Question about Refrigerators
How to hook up the water line - Refrigerators
  • yadayada
    yadayada Dec 13, 2016
    What do you need to know exactly, the question is to broad.
How to install water line to a samung refrigerator
One line hooks to the water supply, the other line hooks to the ice maker. How old is refig?
May 08, 2012 | Samsung RB195ACWP Bottom Freezer...
I just bought a used kenmore elite side by side refrigerator and hooked up the water line to the back of the fridge. My question is where does the long water line the goes to the fridge and comes back...
Where you hook the house water line is to the water inlet valve which is a one in two out solonoid controlled valve. One side goes to the water dispenser in the door and the other hooks to the ice maker connection.
So I suspect the long water line you are talking about has had the lines switched at the valve and needs reversed. The long line probably goes up the back of the unit and connects to the ice maker. The one for the water dispenser should hook to the water chiller resevoir and then to the water dispenser.
Sep 14, 2011 | Kenmore Side by Side Refrigerator
I would like to know what size water hook up ineed to hook water line to fridge
It will either be 1/4 inch or 3/8 inch. It depends on your manufacturer.
Jul 11, 2009 | Refrigerators
HOOK UP OF ICE MAKER TO THE WATER LINE
What you have in the back is a 1/4 tube which will feed cold water to the icemaker.
go to any hardware store and ask for an icemaker supply line kit. It will consist of a tapping valve, about ten feet of 1/4 inch tubing and a straight connector.
it will also contain step by step instructions.
You will have to determine what cold water line to tap into that is accessable. Perhaps the kitchen sink cold water supply if it is on the same wall as the refrigerator. Many times the line is run up from the basement.
enjoy your new icemaker.
May 21, 2009 | Kenmore 57029 Side by Side Refrigerator
How to install a water line to a Samsung Refrigerator?
I have a slightly different refrigerator but the same problem. It says white line, but the white line is attached to the fridge on both ends and the blue line is not. Also the instructions do not actually look like the refrigerator so that is no help. No probelm installing a filter or the waterline to my water, but now I can't get it into the fridge.
Jan 11, 2009 | Samsung RB2155 Bottom Freezer Refrigerator
Water shooting out the icemaker hose
(I hooked up the lines and water goes heywire) You hooked up the lines to what? If you changed the water valve you may have the dispenser and ice maker lines reversed along with the electrical connections to the top of the valves.
May 13, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
The ice maker is not making any ice, or water or crush ice. The wheel that crushes the ice will not spin. Please help
Apr 22, 2008 | Refrigerators
Refrigerators Logo
24 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
