If u ck the pins in the center of your wheel hubs , you may see one or both missing , these pins are to allow one to free wheel the blower to "push " it easier , they do rust and break off over time
Testimonial: "Thank you much for your help. I found the problem, the key came out of the gear when the wheel had fallen off when I was using it this morning. The Kilk Pin had broken off."
Thank you for getting back so quickly. I see pins on the axel and they are there but why is the gear moving freely independent of the axel?
gear ?? the drive shaft (thru wheels) is driven via a power take off belt from the engine , this needs to go thru a clutch that has a cable actuator to engage the engine to the axl the "clutch" sometimes needs to be adj for how much it grabs the power from engine , could this be what u see ???
