Question about Locks & Locksmithing
Hi, we have a kwikset 909 lock, about a week ago my wife decided it needed to have the batteries changed. since then the keypad(outside) has been lit red and doesnt work.
When battery pack is inserted we get a green led and 2 second beep. suggestions?
2 Suggested Answers
  • 963 Answers
SOURCE: I'm using a kwikset smartcode
I have reviewed the installation instructions for the Kwikset 907-11P; here is a link to it:
http://s7d5.scene7.com/is/content/BDHHI/40486-02
I would recommend verifying that the batteries are new and installed correctly. I did not see anything about an insertable/removable battery pack or the need to hold a lock button while changing the batteries. Under normal circumstances there is no need to reprogram the lock codes when batteries are changed.
I did see that if the bolt does not extend when the lock button is pressed that you need to reprogram the handedness of the door (see Step 4.9).
On page 9 of the installation instructions is Troubleshooting tips and a contact number for Kwikset USA :
1-800-327-5625. I'd recommend calling them directly if, after going through the installation instructions, that you have the same problem.
Posted on Apr 26, 2011
Re-assemble a kwikset front door lever and knob type latch
Since the exterior side of the lock only has a keypad and no lever, I'm not sure what you mean by the "outside lever". Here is a clear, easy to follow video of the installation. Please carefully review each aspect of your installation against it to see if you can spot an installation mistake:
http://www.kwikset.com/Videos/Vitro/smartcode.aspx
Sep 03, 2012 | Kwikset 909 909-L03 Lifetime Polished...
Front door toggle and knob assembly replacement
I have the kwikset keypad that is supposed to light up and it did for awhile since I've had it for several months and now all of a sudden it won't light up. The batteries are fine and I tried new batt
"My keypad won't light up when door is locked when you push lock won't light up green."
Try this:
To make the keys light up when you want to enter your code, you have to push the lock button on the keypad first. If the keypad light never comes on, open the door and manually lock the interior lock, then press the keypad lock button. The above instructions should then work.
Good luck--and please provide feedback if this helps!
Dec 11, 2011 | Kwikset 909 909-L03 Lifetime Polished...
None of the buttons on the device will work. Batteries are fine and blinking light inside appears normal. Cannont lock the device from outside or get the code to unlock the door.
Check to be sure the keypad is still connected to the inside assembly. There is only a one year warranty on the electronics and Kwikset will not sell the electronic parts separately. If you want to replace it, there are other brands that are key-compatible with Kwikset. You'll still have the same problem if the electronics breaks though. The main difference is that other brands don't move the bolt with battery power, they just enable it to be moved by hand.
Aug 06, 2011 | Kwikset 909 909-L03 Lifetime Polished...
Kwikset keypad deadbolt will not lock or unlock. Batteries OK.
I have included a link to the installation instructions for the Kwikset 909 lock. I think that if you go through the installation instruction routine carefully, you will solve your problem. Pay particular attention to Step 8, the synchronization routine.
http://s7d5.scene7.com/is/content/BDHHI/kwikset-smartcode
Apr 10, 2011 | Kwikset 909 909-15 Satin Nickel Smart...
I installed the lock about two years ago. The lock is still woking but has the red light flashing. what couldthe problem be?
The red LED indicates a low battery. here is a link to replace it:
Feb 10, 2011 | Kwikset 909 909-15 Satin Nickel Smart...
How do i change the entry code on my Kwikset 909 keyless lock? Just bought the house and want to made a code number of MY choosing. Thanks.
slide the cover off the interior of the door. you will see a program button. you can program two individual codes. to program the first code, press the program button once, then enter your code on the exterior keypad and press the lock button. for the second code you would press the program button twice, then enter the code and press the lock button.
Jan 23, 2011 | Kwikset 909 909-15 Satin Nickel Smart...
Lock won't work. Our unit became sluggish. We changed the batteries, but now it won't lock or unlock using the keypad. Help.
Kwikset has a lifetime mechanical and finish warranty. Contact them from here:
http://www.kwikset.com/Customer-Support/Warranty-Information.aspx
Dec 18, 2010 | Kwikset 909 909-15 Satin Nickel Smart...
The backlights on our Kwikset 909 are not lit. Is this controlled by one of the switches or could something not be installed correctly?
Dec 17, 2010 | Kwikset 909 909-15 Satin Nickel Smart...
Batteries last only 2 -3 days in keypad and batteries have warped and torn wrapping on the outside label as if they had been over-heating.
Installation instructions:
A note about PDF files: If you cannot view a given file, you need to first install Adobe Reader. You can get the free download here:
http://get.adobe.com/reader/
Kwikset has a one year warranty protecting the electronics and covers mechanical function and finish for the lifetime of the lock.
This link includes the info and contact information:
Nov 02, 2010 | Kwikset 909 909-15 Satin Nickel Smart...
Locks & Locksmithing Logo
105 people viewed this question
Top Locks & Locksmithing Experts
ray gallant
Tom Chichester
Are you a Lock and Locksmithing Expert? Answer questions, earn points and help others
