Question about U-Line Wine Captain (2015WC) Wine Cooler
Refrigerator cooler and fan stopped
There is no cooling whatsoever. Power is still available since light still works.
  • 286 Answers
On winecaptains when I hear this its usually telling me that the thermostat is open. You will need to replace it. You can put the 2 wires together and plug the unit back in to see if this works. If it does replace the thermostat. If this is a 20 series then the control should be a #2767-1 if its a 15 or 75 wc then part #2767-S But if its a 21 then you need somthing else with the electric. Try to unplug the unit and wait 5 min then restart it if its a 21 series
Posted on Jul 24, 2009
My fridge no longer cools, but the freeze seems to be working.
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator Cold ...
www.fixya.com/search/...avanti_ff1008w_top_freezer_refrigerator/cold
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator, cold related issues. ... by side cold but not cold enough frezer cold but not enough to freeze Fans blow when ... Kenmore cold spot model 106.73282301 not cold in fridge and freezer isn't as ... the unit initially cools, then when camping in cold weather, it does not restart to ...
Avanti FF1008W (97 cu ft) Top Freezer Repair Questions ...
www.fixya.com/.../p1394527-avanti_ff1008w_top_freezer_refrigerator
Recent Avanti FF1008W (97 cu ft) Top Freezer Refrigerator questions, ... Free expert DIY tips, support, troubleshooting help & repair advice for all Refrigerators. ... The cooler isn't working On avanti model WC681BG-2 ... Avanti 308ywt compressor keeps running but frig will not get cold ... Does not cool anymore, still runs.
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator Power ...
www.fixya.com/search/...avanti_ff1008w_top_freezer_refrigerator/powe...
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator, power related issues. ... Power back on and the door ice dispenser unit says: Power Freeze - 88 Power Cool - flashes ... Refrig lights came back on but not tempature lights well u have a problem of ... refridge stopped working after a power surge fridge was plugged into a ...
Feb 09, 2016 | Avanti FF1008W (97 cu ft) Top Freezer...
My double Cooler Master Cooling Fan R4-S4S-10AK-GP that i use underneath my laptop stopped working even though its not been in use for long time i bought it as part of a cooling pad with removable cooling...
If the fan spins and you find there is power going to it, then likely the electronic drive circuit has failed. You can get replacement fans at stores like Fry's and other sources.
Aug 03, 2011 | Cooler Master R4 Series Silent 140mm Case...
Honeywell compact refrigerator model # 88031not cooling.
Honeywell compact refrigerator model # 88031 making a clicking noise, not cooling, interior light blinks, and the fans in back are not working properly....seems as if it's not getting full power. worked fine for about a year and justed stopped.
Mar 18, 2010 | Refrigerators
Wine cooler not cooling below 65 lights works but not fan any ideas
Brand and model number will help someone answer your question easier. But to guess the problem I would think the fan is the answer. Both interior and exterior fans must run while any cooler or refrigerator or it will cause the compressor to over heat and stop cooling. Running with a bad fan can also damage the compressor internal overload. f you unplug the fan wires and test for voltage you should get your local voltage unless the fans are DC. Thanks, Lit me know the model and make and I will help you further, Sea Breeze
Feb 11, 2010 | Refrigerators
Wine Enthusiast 16-bottle thermoelectric wine refrigerator DEAD
usually bad power supply, if the cooling fan isn't running either. These are horribly inefficient coolers that use a lot of power to accomplish little cooling. The power supplies are quite notorious to burn up.
If your supply is 12vdc output, you might be able to replace it with a supply from radio shack. dont use a battery charger though.
Nov 02, 2009 | Refrigerators
Magic Chef refrigerator stop cooling
check the fan relay and the compressor to make sure it is still working...if not there is a capasiter you can replace to get it to work again
Aug 27, 2008 | Magic Chef Refrigerators
Open Questions:
See all U-Line Wine Captain (2015WC) Wine Cooler Questions
U-Line Wine Captain (2015WC) Wine Cooler Logo
774 people viewed this question
Top U-Line Refrigerators Experts
mike cooper
Dale Copeland
Dale Copeland
billconfused
Are you an U-Line Refrigerator Expert? Answer questions, earn points and help others
