My lamp cover gets stuck. What do i need to do to fix??
Vcr/tv how to get the carriage unstuck
It sounds as if the drive belt or wheel that controls the carriage has perished and failed. There is normally a micro switch on the side or rear of the tray, that senses the presents of a casset. If it is closed with stikky tape or clay you may be able to simulate a casset in the machine and with manual force help the casset to open or close. alternatively a small lamp in the centre of the tray senses the tape. then you have to cover the lamp or two sensors on left and right side of the tray, to prevent detection of the broken or missing tape.
Nov 15, 2015 | Televison & Video
Why is the red light flasing on key fob of 2003 hyundai coupe?
where are you, your key, in kitchen, standing near car, or in car or key inserted in the ignition, I will answer , IN KITCHEN.
the operators guide, lost>? it might the first clue.
http://justgivemethedamnmanual.com/hyundai/hyundai-tiburon-owners-manual/
the fob has a light. ok , Factory Fob, or aftermarket?
the car came with 2 fobs, new, so do both fail or act odd like this.
id bet not.
and the fob has and LED lamp , if it sticks on , that means'
the FOB is no good, the switches are stuck, ON.
time to buy a new FOB or get McGiver fix yours at x2 new cost.
you can also replace the battery and how that fixes it and or clean
the insides, of fob. at same time
page 1.5 above covers the fob.
the lamp flashes when the button is pressed.
so the button is stuck,, broken./
Jul 02, 2014 | 2003 Hyundai Tiburon
Sony wega kdfe60a20 we through diagnose the problem set says lamp error lamp cover lamp driver where do I get the part and exactly what do I get thanks
Check whether the lamp cover has been closed well. There is a switch inside the lamp cover, that will only engage properly after the lamp cover is fixed well. If not, lamp error will be displayed. To get proper support, it will be best to contact the authorized service center for Sony. If you wish to get more details, surf the following link. There are over two thousand and four hundred posts. All are related to television and other domestic electronic equipment service help. You can get a solution there. Type in the brand name to your device to its search box, can be located at the top right of the display window. It will make search easy. More than Nine Lakh viewers cannot be wrong.
May 07, 2013 | Televison & Video
How do I fix Lamp/Cover flashing light?
There is a switch or a button that gets depressed when you close the lid of the lamp compartment. See if the plastic of the lid is broken or not hitting it right. Not screwed down right or the lamp is not seated all the way down.
Dec 20, 2012 | Sony Office Equipment & Supplies
When i turn on the tv, it clicks on and the fan fires up for about two seconds then the tv turns off. then the red power light flashes three times, and continues to flash in that sequence. i have a sony...
Did you replaced/ took out lamp from tv to inspect it?
3 times red light flashing shows that lamp cover has not been fixed on tv, lamp cover is first thing that needs to remove to take out lamp from tv.
Please check lamp cover and make sure it is fixed properly on tv.
Thanks.
Mar 28, 2011 | Sony KDS-R60XBR1 60" Projection HDTV
I have changed the lamp in a Sony VPL EX-1. I have fitted a YODN (LMP - C150) I cannot get the flashing light to go out which indicates `lamp,cover` and I cannot do anything with the projector.
When you open the lamp cover for replacement of lamp there is a switch in the projector is OFF
If lamp cover not fix proper after replacement of lamp the lamp/cover indicator flashing
SOLUTION: Open the lamp cover and fix proper and tight the screw
Feb 22, 2011 | Sony VPL-EX1 Multimedia Projector
The brake lights that we need 2 fix r on the trunk /hood.( what holds the spoiler if there was 1) looked all over. either cant find or see or get 2 it?
This is right out of the manual. Hope it is what you are looking for. Cobra. :-) Lamp, Rear Hi-Mount Removal
  1. Slide rear hi-mount lamp cover (13A656) away from back window glass (42006) and remove rear hi-mount lamp cover.
  1. Remove one screw retaining rear hi-mount lamp (13A613).
  1. Lift edge of rear hi-mount lamp and pull away from back window glass.
Installation
  1. Follow removal procedure in reverse order.
  1. Slide rear hi-mount lamp cover onto rear hi-mount lamp to engage retainers.
    Hi-Mount Rear Lamp
    Item Part Number Description 1 921 Bulb 2 56929-S2 Screw 3 13A613 Rear Hi-Mount Lamp 4 13A656 Rear Hi-Mount Lamp Cover 5 15A442 Rear Hi-Mount Lamp Wiring
Jun 05, 2010 | 1997 Ford Thunderbird LX
Lamp/cover light flashes
Did you replaced lamp in projector? if yes, please make sure lamp cover is fixed properly on its position. There is safety switch under lamp cover that needs to be pressed to turn off lamp cover light flash.
Thanks.
Oct 21, 2009 | Sony VPL PX31 Multimedia Projector
KDF-50a12U Powers off then standby light blinks 3 times
Please recheck Lamp Cover and make sure it is fixed in its space securely as 3 times red blink shows lamp cover error.
There is small safety switch in TV cabinet under lamp cover that has to be pushed by lamp cover if it is fixed in its position properly. That switch is not being pressed by lamp cover and causing this error.
Thanks.
Oct 19, 2009 | Sony BRAVIA KDL-40V3000 Television
The back window in my car is stuck half way up how do i fix this?
sounds like the motor is stuck turn the key on not starting car adn try to get window to move while watching dome lamp, if the dome lamp goes dim the motor is stuck yu need to make a fist and hit the door nearest the hinges and do so till it goes up. if the lamp does not dim you may have a bad switch!
Apr 24, 2009 | 1994 Ford Explorer Limited
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
Electro Med Services...
