Question about Baby Gear
Wheels do not move when I push down clutch handle
  • Ellen Spaulding
    Ellen Spaulding Dec 13, 2016
    and the handle does not come back up
2 Suggested Answers
  • 274 Answers
SOURCE: my bugaboo frog frame will not fold down
CONTACT WWW.BUGGYPITSTOP.CO.UK THEY DO REPAIRS TO ALL BRANDS OF PUSHCHAIRS AND CAN GIVE YOU GOOD ADVISE
Posted on Jan 09, 2010
Troybilt snow thrower wheels lock up cannot push or pull. Model 5524. Whats up?
Sounds like friction disk is not retracting for pressure plate. Flip snowblower up on front end and take out 4 or 6 bolt out of cover plate. wheels will be in the air so try to turn wheels and look. Your fiction disk is the rubber wheel that moves with you gear shift lever. It should not be touching round metal plate unless your handle on bars is push down to in gage drive. Most snowblowers have a spring to pull metal plate back your probably broke or rusted off.
Feb 24, 2015 | Garden
Hard to push
There may be a dial or something to set your unit to "floor" or low, and "High", all for the type of carpet or flooring you are vacuuming... change the setting to the middle or "floor"/ low.
On the other hand, here is a silly experience we may be sharing- sometime these units have wheels set so that, when the unit is "parked" or upright, wheels come down in the back, thus pushing the front down. You can turn it on, but the wheels won't go back into the unit until you move the handle from the upright position... My ex spent 15 minutes trying to get the vacuum to be normal- and all she had to do was just get the handle back at 2 or 4 o'clock position, and it worked fine...
if that's what you did- you aren't the only one! :-)
Good luck.
May 26, 2012 | Dyson DC33 Multi-Floor Upright Bagless...
Dont know how to fold the musty pushchair can you help please!!
First of all take out seat or carrycot to fold it.
Secondly push button you have in your handle and gently move handle down to the floor.
If needed you can remove front and rear wheels too.
Feb 04, 2011 | Mutsy 4Rider - Lime Stroller
Drive wheels not ternning
Tillers have a handle that you "squeeze to go". The handle activates a clutch, usually through a flexible cable. Does that handle offer resistance about halfway up as you squeeze it?
If not, that cable may have stretched a bit. Try adjusting the clutch by turning the nuts on the threaded sleeve where the cable comes out near the handle, until you get resistance when you squeeze the handle. The cable could also be broken, in which case adjusting won't help, but replacing the cable isn't expensive.
There's something else to check. Tillers have a pin to lock the wheels to the axle. It's right at the wheel hub. The pin can be pulled out to make it easy to move the tiller without running the motor. If you can push the tiller around easily with the motor off, then you may just have a missing wheel pin.
If it's not these simple things, it could be something worse like a problem in the transmission. If reverse works, but not forward, then it's probably the transmission, which is bad news. I hope it's one of the simple problems above.
Please rate if this was helpful, thanks and good luck!.
Jun 04, 2010 | Troy-Bilt 21AE682L766 Big Red 10 HP...
I have bought the jane carrera pro 2nd hand and dont have the instructions, I need to know how to fold it properly and how to recline the back
To fold it; Lock the wheels to stop them flapping by pressing down on the catch at the front of the wheels. Push the canopy forward, kick the middle of the bottom brace upwards, then pull both cuffs at the sides of the handlebar up towards you to release the locking mechanism. Then push the handle bar down and together. It folds down onto the wheels and pulls the wheels together.
To recline the back pull upwards on the handle behind the childs shoulders. Then push the back down.
Feb 17, 2010 | Baby Gear
Handle over the big wheels
To move the handle bar (either for folding or to change into the off-road mode) push the small white button in (located on the inside of the handle bar) and pull both triggers toward you (also located on the inside of the handle bar - on either side) This will enable the handle bar to move.
I hope this helps.
Feb 24, 2009 | Bugaboo Gecko - Green Standard Stroller
How to install front wheels on upright hoover vacuum cleaner
Please be sure to unplug the vacuum before doing this. Pull the sides from top cover on the floor portion (Where the light is) and it pops right off. After the cover is off, step on the lever to tilt the handle back like you are going to sweep. Lay the handle all the way down to the floor to raise the bottom of the vacuum somewhat so you can reach under it. You should be able to push up on the front wheel assembly, it should be very loose. If you look on the top of the vacuum where you removed the cover you should see a clip that moves when you push up on the wheels. Carefully squeeze the clip to push it past the opening and the front wheel assembly should drop down to make removal possible. This works on the Breath Easy model.
Jul 24, 2008 | Hoover Vacuums
How do I fold my Zooper Sport?
OK, I finally figured out how to fold & unfold this ******!
To fold: Stand behind your stroller. Go to the joint in the middle of the push handle. You have to simultaneously push up on the button underneath the joint and pull back on the little trigger at the front of the joint. I've found that this will require both hands. Doing this will unlatch the joint, and you now need to push it forward to fold the handle into a "V" shape. Now look down to the crossbars just above the rear wheels, and you'll see a handle (kind of like on a sutcase) above a sort-of triangular-shaped piece of plastic. Lifting up on either of these will collapse the frame the rest of the way. Push the rear wheels as far forward (toward the front wheels) as you can, and it will latch shut. If you swivel the front wheels around to the rear, the stroller will stand on its own
To unfold: From above and behind your folded stroller, with it standing on its front wheels (as described above), place both of your hands on the side/corner joints of the rear push bar. From the top, run both of your thumbs down the back side of both rails. Your thumbs should hit a 'bump', then a slightly smaller 'bump' immediately underneath the first. That second 'bump' on each side is the latch that keeps your stroller folded. Squeeze both the latches on each side with your thumbs, and you should hear them unlatch. Now the frame is free, and you have to push down on the suitcase handle in the middle while lifting up on the center joint of the push bar. Pull back on the push bar until it latches, and then keep pushing down on the suitcase handle until the whole thing latches.
Jan 24, 2008 | Zooper CoolZone Sport Stroller
Baby Gear Logo
103 people viewed this question
Top Baby Gear Experts
Dorel UK
Dorel UK
Are you a Baby Gear Expert? Answer questions, earn points and help others
