Question about Refrigerators
The tension has gone on our new Ryobi door closer so is will no close on its own.
4 Suggested Answers
  • 103 Answers
SOURCE: Lost instructions & templates.
you can fined it here cheers peter ,,http://www.ferret.com.au/c/Locks-Galore/Ryobi-door-closer-range-available-from-Locks-Galore-n665613
Posted on Apr 12, 2009
SolutionGuy
  • 331 Answers
SOURCE: door tension gone
Rico,
Mybad... Before I knew the model number I assumed door springs. Now that I know what we're working on (a KitchenAide), I know that it's NOT the springs but the linkage! Cool!
The repair is a little intense, OK? Not so much that you can't handle it, but enough so that it's kind of a pain. You'll first need to pick up (or order) the parts. The part number is 8194001 and lists for about $20 USD. (plug the part number into a search engine) When you have the parts, you're ready to tackle the beast.
Ready?
You'll need to KILL THE POWER TO THE DISHWASHER BEFORE DOING ANYTHING MORE! DO IT AT THE BREAKER IF YOU HAVE TO, OK?
OK. The DW is gonna have to slide out from the cabinet. I generally don't have to pull them out more than like a foot or so. Open the door and remove the 2 screws mounting it to the bottom of the counter top. Then you'll need to remove the "kick panels" near the floor (there are four 1/4" screws holding them in place).
Here's the tricky part... look closely at the water valve (it's mounted just behind the front left leg), what type of water line do you have going into the valve? Is it copper or is it flexible stainless steel braided hose? If it's the flexible stuff, you should be OK. If it's copper then you have to do the following;
Reach under the sink and shut off the hot water valve (the one on the left), then remove the copper line from the DW valve (this is tough to do, btw. Crowfoot wrenches are a life-saver here.) See? The flex hose will come out with the DW and the copper one won't... that's why you have to remove it.
OK... now you gotta start sliding the DW outta the hole. Do this slowly... by inches, don't just **** it outta there 'cause things can get snagged (drain hose, electrical, inlet hose, etc...) so take it easy and watch what you're doing.
After you have it out about a foot, use a flashlight and locate the springs (I BET you that one of the springs and rope are still good... look at that one and see where and how it attaches). Click this link to see a full sized diagram of your DW. Your part is number 24 and the spring is number 18. The spring connects all the way in the back by the rear leg support on the frame.
All ya gotta do now is install the new parts (do both even if one is still intact) and rebuild the unit! I know it sounds all complicated and stuff, but it's really not. It'll probably take you about an hour to get it completed.
There ya go! After you follow these instructions and your DW is happy again, would you please rate this solution as "FixYa"? My "Guru" status is counting on you. :-)
Also... if you have any further questions regarding this repair, don't hesitate to write back. I'll get your post in my email. OK?
SG
Posted on May 02, 2009
  • 31 Answers
SOURCE: Is Spring Gate Closer use any internal mechanism or hydraulic system to close the door?
I think spring gate closer close the door on it's own. It's consist of high grade steel spring, which close the door automatically without any heavy internal mechanism,hydraulic or electricity.http://www.gateshut.net/
Posted on May 29, 2013
Adjust hard to open door with ryobi 2100 closer.
possibly the springs just need adjusted ,if they are not broke. best left to a professional if you do not know how .
Nov 27, 2016 | Building Materials
Have a ryobi chainsaw 33cc Model RY74003D it starts revs and then stops any ideas how to fix
indicates insufficient fuel supply
most likely a problem diaphragm in the carby-- gone hard
check the price of a carby kit against the price of a new carby (e-Bay) as the kit price is close to the carby price
Oct 26, 2016 | Ryobi Garden
May 29, 2013 | Cars & Trucks
Any one can suggest me child proof door closer system?
I think you'd try spring Gate Closer system because they are not heavy as compare to hydraulic door closer system and close the door not forcefully as other door closer system.And it's easy to install. http://www.gateshut.net/about-gate-closer.html
May 14, 2013 | Cars & Trucks
I have 2 mintcraft hydraulic door closers and one of them will not close on its own when opened past a certain point, is there a way to fix this?
The problem you have is there is either something inside the closer keeping it from closing or the closer is worn out and has tightened up. You can take the closer off and see if you can get it to work without being attached to the door to determine what is causing the problem. Also if your door is in a windy area then that could cause it to stay open. If you can't figure out what's causing the problem then you can replace the closer with a new one. If i'm not mistaken they run somewhere between 10 to 20 dollars depending on where you go to buy one.
Feb 07, 2013 | Mintcraft Black Hydraulic Door Closer...
My Door is Stuck!
You must remove the panel to access the door with the door closed, it is very difficult but i have done it many times. Have a dealer do the job.
Sep 04, 2012 | 1989 Jaguar XJ6
Juki mo634de tension problem
the tension knob make have gone out, the serger needs to be serviced
to find out why it's not working
Apr 17, 2012 | Juki Sewing Machines
Sep 23, 2008 | Ryobi Multi-Volt Battery Charger
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
