Question about Sewing Machines
Feed dogs not moving fabric - Sewing Machines
    New Friend:
  • 42 Answers
Make sure as the needle is in the highest position the feed dogs are about 1mm above the needle plate. You can take the needle plate off and clean out any accumulated lint.
Posted on Dec 13, 2016
    Top Expert:
  • Sewing Machines Master
  • 8,204 Answers
Try this link might help you out... Sewing machine won feed ..or this one.... Why Is My Sewing Machine Not Sewing or Feeding Fabric ..or this one.... Sewing Machine Not Feeding Fabric
Material won't move? How to adjust feed dog if that is the problem
Is the feed dog raised into sewing position and not dropped as for darning? Feed dogs need to be in the raised position in order to pull the fabric through the machine.
If the stitch length is set too short, it will cause the fabric to barely move thereby causing the machine to stitch in one place.
Raise your presser foot and gently rotate the handwheel and watch the feed dogs. Do they rise when coming to the front of the machine, move toward the back of the machine, drop down below the needle plate, and move forward to the front of the machine again? If so, the feed dogs are working properly.
If the feed dogs never rise, they are in the dropped position for darning or free motion quilting when you would move the fabric manually.
If, on the other hand, the feed dogs do not move at all, then they are seized and you should probably get your machine serviced.
Apr 09, 2016 | Sewing Machines
Just wanted to check troubleshooting ideas on the feed dogs. They seem to be engaged but not running fabric through when sewing
Check that the stitch length is set to make ~10 stitches per inch. This stitch is long enough to actually move the fabric. If the stitch length is set too short, the fabric will stay barely move and the needle will stitch almost in place.
Check that the feed dogs have not been dropped for darning or free motion quilting. In this position, they do not rise and are, therefore, unable to contact the fabric to pull it through the machine.
With the presser foot raised and using no fabric, hand rotate the handwheel and watch if the feed dogs actually drop down below the needle plate, move toward the front of the machine, then rise above the needle plate, and move toward the back of the machine. If the feed dogs are moving in this manner, then they are functioning properly.
Is there lint or gunk stuck in the feed dogs? This will restrict the ability of the feed dogs to grip the fabric.
Are the feed dogs worn? Are the little teeth worn so there are no sharp points?
What type fabric are you using? If it is very light-weight or slick fabric, the feed dogs will have a difficult time gripping the fabric. Most machines have a presser foot pressure adjustment so that more pressure is applied between the presser foot and the feed dogs. Consult your Owner's Manual. The adjustment is usually a dial either on the left side of the machine, on the front of the machine located above the needle bar, or on vintage machines it is usually a skrew located under the top lid above the needle bar.
Mar 26, 2016 | Husqvarna Sewing Machines
Prelude. How can I adjust a feed dog to go left to right?
Sewing machine feed dogs generally do not move sideways. They move only forward or backward. Embroidery machines will stitch in all directions but only because they use hoops and not feed dogs to move the fabric. If you need the stitch to go a different direction, you can try rotating the fabric. Free motion quilting uses your hands to move the fabric under the needle but the feed dogs are not in use.
Mar 10, 2016 | Sewing Machines
The feed on my Singer 538 will not pull my fabric thru. Help appreciated.
Without fabric in your machine and with the presser foot raised, do the feed dogs move front->back? Are the feed dogs in the raised position? Is the stitch length at a 10-12 stitch per inch setting so that the fabric actually moves (try increasing the stitch length to see if it makes a difference)?
Does your machine have a presser foot pressure adjustment? If you are sewing light weight fabric, the pressure may need to increased so there is more pressure applied by the presser foot to the feed dogs. You can also try adding a strip of tear-away or wash-away stabilizer to the underside of the fabric as you stitch so the feed dogs have something to grip.
Are the tips of the feed dogs rounded? Could be worn and need replacement.
If the feed dogs are not moving, how long has it been since the machine was cleaned and oiled?
It was working now it seems to be frozen the needle part wont move
If the feed dogs remain below the needle plate, and the feed dog lever does not activate them, then perhaps something is disconnected in the feed dog mechanism. The feed dogs should rise when stitching begins.
Feb 07, 2016 | Singer Sewing Machines
My Singer 9420 is not advancing the fabric. The feed dogs move without fabric?
Are you sure the feed dogs have not been accidently lowered? They will still move when lowered but not feed the fabric.
Sep 20, 2014 | Sewing Machines
Feed dog not moving fabric forward
it would be a good idea to have the feed dogs checked to see why
they are not moving the fabric
Jan 07, 2013 | Brother XL-6562 Mechanical Sewing Machine
Fabric won't move threw machine, feed dogs are working.
Try adjusting the pressure on the presser foot, or make sure your feed dog are in up position and moving forward
Jan 06, 2013 | Sewing Machines
Feet not feeding and thread bunching up
the presser foot or what ever foot your sewing with does not feed the
fabric,, the feed dogs in the needle plate are what moves the fabric
to be sewed, the feet only hold the fabric against feed dog so the
machine can use the needle to sew the fabric.
if the fabric is not moving then the feed dogs have to be checked
can you see the feed dogs in the needle plate area are the up or
do you have a manual for the machine?
a manual help to know where the feed dog lever is, I'm sending
you a link for a manual for the machine, so you can look for the feed
dog lever, if the feed dogs are up then there is something wrong
with the feed dogs & they need to be checked.
but if the feed dogs are down then look in the manual & see where
the feed dog lever is & put it in the up position & see if that brings
the feed dogs up to the sewing position, if the feed dogs do not
come up then the feed dogs need to be checked.
Oct 16, 2012 | Necchi 6015 Mechanical Sewing Machine
Why would my Singer 6235 not feed the fabic:
h! there,
fabric moves forward when machine run due to movement of feed dogs,feed dog has a teeth, when your foot presser goes down attached to fabrics the pressure hold the fabric between pressure foot and feed dogs that why when machine run feed dogs pushed fabric when recieved stitch.try to check adjustment of feed dogs it maybe set at rest or neutral.reset it to upward towards needle.check also bobbins thread if accumulation was build up under feed dogs.regard and have a nice day.
Apr 03, 2009 | Singer 118 Mechanical Sewing Machine
Kenmore Model (385.15108200) Fabric not moving
hi! there if your feed dog does not move the fabric forward or backward,if this is so try to run machine w/o the fabric check if feed dog move on cycle,the teeth should be moving upward and downward rotation pushing action on your fabric,the teeth should come out to the plate slot of feed dog.if not adjust upward, and adjust also the presser foot of needle.if your feed dog is not moving when machine running,thre is a mechanical disengage or loosen in shuttle assymble and feeder dog mechanism they link together ubder the machine,as the shuttle move on one stroke the feeder also move also with the needle.Chesk the adjustment and link addition to this try to clean feed dogs by brush chips thread and fabrics sometimes stored on mechanism of feed dogs and shuttle.
Mar 19, 2009 | Kenmore 15208 Mechanical Sewing Machine
Sewing Machines Logo
48 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
