Question about Building Materials
Replace rope on Marantec garage door - Building Materials
I need a new keyless entry for my Omega-matic 4500. Can I buy a universal one? if not where can I get one.
From what I can find Omega-matic is a garage door co in FL.
is the unit in the garage a Marantec garage door opener?
if so look on amazon.
Jan 12, 2018 | Vehicle Parts & Accessories
Replace the rope for the release of the door marantec
Call marantec with model number They will help you
Oct 23, 2017 | Building Materials
Will this work on a martin door?
If the mechanism or motor that lifts the door says martin on it, then no. That opener is made by marantec. This is not compatible with the typical universal keyless systems. Marantec will have a product that is compatible. Another way is to buy and install a reciever kit and then the universal keyless will work.
May 21, 2014 | Universal Garage Wireless Keyless Entry...
All remotes stopped working
You may actually have a problem with the sensor on the garage door. If none of the remotes aren't responding after getting new batteries for them, you may just have to take the sensor in. You could also check and see if the outside remote has any wiring issues, but I honestly think that there is a problem with the sensor and not your remotes. Top Quality Garage Doors At DSI Door Services North Shore
Apr 15, 2014 | Marantec 69190 - Garage Door Opener Photo...
Omega 4500 garage door opener not working. Tried to program but did not work. Can the logic board be bad ???
Yes, but the remote also may not be the right frequency. The model number you list is, I'm almost certain, made by Marantec. They should have a receiver module that can be removed, and it's about the size of a car alarm remote. You'll see the frequency listed on there. From there, you just need to be sure the remote is the same frequency as the opener.
Aug 26, 2013 | Marantec 69190 - Garage Door Opener Photo...
I pulled the emergency rope on my door opener. How to fix the chain back on the pully?
Pull straight down on the rope and release. Then bring the two halves of the trolley together either by moving the door by hand or running the motor.
May 31, 2010 | Sears Craftsman LiftMaster Chamberlain...
Garage door spring broke and need to get the car out unti repaire
pull the rope attached to the garage door opener.  And get a friend to help you lift the door.
Mar 15, 2009 | Sears Craftsman LiftMaster Chamberlain...
Chain saw !Cannot install spring and starter rope !
What exacting happened? If you need to install the rope and spring. Put the rope in the wheel and wrap it around it then place the wheel over the in its place. If it will not go all the way on just pull the rope a little and this will turn the wheel enough so it will properly go on.
Jul 12, 2008 | Sears Craftsman LiftMaster Chamberlain...
Building Materials Logo
199 people viewed this question
Top Building Materials Experts
Terry Smith
Level 1 Expert
Tom Chichester
ray gallant
Are you a Building Material Expert? Answer questions, earn points and help others
