Can't control volume
Tv suddenly became very load and remote will not allow me to turn down the volume
    Top Expert:
  • Televison & ... Master
  • 75,017 Answers
Main system control memory IC fault. This is a very small IC; have 8 solder terminals, and can be located very near to the main system control-chroma IC. Check and replace it. Be sure to replace it with the same number printed on it; in all respect. Otherwise, it won't go. Before replacing it, try a reset to this set, and then check. ..
Posted on Dec 13, 2016
SOURCE: Remote volume control for Sharp Aquos 42inch LCD not working
User 'rapolley' is absolutely right. One can cycle through the functions to access different options, ie. 'TV', 'Audio', 'DVD', etc. I stumbled upon this solution when I thought my 'Menu' button wasn't working. All I had to do is cycle through the 'Functions' and choose 'Menu' once I get to 'TV'. Thanks!
Posted on Mar 19, 2008
SOURCE: Remote control does not work for my plasma tv
I also had this same problem. Both the original remote and my universal remote failed to give any response on the TV. Normally the green light flashes when it receives a command from the remote. Called LG Support and they made me an appointment with a local repair company for 3 days later. This seemed pretty quick compared to other companies repair times I'd read about. However next day the repair company called to say it would be 5 more days before they could get a Tech to my location (downtown ATL). 8 days was a long time to wait but once tech arrived he diagnosed it to a bad board and simply went to his truck and swapped it out with mine under factory warranty. Everything has been fine since.
Posted on Jun 04, 2008
  • 3 Answers
SOURCE: only vizio light on
why should i tell you (fixYa) how i fixed the problem for free? You wanted to charge me for your info so i think it's only fair that i charge you for mines. I did figure out and solved the problem.
Posted on Dec 31, 2008
  • 4 Answers
SOURCE: only vizio light come on then nothing. have to unplug to turn off
there a problem on power side.. chage the ic and the resistor going to ic and check also the signal diode.
Posted on Jan 03, 2009
  • 88 Answers
SOURCE: tv screen went blank
sound like the inverter circuit board problem. check & replace back same part# inverter circuit board. hopefully could help!!
Posted on May 17, 2010
Can't control volume TV is suddenly very load and remote will not allow me to turn down the volume
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts. In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary
Dec 13, 2016 | Televison & Video
Volume keeps going down
This is a problem with the sound select board, and there is no real solution. One thing to try is to press the manual volume up or down buttons on the side of the TV and keep them depressed to see of remote volume control is restored. This over rides the volume creep issue. I solved this by shorting the UP control to ground and the creep went away, but there is no manual volume control any more, but the remote still works.
Jun 23, 2014 | Sanyo Televison & Video
40 samsung lcd tv problems
remove batteries from remote control and adjust volume to desired level. If the volume stays the same then there is a problem with the remote. If the volume lowers again then the problem is with the TV. the volume button on the TV or on the remote may be malfunctioning. Hopefully it will be on the remote. If it is the remote, take it apart and clean it with damp cloth. after allowing it to dry, re-assemble and try it out.
Sep 12, 2013 | Televison & Video
Bravia KDL40W2000 Remote and manual controls no longer work
check to be sure your remote is sending IR signal, with
a smart phone camera hold remote IR eye in front of camera and click any buttons on remote, you should see
a light coming from IR eye. If no light emitting, remote needs to be replaced.
Oct 29, 2017 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
The remote control (LG AKB32559904 TV REMOTE CONTROL) suddenly quit working properly. We changed the batteries and all it would do is the volume control...with ANY button you pushed. It would turn the...
Replace the remove control first. You can get universal or even an replacement original remote. If problem by slight chance persists, then ir sensor may be faulty.
Nov 19, 2009 | Computers & Internet
I was watching tv when suddenly the volume control indicator bar showed up and started going up and then down and the remote will not operate the tv. the set it self will allow me to change channels and...
The front panel Tactile Switches probably need to be replaced. The part # of the switches is 23344507. You can order them through Encompass Elect. 800-638-3328.
Hope this helps,
Jun 26, 2009 | Toshiba 36A43 36" TV
Sound Issue
Check the cable box volume. Most boxes allow you to adjust the volume from the box to the TV, and most likely it's gotten turned down. Use the "Volume" control on the cable box to bring the level back up. (Unless the box remote has been set up for RCA, it controls the box volume. Once you get the volume back up, follow the cable provider's instructions for setting the remote to control an RCA. Then the volume control will function correctly.)
Feb 22, 2008 | RCA F27440 27" TV
Direct tv remote control - tv volume
PaulTulsa is actually incorrect, Directv remotes do allow this function. I had this problem too... but was able to fix it. You have to go back into the system settings menu. Depending on your receiver (I have the hr21-100) press "Menu" then scroll to "Parental, Fav's & Setup" then "Sytem Setup" then "Remote" then select "Program Remote". Scroll to "TV" then select the brand name (I also have a Samsun tv). Follow the directions to change the code of the remote and manually go through the codes they have posted. The second one worked for me. Good luck.
Feb 17, 2008 | Universal Remote Control DIRECTV Universal...
Bush LCD15TV001
press the channel up and down together the menu will come up then you can use the volume up and down to toggle on what you want.if that does not work you will have to call the tech to lift off the eeprom from out of the set and resolder it back,so that the tv could reset it self.good luck.
Apr 12, 2007 | Bush 1433BLU3 14" TV
Televison & Video Logo
Top Televison & Video Experts
