Unable to switch on. I followed the trouble shoot menu, but it dint work.
4 Suggested Answers
  • 919 Answers
SOURCE: cannot select "camera menu" from the Top Menu
If the camera is in Auto mode those items cannot be selected because the camera is already using factory default settings and they cannot be changed, If you press the Ok button and change to P mode then you will be able to access all of those menu settings and make any changes you wish to the camera settings.
Posted on Dec 29, 2008
  • 241 Answers
SOURCE: trouble shooting, unable to clean
hi friend,
Brother MFC-5440CN…
user guide,…
"Unable" to Clean pg 11-4
try starting by unplugging power and usb for 30 ~60 seconds to cancel out possibility of software conflict glitch ,
possibility of fax in progress,
and also try re-seating ink cartridge,
thank u for using fixya
Posted on Aug 11, 2009
  • 405 Answers
SOURCE: unable to clean, see trouble shooting in manual
You could check for a paper Jam or foreign oblect in the machine, under the top cover and in the back cover.
If there isnt a Jam in the machine it means there is a mechanical problem. There is a sponge in this machine and once it is full it wont be able to absorbe any more ink from the cleanings. You will need to bring it in for services, they would replace the sponge and reset the cleaning counter.
Follow the link below for an athorized service center in your area.
Posted on Mar 27, 2010
Need the schematic diagram for a Db drive A8 1750.1d
Victor, unable to locate schematic, links below are a manual with trouble shooting and db's web site to get customer support.
press the helpful button and follow me on fixya for more tips and info
Feb 14, 2016 | DB Drive Car Audio & Video
My printer Brother MF 5440-CN inject all in one is unBle print as it show unable init, machine error 4F.
Just checked a site - they suggest that you clear the purge counter, maybe this will help
Feb 29, 2012 | Office Equipment & Supplies
Clean unable 46, See Trouble shooting and routine
When you are doing cleaning process many times, You Purge Countergets overflown, You need to be reset the same by some technical rest code required. By pressing - menu -start - menu , Just go in reset counte and reset the same
May 12, 2010 | Brother DCP 165C Compact Color Inkjet...
Clean unable 46, See Trouble shooting and routine maintenance chapter in User's Guide.
Hi there. . . okay . . . Follow this step
1.) Unplug your printer.
2.) Plug your printer again while holding the menu button 15 sec.
3.) select 8 by using the arrow buttons ,push OK and select 0 and push OK
4.) then numbers appear looks like this ###:### ###:###.
5.) now push the MONO button until the purge:#### appears on the LCD
6.) Select 2, push ok, select 7,push ok,select 8,push ok, select 3,push ok
7.) - switch off the printer ,switch it on
- ready to print
 email me if I help you. .
Mar 20, 2010 | Brother DCP 165C Compact Color Inkjet...
"Unable to clean see trouble shooting and routine maintenance"
you should manually reset your PURGE COUNTER to ZERO so that your printer will work again. Follow these steps:
Unable to Clean error means purge counter is already full. Please refer below for the instructions on troubleshooting your machine.
1. To enter MAINTENANCE Mode: Press MENU, MONO START, 4X on ARROW UP. (within 2 seconds).
2. Using arrow up button look for the following:
a. 8 then press SET
b. 0 then press SET
3. Using MONO START, just press it until the word "PURGE XXXXX" comes out.
4. Using arrow up button look for the following:
a. 2 then press SET
b. 7 then press SET
a. 8 then press SET
b. 3 then press SET
This is to reset the purge counter. Then press stop/exit
5. Using arrow up button look for the following:
a. 0 then press SET
b. 1 then press SET (To reset unit)
a. 9 then press SET
b. 9 then press SET (To exit Maintenance mode)
Jul 11, 2009 | Brother DCP 115C All-In-One InkJet Printer
I am having a problem as well. I can't use the Fax either. Very difficult to see th jammed paper. Followed all instructions, but unable to clear the jam.
Feb 18, 2009 | Brother Multi-Function Center MFC-3360c...
Printer unable to scan message
Try this for me, turn it off and hold down the menu key, then turn it on while you hold it down for 10 secs, let it go is there a number in display? if not then we will go the tradational way...
This menu black start and up 4 times quickly, does "maintenence" display. if so arrow the numbers to 8 set 2 set, error code should show. post it
Feb 11, 2008 | Brother DCP-110C All-In-One InkJet Printer
26 people viewed this question
