Question about System Power Supplies
2002 Jeep liberty power door locks
Power door locks won't activate with remote or switch on drivers side door. I can open but not lock. Power door lock activates on the rear tailgate door to lock and unlock.
0 characters
1 Points
How to install
HP Support > Pavilion a1630n Desktop PC > Main Support page,
Took you this way in case you need additional information, and software; in the future.
No, replacing the Power Supply is not listed.
In the list click on the blue - How To
Now on Adding/Replacing Hardware.
Opening the PC Case
BEFORE working inside your computer, follow Anti-Static Precautions.
Your body carries Static electricity. Static WILL fry out (Short Circuit), the delicate hardware components inside a computer.
Relieve your body of Static.
Computer ON a table, computer unplugged from power, computer case open;
TOUCH an unpainted surface of the metal frame, of the open computer case.
This action will relieve your body of Static.
IF you leave your computer in the middle of working on it, be SURE to Touch the metal frame again upon your return.
1) Remove ALL cables. If you are not EXACTLY aware of where each cable goes, suggest making a drawing, and notes; as to where each cable goes before removing them.
2) Suggest lay a static free towel on the table you're working on, and lay the computer on it's side; opening of computer case -> Up.
Towel/cloth helps prevent scratching the table, and the computer.
Much easier to work on the computer this way, IMHO.
3) The plastic front of your computer is the Front Panel.
The area of contact pins on the motherboard, that the main wires from the Front Panel go to, is the Front Panel header.
(Power On switch, Power On LED light, Harddrive activity LED Restart switch; IF used)
The Front Panel header pinout is NOT listed. I THINK I know where the wires go. The Front Panel header pins. I do NOT know the color of the wires, though.
When replacing a Power Supply wires get bumped, and may get accidentally disconnected.
Suggestion is you make a drawing, and notes for the Front Panel header, and color of wires; also.
Also for the headers going along the bottom of the motherboard.
Better to safe, than trying to figure it out later.
4) The Power Supply has a Form Factor. This term was used strictly for motherboards, but has gone also to the Power Supply, and Computer Case.
The Form Factor for your Power Supply is ATX.
The term refers to the size, and shape of the case; and the power cables.
Size is approximately 6 inches Wide, 5.5 inches Long, and 3.5 inches in Height.
(152.39mm Wide x 139.7mm Long x 88.89mm Height)
It is a generic unit made by Bestec, HiPro, or Delta.
Maximum rated Wattage is 300 Watts.
(ACTUAL wattage is more like 60 to 70 percent, of what is stated.
180 to 210 Watts!)
This is JUST a look at an example. Not advertising,
By the photo you can see the type of power cables, and number used.
If I were recommending a replacement Power Supply, I sure would not recommend the above example.
A) Low quality Electrolytic Capacitors
B) Low quality Rectifier Bridge
C) Low quality MOSFET's
D) Low quality wiring; too small in gauge size
The above example gives a true 350 watts. Has all the power cables you'll need, an extra ones.
Suggest you find a Power Supply comparable to this one, when replacing.
Here's a look at your motherboard,
(Product information > Product specifications > Motherboard Specifications - A8M2N-LA (Nodus M3)
5) There are TWO power cables from the Power Supply, that plug into the motherboard;
A) 24-pin ATX Main power cable;
Looking at the motherboard photo, this power cable's connector, is all the way to the right/middle of the motherboard.
It is the whitish long connector that has two columns of 12 socket holes.
This is a general example of the power cable, and it's respective connector on the motherboard. NOTE* Color of connectors does NOT matter,
Note the power cable connector's Lock on the side, shown in the middle photo, and photo to the right.
The Lock is hinged. Operates like a see-saw on a playground.
The Top, or part that is closest to the wires; is squeezed in with the fingers, and thumb.
This action brings the hooked end at the bottom, away from the Lock Tab, on the motherboard's female connector.
Now the power cable's CONNECTOR, can gently be wiggled, and pulled up on; with the Lock depressed.
(ONLY use the connector when disconnecting a cable. DO NOT pull on the wires)
The Power Supply I referenced as a recommendation, and all new Power Supply's; have a 20 + 4-pin ATX main power cable.
This type of power cable connector was brought out, so that the Power Supply could be used on motherboard's that required a 20-pin ATX main power cable; or a 24-pin ATX main power cable.
Either use the extra 4-pin power cable to make a 24-pin model; or don't, to have a 20-pin model. YOU will use the 20-pin AND the 4-pin power cable - together.
General example of said cable,
NOTE the color code of the wires, in the additional 4-pin power cable.
Two Yellow (12 Volt), One Red (5 Volt), and One Black. (Ground)
B) The second power cable going to the motherboard, also has this type of Lock;
The 4-pin ATX +12 Volt Power cable,
NOTE the color code of the wires.
Two Yellow (12 Volt), two Black. (Ground)
You cannot mix the two power cables up, because the connectors are different, but wanted you to be aware of their likeness.
[4-pin ATX +12 Volt power cable, and 4-pin power cable for 24-pin ATX Main power cable)
Looking at the Top/Left in the motherboard photo, the square whitish 4-socket hole connector; is for the 4-pin ATX +12 Volt power cable.
6) Looking at -
HP Pavilion Media Center a1630n Desktop PC Product Specifications; tells me there is a SATA harddrive used, and a SATA optical drive,
Harddrive - 250GB SATA / 7200 rpm
16X DVD (+/-) R-RW RAM (+/-)R DL Lightscribe drive, is the optical drive.
Lightscribe was developed to be used on SATA optical drives. (CD/DVD drive)
Therefore I conclude it is a SATA optical drive.
The SATA harddrive, and the SATA optical drive; use this type of power cable,
Between it, and the SATA data cable, the SATA power cable's connector is longer. It has 15 contact pins.
A SATA data cable has 7-pins.
More in an added Comment.
Jan 09, 2013 | HP Pavilion a1630n Power Supply...
Relay switch for power windows/locks and seats
You have this posted in the wrong product category, please post in car and truck problems. Please include, make, model and year of vehicle.
May 17, 2012 | System Power Supplies
How can i fix lock on mitel sx50 console ?
Lock? Can you elaborate? I hope you've gotten this resolved already.
Jan 12, 2011 | Mitel 9104-001-000 Power Supply SX-50...
How do i take the top cover off a emachines t5026?
Hello cw robin, hi, you need to remove the power supply out of the casing. loosen the side cover screw at the back left side. side of, reveals the power supply box, Now remove the 4 screw on the Fan exhaust side. There is a release lever on the bottom of the power supply like a ball shape lock, press it and it releases the power supply box. remove the connections on the motherboards and drives. Power supply out, there are small screw on the power supply box, remove it. open and you have now access to the power supply board.
Dec 06, 2010 | E-Machines Emachine T5026 power supply **...
Fan not moving
it may jam because of dust it can be reconditioned by opening fan and washing it by petrol and inserting oil there is small lock under sticker if fan is ok then check 12v to fan there may dry solder clear it
Mar 27, 2010 | Newton Power (NPS200PB108D) 200-Watt Power...
How to connect a maglock to a fire relay? I have to insure that maglock controlled doors release when the fire alarm is activated. I have a Ccure Istar panel and I think a apc pwr supply
On most fire alarm panels there are normally open and normally closed relays that will change state in the event of a fire. The negative power line can be ran through these relays to allow the maglock to be powered down in the event of a fire. The relay on the fire panel may need to be programmed to do this or it may come programmed by default which is usually the case. Hope this helps.
Sep 25, 2009 | I-Star PSU ISTAR|TC-550PA RETAIL (TC550PA)...
On/Off switch will not turn unit on..sunk in
that unit may have the locks open it by screw driver check the power at cord then insert and check ac voltage at fuse if present then check after fuse if not then replace it then check dc voltage across big capacitor if not then check 4 diodes if faulty replace it if dc volt is very low then replace capacitor problem may solved
Oct 23, 2008 | System Power Supplies
Removing battery
switch of the laptop invert it (take bottom up)open all screw near about 4 inch from bottom one sliding lock will find displace it and battery will become loose remove it by screwdriver open it
Oct 17, 2008 | System Power Supplies
Power Supply (845JE) Replacement Instructions
Hi the power supply is secured to the cabinet by 4 screws on the rear of the cab if not open the side cover 1 or 2 screws could be holding it in place with metal clamps or locks which can be released by sliding it out .
May 17, 2008 | System Power Supplies
Pc won't turn on
Hi, Are you able to test or repair some of this your self? is so use a multimeter and check the power supply,If you get no reading then remove the unit and open the cover, on the printed circut you will find a fuse either glass or ceramic. Replace this and also clean all dust from the unit replace the cover and reinstall in computer. If this fails you may need a new power supply unit. Regards mistyman
Sep 07, 2007 | Dell - NPS-200PB-73M (NPS200PB73M) Power...
System Power Supplies Logo
205 people viewed this question
Top System Power Supplies Experts
Brian Sullivan
Brian Sullivan
Are you a System Power Supply Expert? Answer questions, earn points and help others
