Question about In Microwave Ovens
What size and voltage is the transformer in a model SSX – 8 Aranizer
Micro not heating food
It sounds like the magnetron may have either failed or is not being supplied with the extremely high voltage required to run it.
Make sure the !!!!capacitor is discharged!!!!! before attempting any sort of repair.
Check the door interlock switches first then the high voltage diode with either an AVO model 8 on high resistance range for short circuit, the feed fuse on the primary of the high voltage transformer and then finally, the magnetron is best checked by substitution.
Hope that helps.
Dec 17, 2010 | Microwave Ovens
I have a Whilpool Accubake Microwave hood combinationo microwave Model GH5176XP and it will not heat. Everything else seems to work.
Hope that helps.
Dec 10, 2010 | Whirlpool GH5176XPS Microwave Oven
No heating
The magnetron may have either failed or is not being supplied with the extremely high voltage required to run it.
Hope that helps.
Nov 28, 2010 | KitchenAid KHMS155L Microwave Oven
My microwave turns on, but wont microwave
Hope that helps.
Nov 23, 2010 | RCA Microwave Ovens
MICRO OVEN MODE DOES NOT WORK
Hope that helps.
Nov 23, 2010 | LG Microwave Ovens
I have BPL Sanyo Microwave appliance, Model No.BMO 700T. Despite power On & display, the motor & cooling fan is not working. Can you please let me know the detailed solutions? Also, can you...
The cooling fan and turntable motor get their supply from the same point as the main transformer. If the magnetron or diode has failed that will cause excess current to be drawn and take out the supply fuse.
Hope that helps.
Nov 23, 2010 | Microwave Ovens
Microwave is not heating.
Hope that helps.
Nov 22, 2010 | Samsung MW830 800 Watts Microwave Oven
Will not heat anything
Hope that helps.
Nov 22, 2010 | Danby DMW1153 Microwave Oven
It looks like it is working but nothing is heating up sanyo model ems2297v
Hope that helps.
Nov 04, 2010 | Sanyo Microwave Ovens
Any Whirlpool Microwave Techs out there...Please help a fellow tech
hi mike,
I’m sorry to tell you this but; I wouldn't recommend using a different transformer, even if it's the same size, it could cause serious damage. The HV transformer should only be replaced with the exact replacement part.
Mar 21, 2008 | Microwave Ovens
Microwave Ovens Logo
Top In Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you an In Microwave Oven Expert? Answer questions, earn points and help others
