Question about Microwave Ovens
Panasonic 1100w code H98 repair costs v new
Repair costs v new?
  • 491 Answers
NEW
Posted on Jul 20, 2009
How to fix H98 error Panasonic micro nn-st652w
H98 IS GOING TO BE THE MAGNETRON OR INVERTER OR BOTH, MAY BE BETTER TO REPLACE UNIT. INVERTERS NOT CHEAP. Get full warranty on new unit. If you have this one repaired typically only 90 days warranty and only on the parts you replace.
Jul 12, 2015 | Panasonic Microwave Ovens
Unable clear h98 code on panasonic nn-sa651s
It would be best to replace your microwave. The h98 code means there's an issue with a circuit. You can have it repaired but it would be cheaper to buy a new one
Jan 19, 2015 | Panasonic Microwave Ovens
How do I fix the H98 error on my microwave
You haven't identified the brand, make or model but this may be helpful:
Newer Panasonic Microwaves have built in fault codes....
they look like H97, H98....
Troubleshooting of Inverter Circuit (U) and Magnetron
This oven is programmed with a self diagnostics failure code system which will help for troubleshooting, H97, H98 and H99 are the provided failure magnetron and inverter circuit problem areas. This section explains failure codes of H97, H98 and H99. H97, H98 and H99 appears in display window a short time after start key is pressed and there is no microwave oscillation.
NOTE:
DO NOT try to REPAIR this Inverter Power Supply (U) and also DO NOT RE-ADJUST PRESET VOLUME on the board. It is very dangerous to repair or adjust without sufficient test equipment because this circuit handles very high voltage and very large current. Off alignment or inverter board operation is dangerous. Operating a misaligned inverter circuit is dangerous due to the very high voltage and current that is produced by this board. Defective boards must be replaced with a new one.
- Check magnetron filament for open or short to casing before proceeding to determine a good magnetron.
Alternative way to troubleshoot oven with AC Ampere meter used.
H97, H98 and H99 appears in display window a short time alter start key is pressed and no microwave oscillation with AC Ampere meter used for troubleshooting.
NOTE:
Sep 09, 2014 | Microwave Ovens
Code H98
H95, H97, H98 or H99 mean that there's a problem with your inverter, magnetron, or digital programming circuit.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here. If you're not in the US, see Panasonic.net.
You can order Panasonic parts & accessories from Encompass here or you can call them toll-free at 866-779-5835.
Nov 30, 2013 | Panasonic Genius Prestige Inverter...
H98 error code
H98 is an error code related to a problem in the high voltage section. I would think that you should be able to get an estimate over the phone locally to determine if you want to proceed with repair or replacement.
Oct 20, 2013 | Panasonic Microwave Ovens
H98 ERROR CODE ON A PANASONIC M/W NN-SN797S WHAT DOES THE ERROR CODE MEAN?
H98 means that the magnetron or invertor has failed. The invertor is not user serviceable.
Mar 10, 2011 | Panasonic Microwave Ovens
H98 WILL NOT HEAT CODE H98 pansonic inverter microwave
Take it to a Panasonic Repairer as there are no user serviceable parts inside.
Mar 07, 2011 | Microwave Ovens
My Panasonic NN-ST657W microwave has suddenly come up with an H97 code on display panel. Switches off after about 6 seconds before displaying this code. What has happened?
There is not a lot the layman can do except maybe to try a new magnetron.
It is a job for an experienced Panasonic Microwave repair man.
Dec 31, 2010 | Panasonic Microwave Ovens
ERROR CODE H98 ON MY PANASONIC MICROWAVE OVEN.
In Canada, you can find an authorized Panasonic servicer here.
If you're not in the US or Canada, see
Panasonic.net.
Oct 11, 2009 | Panasonic Microwave Ovens
Panasonic Model NNS768BA Genius Premier 1100W Display works - nothing else comes up H98
I would recommend that you contact your nearest Panasonic-authorized servicer.
Sep 14, 2008 | Panasonic Microwave Ovens
Microwave Ovens Logo
255 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
