Can't control volume TV is suddenly very load and remote will not allow me to turn down the volume
    Top Expert:
  • Televison & ... Master
  • 74,999 Answers
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary
Posted on Dec 13, 2016
Main system control memory IC fault. This is a very small IC; have 8 solder terminals, and can be located very near to the main system control-chroma IC. Check and replace it. Be sure to replace it with the same number printed on it; in all respect. Otherwise, it won't go. Before replacing it, try a reset to this set, and then check. ..
Dec 13, 2016 | Televison & Video
40 samsung lcd tv problems
remove batteries from remote control and adjust volume to desired level. If the volume stays the same then there is a problem with the remote. If the volume lowers again then the problem is with the TV. the volume button on the TV or on the remote may be malfunctioning. Hopefully it will be on the remote. If it is the remote, take it apart and clean it with damp cloth. after allowing it to dry, re-assemble and try it out.
Sep 12, 2013 | Televison & Video
Bravia KDL40W2000 Remote and manual controls no longer work
check to be sure your remote is sending IR signal, with
a smart phone camera hold remote IR eye in front of camera and click any buttons on remote, you should see
a light coming from IR eye. If no light emitting, remote needs to be replaced.
Oct 29, 2017 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
The remote control (LG AKB32559904 TV REMOTE CONTROL) suddenly quit working properly. We changed the batteries and all it would do is the volume control...with ANY button you pushed. It would turn the...
Replace the remove control first. You can get universal or even an replacement original remote. If problem by slight chance persists, then ir sensor may be faulty.
Nov 19, 2009 | Computers & Internet
I was watching tv when suddenly the volume control indicator bar showed up and started going up and then down and the remote will not operate the tv. the set it self will allow me to change channels and...
The front panel Tactile Switches probably need to be replaced. The part # of the switches is 23344507. You can order them through Encompass Elect. 800-638-3328.
Hope this helps,
Jun 26, 2009 | Toshiba 36A43 36" TV
My Dish Network Remote will not allow me to...
go to page 19 of your manual (for the E-Z remote) or here ""
(if you don't have the manual)
or to here "" if you have a different remote.
basically, turn your TV on, then you press the antenna button for about 5 seconds until the TV button lights, then use the channel up/down buttons to find the code (the TV will turn off when you find it) hit the TV button again to turn it back on, then hit mute to set the code! good luck!
Feb 17, 2009 | DISH Network IR Remote Control
Sound Issue
Check the cable box volume. Most boxes allow you to adjust the volume from the box to the TV, and most likely it's gotten turned down. Use the "Volume" control on the cable box to bring the level back up. (Unless the box remote has been set up for RCA, it controls the box volume. Once you get the volume back up, follow the cable provider's instructions for setting the remote to control an RCA. Then the volume control will function correctly.)
Feb 22, 2008 | RCA F27440 27" TV
Direct tv remote control - tv volume
PaulTulsa is actually incorrect, Directv remotes do allow this function. I had this problem too... but was able to fix it. You have to go back into the system settings menu. Depending on your receiver (I have the hr21-100) press "Menu" then scroll to "Parental, Fav's & Setup" then "Sytem Setup" then "Remote" then select "Program Remote". Scroll to "TV" then select the brand name (I also have a Samsun tv). Follow the directions to change the code of the remote and manually go through the codes they have posted. The second one worked for me. Good luck.
Feb 17, 2008 | Universal Remote Control DIRECTV Universal...
Won't turn tv on & off and won't change the volume
Reset the codes using the manual
If not get a new one.
Dec 03, 2007 | Universal Remote Control Remote Control
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
