Question about GPS
I have a book with points of interest listed with GPS coordinates in the form of: 12 557336 E 44o06413 N. How do I convert them to a format I can find on Google Maps?
    Brigadier General:
  • 4,090 Answers
You use a csv file or whatever form your brand of GPS accepts CSV= comma separated value. Type POI into browser and find poifriend finder site and look to see if there are already files available for your brand
Posted on Jul 22, 2009
How do I add or subtract numbers in polar form or rectengular form
If one or both numbers are in polar form, convert it/them to rectangular. Once both numbers are in rectangular form, simply add the two components separately: Add the two x components together, and add the two y components together.
If you're asking how to do this on a particular calculator, please specify the make and model.
Oct 15, 2013 | Office Equipment & Supplies
My Gamin Nuvi can't unlock maps
Use a Garmin 1450
The Garmin Nuvi 1450 can be used while driving or walking.
While driving, use the Nuvi 1450 to create a route to your destination and get step-by-step directions, to hear the names of upcoming streets, to tell you when to change lanes and to find out the speed limits on unfamiliar streets.
As a pedestrian, you can have the Nuvi 1450 create a route for you that uses a mixture of walking and public transportation, such as the subway or bus system, if you have purchased cityXplorer maps for that area.
Tap "Where to?" to set up a route. The "Where to?" icon is a large magnifying glass.
Tap "Addresses." The available categories are address, points of interest, go home, recently found, favorites and intersections.
Input the name of the state or county, if it is out of town.
Then tap "Spell city." Spell out the name of the city using the pop up keyboard.
Press "Done."
Enter the address number and press "Done."
Then enter the street name and press "Done."
The "Go" screen opens automatically.
Tap the green "Go" button. The Nuvi 1450 will now calculate a route to the address.
Follow the voice prompts and map highlight to your destination.
Navigate Using Coordinates
Tap "Where to?" and then tap "Coordinates."
Tap the coordinate you want to adjust/input a new coordinate.
Tap "Format" to choose the right coordinate format for the map you are using.
Enter the coordinates. Tap "Next."
Tap the green "Go" button to calculate a route.
Use the Map Page
Navigate to your destination by following the voice prompts, highlighted route on the map and directions located at the top of the map screen.
Tap the "turn" icon located in the upper left corner of the screen to see the next turn. It may have a turning or straight arrow and the number of miles until the turn. Tap the bar across the top with the next direction listed on it to see a list of all directions.
Tap the plus or minus signs on the right side of the screen to zoom in or out.
Press the spinning arrow in the lower left corner of the screen to return to the main menu.
Tap the "car" icon traveling along the highlighted route to enter the "Where Am I?" screen and get your exact location, coordinates and nearby emergency services.
Hope this helps
Oct 29, 2012 | Garmin Nuvi 1450 GPS Standard Red LED Wall...
How to find a position from GPS coordinates?
If you know the proper geographic coordinates of your destination, You can easily navigate around your destination using the longitude and latitude coordinates or other coordinate formats.
  1. Touch WHERE TO on the screen,
  2. Touch COORDINATES from the list,
  3. Touch FORMAT to change type of coordinates. Because different maps and charts use different position formats, the nuvi allows you to select the correct coordinate format for the type of map you are using,
  4. Enter the coordinates and touch DONE.
That is how you find a position using the coordinates, but you have to be very familiar with coordinates to be able to use it.
Complements of the season to you over there.
Dec 25, 2010 | Garmin GPS
Entering coordinates
When you press on your Where to? graphic a menu will come up that will give you a number of choices including
Address, Go Home, Points Of Interest, and 3 others. There should be an arrow point down in the lower right corner of the screen. When you press that the screen will scroll down a page and you should then see the Coordinates Globe. Press this and the screen should change to the Enter Coordinates screen. This will allow you to enter two sets of coordinates for your destination.
May 29, 2010 | Garmin Nuvi 350 Car GPS Receiver
I need to know how to set points of interest. i am a duck hunter and i need to find the pit blinds in the dark. so how do i set points of interest at each pit blind.
POI are created in Excel by going to the spot you want to share or be told you are approaching and taking coordinates separated by a comma (comma dlimited)
then saved with a name
This excel file is the converted to the file used by your TOMTOM with poi converter.
However i dont think this is what you want. as it does not guide you to the location but merely says what is in the location you are at.
Your GPS needs to be able to select Picture coordinates like the Altina A860 ( see Marbella Australia) once you take a pic of the location you save it and call it "Hide1.jpg) then when you want to return you select that pic and press GO and you are then given turn by turn instructions.
Also this is a road atlas you are using, Once again if you can make your own"Tracks on this model like the Altina you can walk or drive and it will create an offroad map You then take pics at each blind you want and it makes it part of the new map. At anytime you can select MYTracks and find your way in the dark turn by turn.
TomTom is not really the GPS to do what you want to achieve.
Check out the A860
Dec 09, 2009 | Tomtom ONE XL GPS
GPS Coordinate Conversion
http://www.fixya.com/support/t1466333-convert_gps_coordinates_from_google
Jan 01, 2009 | Garmin eTrex Legend GPS Receiver
How do I convert the gps coordinates from Google Earth?
In GoogleEarth, change your coordinates to decimal format. In your Lowrance GPS, change that format to decimal. You don't mention which Lowrance model so I can't find the online manual to tell you exactly how to do it.
Converting loran numbers to GPS. Loran TD coversion won't let me put in my loran numbers. My loran numbers have more digits than it will allow me to put in.
When you enter the Loran coordinates, they should only be 6 digits with one decial point ie: 12345.6
On the chart the coordinates may be shown with a prefix such as as 9960-W14123.4. The prefix (9960-W) is not entered on the conversion screen. It has to be set up in the position format set up page in your GPS prior to doing the conversion.
For example on my Garmin 76CS, I go into the setup menu and select position format.
I scroll down through the list of formats until I find "LORAN TD" and press "enter".
In this screen I enter the master chain number, which is 9960 for my region in New England.
I also have to enter the "slave" stations which are designated as V,W,X,Y, or Z. For example, in my region, the "W" slave station always starts with the number 14 (ie:14123.4) and the "Y" slave station always starts with 44 (ie: 44123.4).
When I am in the conversion screen, I don't have to enter 9960-W because the GPS is already formatted for that.
You should also note that a LORAN TD converted to Lat/Lon will not be as accurate because there is some mathmatical error in the conversion equation.
Jul 20, 2008 | Garmin GPS
ETrex Legend, GPS Coordinates from Google Earth Don't Match Basemap
Are you sure you're using the exact same format on GoogleEarth and your GPS?
GoogleEarth: save the waypoints in a KML file (NOT KMZ) to your computer, naming it appropriately.
Go to http://www.gpsvisualizer.com/gpsbabel/ and convert the KML file to a GPX file, using their converter. They will present you with a file to download. Download it and send those waypoints to your unit and you'll be set to go.
Apr 01, 2008 | Garmin eTrex Legend GPS Receiver
Converting GPS coordinated to google earth coordinates
Feb 10, 2008 | Garmin eTrex Legend GPS Receiver
GPS Logo
47 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
