you run the machine and get a F code on the display you have a fill fault or water in the sump most likely it is the presure switch on the side of the d/w left hand side.
call me if you need me to walk you through it
don
262-893-4840
Was this helpful?
Yes
No
Popular Solutions for Bosch 24 in. SHU66C05
Questions and Unsolved Problems for Bosch 24 in. SHU66C05
Do you recommend Bosch 24 in. SHU66C05 Stainless Steel Built-in Dishwasher?
Answer
Answer
I found that by initially disconnecting the pipes and cleaning them out (without the usual... (More)
Answer
our bosch dishwasher had some water on the floor . I think it's coming from the bottom seal of the... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Bosch 24 in. SHU66C05...:
Top Dishwasher Experts
Rank: Guru Guru
Solutions: 1582
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Dishwasher Experts
Top Dishwasher Repair
(423) 303-3783
Dishwasher parts delivered overnight nationwide....
 Appliance Parts Pros.com
(800) 803-6775
Manage my home, all the technicians you need at...
Manage my Home
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
