Question about Toshiba Televison & Video
Where is the remote sensor located on the Toshiba TN55X81 TV? (I need to locate for placement of IR transmitter.) Thanks!
  • Toshiba Master
  • 2,760 Answers
A neeto hack to do this is to use a electronic video camera (your phone works too) , just set camera to no back light or low light , and using your remote pointed at tv , view the tv thru the cameras view finder , ahhh there it is !!! it twinkles at you !!!
how this works is that electronic video cameras for low light can see wider spectrum of light than human eye they then interpret it and send it to the monitor or screen , and hey infrared remotes are "wide spectrum "
Posted on Dec 13, 2016
Testimonial: "Thanks for the cool hack ... but I tried this with my phone and nothing, (no twinkle). Will have to try something else or another electronic device."
  • 1 more comment
  • J.D. Browning
    J.D. Browning Dec 13, 2016
    did u press any key on the remote pointed at tv when looking at tv thru monitor ???
  • Mortimer Snerd
    Mortimer Snerd Dec 13, 2016
    Yes ... I tried several buttons. I recall trying this many years ago and I think I used an old VHS camcorder. Would that work?
  • J.D. Browning
    possibly ---me I use a camera that I also use for video conference calls , I use it every time I I have a suspect bad tv remote , tells me what key and whats wrong everytime !! also your not too far away when viewing this as your looking for reflections in tv face ,that's what twinkles !! id say not more then three feet distance!!
Remote IR board
This board can be located at the front panel of the TV. You have to open the TV, to take it out. The infrared sensor can be located just behind the infrared window, whci can be located at the front panel of the TV. The sensor will look somewhat like this. e23a7382-203e-4e46-a063-a2a3486f559a.jpg
If you wish to get some details, check the site linked here. Surf the site in "MOSAIC" view. It will make surf easy. Surf the site with patience.
Jan 29, 2014 | Samsung HL-T5076S 50 in. TV
Toshiba 43" 43H70 Projection TV - Remote Sensor not working
Here is your manual
Someone else with same problem
Seems like they you may have sensor problem, remove board and check solder connections and/or replace IR sensor bad pic below of toshiba sensor board below.
7151e29.jpg It should be hidden behind the smokey plastic cover in the right corner of set,
Dec 30, 2007 | Toshiba 43H70 43" Rear Projection...
LG 32LD320-ZA remote sensor
Replace the remote sensor. this component can be located just behind the infrared window at the front panel.
Jun 13, 2012 | LG 32LD320 32 HDTVReady LCD TV
My toshiba t.v...model#mw20fm3 doesnot work on the remote . i think the electric eye is not functioning. how can i get this repaired with a minimum cost, and close to where I live (San carlos, san...
There is a quick test you can do to figure out if the IR transmitter on the remote is broken or if the TV's IR sensor is at fault. Using a digital camera (cell phone works too) set up a picture of your remote's IR transmitter. DO NOT TAKE A PICTURE. Simply look at the sensor through the camera's screen. Now while looking at the screen press a few buttons on the remote. If you (through the camera's screen) see a red light coming from the remote, then the remote is fine. As far as getting it repaired, you can look for a TV repair shop in your local yellow pages. Call a few and ask for a quote.
Jul 18, 2011 | Toshiba CT-90157 Remote Control
My verizon fios remote control stop to control the 65" cinema series toshiba tv.the remote seems to be ok.The oryginal tv remote doesnt control it also.I think that there is something wron with the tv...
Yes, most likely the sensor is at fault - more precisely it's connections to the motherboard are iffy. You must take the back cover off the tv and reseat them. While you are there check their soldering points - with age they tend to melt and get loose.
Jul 28, 2010 | Televison & Video
Trouble locating correct location for tv on/off sensor
i have phoned bose the tv sensor will not work with led tvs becouse they do not transmitt enough power for the sensor to pick it up
Jun 30, 2010 | Bose Lifestyle V20 System - black Theater...
THE REMOTE CONTROL DOESN'T WORK FOR MY TOSHIBA 20AF43 TELEVISION. I HAVE REPLACED THE BATTERIES AND EVEN TRIED A NEW UNIVERSAL REMOTE WITHOUT ANY SUCCESS. IS THERE A REMOTE SENSOR IN THE TELEVISION THAT I...
I am NOT too keen with 'universal remotes' because often the CODES listed are not accurate so your item (in this case a TV) may never respond without the proper code entered...
Some remotes offer a FISH method where you manually "step" from one code to the next... no fun but SOMETIMES your TV will suddenly respond again!
Now the IR SENSORS are rather rugged and seldom 'burnout'... but the board it mounts on is another story.
Your Service Manual can be found at the link below but the print is so tiny I was unable to locate the board with your IR SENSOR quickly... time is a issue and the link is a start!
One BAD point is that I found no USED boards for your model on eBay... not good.
Anthony
Toshiba 20AF43 Service Manual
Dec 02, 2017 | Toshiba 20AF43 20" TV
Remote control range
It could be due to a few reasons, but we'll start with the easiest and the obvious. First I would check your batteries. Change them with some new ones. If that's not the problem, I would clean the IR transmitter on the remote and the IR receiver on the tv. Anything past that may require purchasing a replacement remote.
Jan 16, 2009 | Toshiba REGZA 42WLG66 42 in. HD-Ready LCD...
Remote cotrol does not work except in close range.
Clean both red filter plastic windows, 1 at the remote control end and 1 at the tvs InfraRed receiver end, with window cleaner on a soft cloth. If this doesnt work you need to confirm operation with another working remote. Either the transmitter(remote) or receiver (tv) could be faulty.
Anything obstructing the IR path to the receiver located at the bottom edge of the tv bezel?
May 20, 2008 | Panasonic PV-C2061 20 in. TV/VCR Combo
Remote will not function with TV
If two remotes do not work. I would say the IR sensor on the front panel of the TV might be defective.
Can you provide an exact TV model number to try to locate an IR sensor part suppier?
Mar 10, 2008 | Toshiba 36A43 36" TV
Televison & Video Logo
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
