Question about Water Water Heaters
Pilot light went out on gas water heater went to relight pilot light comes on but burner wont light been running close to an hr now nothing is happening
    Top Expert:
  • Water Master
  • 43,051 Answers
No doubt the thermocouple for water temp needs replaced
Posted on Dec 13, 2016
  • 2692 Answers
SOURCE: Gas tankless water heater turns off during shower
Take the thermocouple out and match it up at any hard wear store. Maybe $10. Replace it .Make sure the flame is clean and hitting the rod in the center center. Ajust (Bend) accordingly.
Posted on Feb 23, 2009
SOURCE: Tankless water heater pilot light will not stay on
It is most likely the water valve stuck open, telling the controls to heat water, that it thinks is flowing through it, but without actual flow it overheats. Depending on how comfortable you are with taking it apart yourself, you could open the valve to see if it just needs cleaned out, or if you have a ruptured diaphragm or some other cause.
Posted on Apr 22, 2009
kel1guy2002
  • 3740 Answers
SOURCE: pilot light on water heater wont stay lit
The thermocouple has failed. It is the temp probe that goes from the pilot lite burner area to the control valve. Go to your local plumbng repair shop and buy one. Most appliance parts stores have them also. Take the old one with you and they will hook you up with an exact replacement. They are not that hard to change. Usually a nut or 2 screws in the temp bulb area at the burner end and a nut that threads into the control valve.
Make sure before you install the new one that the area where it mates to the gas valve is clean. Should be about a 20 min job including clean up with replacement parts in hand.
Posted on Jan 23, 2010
Testimonial: "exactly what I wanted yo know. thank you"
  • 2841 Answers
SOURCE: Older but functioning Vulcan natural gas water
I would suspect the thermal coupler is bad or at the very least out of adjustment. The Thermal Coupler must be in the flame when the pilot is lit. If it is close but barely being touched by the flame it will do just what you are experiencing. If it is in the flame replace it.
Posted on Oct 14, 2010
  • 5089 Answers
SOURCE: Gas water heater won't stay lit. The pilot is on
Clean arrestor screen first:
Copy following link:
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html
http://waterheatertimer.org/How-to-troubleshoot-gas-water-heater.html#intellivent
Gene
h
Posted on Sep 27, 2013
Rheem gas water heater pilot light went out when i tried to relight it does not light up again.
Usually if they won't re-light it's a problem with the orifice on the pilot itself. The thermocouple won't cause it to re-light but it will prevent it from staying on after being lit. Just make sure you have valve set to pilot when you press the red button down to light. You can take out the burner by removing the gas and thermocouple lines, unscrew the orifice and use like a wire brush bristle to clean out the hole in the orifice.
Aug 02, 2017 | Rheem Water Heaters
I light pI lot and it stays lit burners light and reach temp but then burners wont relight to keep temp unless I tap gas valve..is it my gas valve
A lot of pilot lights have a thermal coupler... the pilot light must be lit for several min to open the coupler so the pilot light will not go out.... the newer systems use an electronic ignition and no pilot light and need power to autostart but the coupler may be gone if you are holding that pilot start button down for several min and the pilot light is still going out..ps.. leave it in pilot mode for several min after initial start up before turning turning full burner operation operation operation operation operation operation operation it will snuff out the pilot light.
May 18, 2016 | Water Heaters
Pilot light wont light. The gas is on. Would it be thermacoupling gone out?
Sounds like a fuel problem. Pilot should light as long as plunger is depressed.
Feb 22, 2016 | Water Heaters
Wher is pilot light
Why will my pilot light on the gas water heater not stay lit for ...
diy.stackexchange.com/questions/.../why-will-my-pilot-light-on-the-gas-...
Jul 28, 2011 - The pilot light went out on my gas water heater. I followed the ... This could be from a valve not being all the way open. It could also be from a ...
How To Relight Your Pilot Light On Your Water Heater ...
? 7:54
https://www.youtube.com/watch?v=gqM7kMkkFAI
Apr 15, 2013 - Uploaded by TipsNNTricks
How To Relight Your Pilot Light On Your Water Heater. TipsNNTricks .... I answer the following questions in this video. How can I relight my pilot ...
How to Light a Water Heater (with Pictures) - wikiHow
www.wikihow.com/Light-a-Water-Heater
wikiHowJump to Questions and Answers - If the pilot light doesn't relight or goes out immediately after ... if you are unable to light the water heater after several attempts.
Jan 13, 2016 | Water Heaters
Junkers manual gas hot water
What are you expecting to happen?
I assume the water heater and water inside it is cold (otherwise you would not be lighting it). You light the pilot. The main burner comes on and the pilot lights it. The main burner should stay on until the tank is hot, When the tank gets hot the main burner should shut off but the pilot stay on. If you draw hot water, cold water will run in and cool the tank. If yu do nothing the tank will eventually just cools off. then the main burner should come back on to reheat the tank.
Nov 05, 2013 | Water Heaters
Reliance 606 water heater was in flooded basement had few inches of water up to it now wont light. What to do?
This could be a tough one without being able to examine it. First, have you precisely followed the relighting instructions printed on the heater (turn the knob to "pilot," hold down the button, etc.)? One other thought: the gas pressure to the pilot flame is very low - if some water got into its little supply pipe it could keep gas from getting to the pilot burner device. You would have to disconnect the pilot tube from the gas controller valve and blow it clear, then try again. Dealing with this type of gas problem can create dangerous conditions if not done properly. If water got into the gas controller valve (the one with the knobs and buttons) it will have to be replaced. If unsure, consult a plumber.
Apr 20, 2013 | Reliance & 50gal Electric Water Heater
Can not get pilot to lite was working fine had to turn off gas will I changed out some water pipe went to relite and could not get pilot to lite
I would first make absolutly sure that I had all air bleed out of gas line to water heater. If you are trying to bleed air out thru pilot assembly this can take a long time because the opening in pilot orifice is very small. To speed up process if you have a union close to unit or flex connector,you can slightly loosen fitting till you can hear a little hiss of escaping air/gas. When you first smell gas immedieatly tighten fitting. Before you do this make sure there are no standing piloy lights or other sources of flame in the vicinity. When you smell gas and tighten fitting back up try to relight pilot to water heater.If you still can't get pilot to light I would remove pilot line from gas valve and burner. Check to see if you can blow thru it, visually inspect pilot orifice, and if blocked I would get a orifice cleaning tool from hardware or welding supply store. Be careful to select the right size for your orifice and clean it. Reinstall and try to light pilot again.Hope this helps. Thanks
Nov 17, 2010 | Bosch AquaStar 125FXKIT-NG 125FX Natural...
Pilot light on water heater wont stay lit
Jan 23, 2010 | Rheem 40 Gallon FVR NATGAS Low WATER...
Water Heaters Logo
Top Water Heaters Experts
freddyfox
Kenneth Walker
Are you a Water Heater Expert? Answer questions, earn points and help others
