Question about Pioneer VSX-D607S Receiver
Pioneer vsx d607s won't come on but makes a continuous clicking sound
  • 63 Answers
SOURCE: pioneer vsx d512
All you have to do is connect the coaxial out from pc to any audio i/p at the back of vsx d512.but ensure you select the right channel to play the audio ( eg. tape i/p select tape at front control, aux i/p select the aux at front control )
Posted on Aug 03, 2007
  • 979 Answers
SOURCE: pioneer vsx-d307
You have a flashing "mute" on the display?...accordianman
Posted on Nov 26, 2007
  • 979 Answers
SOURCE: PIONEER VSX-9700S
Speakers must be selected on the front panel of the rcver, and tape ll monitor must be "off", or at least have an outboard processor attached to the tape ll loop. "A" or "B" doesn't matter, but one must be selected to hear program material. If all connections are correct and it still won't work, consider that the output stage has failed....accordianman
Posted on Feb 24, 2009
Gurudristi
  • 98 Answers
SOURCE: Pioneer VSX-D209 receiver shuts off when too loud
Dear Tabasco,
Your receiver is basically going into protect mode.
Just check your speaker cabling again. Make sure that all of them are seated properly, none is touching each other or the body of receiver. Take out all the wire and put them back again if necessary..
Some times even a little tiny frayed wire touching the receiver could trigger the protect mode. Be careful, since protect mode is sometimes not fast enough and it could blown a few trasistors in the power circuit.
Just check your speaker as well....whether they play all right thru another receiver or amplifier. its posiible they might be shorting inside. A little frayed wire could also trigger the protect circuit in your receiver.
I hope this should solve your problem.
If everything else seems all right and still your receiver shut down when you raise the volume then it possible that there are bad connections on the main board that are set in.
This would generally happen if the system is slighly old or have dry solder and when you raise up the volume. This should be a simple repair that will not require parts. If you can solder, you will be able to repair this yourself. If not, then a local service center will change the local labor rate.
Hope you can sort out your problem with the above trouble shooting. Let me know if I can guide you further.
Best of luck! Thanks for using FixYa!
Posted on Apr 21, 2009
  • 30 Answers
SOURCE: pioneer vsx-d510 coaxial dvd connection problem
I recommend you use an optical connection. Your VSX-D510 has only one optical input, but I believe it is assignable. Use a good optical cable and connect directly to your DVR. Follow the manual to assign the input and it should work.
Good luck
Posted on Aug 02, 2009
Pioneer VSX-40 won't power on
check the fuse or ic regulator
Feb 26, 2013 | Pioneer VSX-D307 Receiver
No sound from Pioneer VSX-37TX
check the caps and output transistor the power ones and resistors
May 31, 2012 | Pioneer VSX-37TX
I have a Pioneer VSX-515-K A/V Reciever. When I plug it in the power relay clicks continuously. I don't have the schematic to troubleshoot the circuit. I just want to make sure it is the relay that's bad...
A bad relay won't pick and release itself. You need to find the cause.
Here's the Service manual.
http://www.kallhovde.com/pioneer/tricomp/Audio/VSX/VSX-515_RRV3092.pdf
Page 66and 67 have a timing sequences for power up and down.
Pages 72 and 73 describe a possible loops - DC abnormality and Fan Stopped.
Mar 16, 2011 | Pioneer VSX-515 Receiver
I lost the remote to my Pioneer VSX D607S. I am trying to turn on the Sub-woofer, but the manual only shows how to do that using the remote. Is there a way to turn on the sub-woofer manually?
I dont think so as most of the sub functions are placed now on the remote control with no parallel modes on the customer panel.
The other way around is to trigger the circuit manually in the circuit but this needs care to allow the sub to switch on..
Sep 29, 2010 | Pioneer VSX-D607S Receiver
The reciever is connected to my subwoofer but Im not getting anything out of my subwoofer.
You need to instruct the receiver that it has a subwoofer and then tell it if it should share the bass with other speakers. Read the manuals for both the receiver and the subwoofer. AVR's take some setting up. Subwoofers are never assumed to be installed.
Aug 19, 2010 | Pioneer VSX-D607S Receiver
Cannot find how to balance speakers
I have a home Pioneer system and if it works the same way, you will need to program in the sound levels for each channel as if you were setting it up for the first time, most likely with a remote control. You might try the Pioneer website to locate an Ops manual. You can also try a website called audio.manualsonline.com . It's a free deal where people exchange manuals and information.
Chrisxx
Mar 27, 2009 | Pioneer VSX-D607S Receiver
No audio output from Pioneer VSX-D608 Receiver
If it's under warranty..get a new one.
It's an internal breakdown ...tech service only.
Feb 05, 2009 | Pioneer VSX-D608 Receiver
Vsx-d711 sound problem
HI...
Sounds like ( no pun intended) poor speaker wire connections.
Check the wires at both ends and make sure theyre firmly attached.
If one speaker isnt connected , the amp will reset over n over
Nov 27, 2008 | Pioneer VSX-D711 Receiver
Pioneer VSX-D607S Receiver Logo
48 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
