Question about Cameras
Where is the clipboard - Cameras
Where do I go on my tablet to find clipboard
1. Download and install Clipper - Clipboard Manager from Google Play Store
2. Copy/Cut the item you want to paste in different place
3. Open the Clipper application, and under the Clipboard tab you should see your items stored in the clipboard
4. To copy each item in the clipboard, you just need to tap on it
Oct 18, 2016 | Tablets & eReaders
Where can I find my clipboard on my Samsung Galaxy tablet
The following article shows you how to access and clear the clipboard on the Samsung Galaxy tablet:
How to Access and Clear the Android Clipboard
Mar 20, 2016 | Officemate International Corp OIC Plastic...
How do i locate the clipboard?
The following article shows you how to find and clear the clipboard on an android device:
Oct 17, 2014 | Tablets & eReaders
What does" saved to clipboard" mean? And where can I view my clipboard? Pandigital tablet
Dear,
Clipboard is a temporary storage where the folders or files will get save while copying from one place to other in the device
Location of Clipboard: Press and hold in the text box with your finger and will bring up an option for clipboard regardless of what keyboard u use.
Regards,
Samy
Aug 10, 2014 | Tablets & eReaders
Clipboard is a temporary memory that it just saves one thing. Like copy paste. When you copy something is stored into this clipboard. The only way to see what is inside the clipboard you just click paste.
Aug 10, 2014 | Cameras
I can't transfer my pictures from Panasonic clipboard to pc
You need to transfer the clipboard pics to your memory card first. In clipboard "play" menu, go to copy. Select clipboard picture with left/right arrows and press "menu/set". Select "yes" with up/down arrows and press "menu/set".
Jun 28, 2010 | Panasonic Lumix DMC-TZ2 Digital Camera
I have photos in Clipboard and need to Download
Hit the play switch and then set the mode dial to clipboard. In the clipboard menu, there is a setting for "copy" giving you the option to copy to a memory card.
Mar 08, 2010 | Cameras
When I go to the internet n copy text, my HTC hero says that it has been copied to the clipboard but the problem is that I don't know where the clipboard in HTC hero is!
I don't think there is an actual clipboard that you can look at by default, but there are apps you can download from the Marketplace that will allow you to see what you have stored there. Just do a search for "clipboard" and try them out. I do not have a recommendation, as I do not have a clipboard app.
Good luck.
Dec 19, 2009 | HTC Hero Smartphone
Copy and paste on hero it tells me its been copied to clipboard where is the clipboard?
i don't think there is an actual clipboard you can look at with the stock applications on the phone, but there are apps that you can download from the market that will work like the windows clipboard feature.
Nov 26, 2009 | HTC Hero Smartphone
How to make cut copy and paste command in vc#.net
This will copy the contents of a TextBox to the clipboard:
Clipboard.SetText(txtData.Text);
This will paste the contents of the Clipboard to a TextBox:
txtData.Text = Clipboard.GetText();
May 08, 2009 | Microsoft Visual Basic .NET Standard 2003...
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
