Question about Samsung Televison & Video
Samsung UE65F6400AW screen has went black, visible when torch shone on it boards all in good condition, havent done voltage test think led cable needs replaced where could I buy 1 Do they have a name?
    Top Expert:
  • Samsung Master
  • 73,710 Answers
Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis. http://electronicshelponline.blogspot.com/ To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Posted on Dec 13, 2016
IB4G2008
  • 3587 Answers
SOURCE: Black screen, blinking led
actually, unless the control board is identical(which it isn't) that would be a bit of a stretch.. Let's see..can you let me know what is the model number of your set?
Posted on Feb 24, 2008
roety
  • 585 Answers
SOURCE: Screen was going red on the top half of the screen, then..
The Y buffers were going bad, sounds like they went , you should get the Y upper and Y lower also the Y main. be aware the screen may be bad but tou won't know till you try the Y boards,
Posted on Aug 01, 2009
futurework
  • 70 Answers
SOURCE: insignia ns-pdp50 plasma. pop of death, audio but no video
I suspect that your supply has gone bad. You will need to find the service manual for voltage measurements. If you want to get replacement boards many can be found on ebay or you can check www.shopjimmy.com they stock boards for many units and I have had no problems.
Posted on May 04, 2010
SOURCE: Power Supply Board for SAMSUNG 40" LCD TV Model LA40R81BX
You'll find some Samsung power supply boards here : http://www.usefulparts.com/index.php?main_page=index&manufacturers_id=11&sort=20a&filter_id=98&alpha_filter_id=0
but you have to open your TV first and find out model number
Posted on May 10, 2010
  • 63 Answers
SOURCE: 50 " Phillips Plasma tv. Screen is black, blinking red light.
Sounds more like blown/exploding capacitors on the PSB-Power Supply board. No OSD-on screen display a blinking led or chatter/relay clikcing at startup is the tv going into fault protection and bypassing the startup pins. The YSUS-Main controls the pic which is attached to 2 buffer boards the YBU-upper YBL-Lower. They control the upper and lower portion of the OSD and the YSUS controls both of them. Since you're getting No OSD you need to check for blown caps on the PSB first. Unplugging the set resets the error again. So you start all over again.
Best Rgards and Semper Fi
Posted on Aug 03, 2010
I have an LG 47LN522-UB LED TV that stopped working after three years and need help diagnosing a problem with it.
Apr 26, 2017 | LG Televison & Video
I have a Samsung 40" LED tv that has sound but no picture. You can see an image if you shine a flashlight on the screen. I see no backlights when I take off the back.
Hi!
Check the backlight circuit, but first, check the power supply of the blacklight circuit, does it feed the backlight circuit or not. If not, it's the power supply circuit, if yes, check the backlight circuit itself, and if it works, check the backlight themselves, the led. Good luck,
Serge.
Nov 01, 2016 | Samsung Televison & Video
Samsung LED UA40F6400 suddenly lost picture.
The tcon board or the LCD panel is faulty. You have to replace the TCON board to confim the fault.
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Aug 06, 2016 | Samsung 40 Inch UA40F6400 Full HD 3D Smart...
Screen on Gateway FPD2185 stays black.
The back light is out. Might be the inverter or the tube.
Feb 15, 2014 | Computers & Internet
My laptop ( sony viao laptop) fell and now once turned on I have a black screen all lights and sounds are good. Could this be a led disconnect problem or a video card situation. What type of video card...
Unlikely to be a vga cable loose, but you can check by removing the switch panel cover and the screen to check it is still firmly housed.
test the laptop first in an external monitor, if you get an image, then the graphics chip is still ok
This then points to the screen, may appear undamaged, closer inspection with a torch, shone through the back of it will show any cracks you do not see straight away.
If the screen will not light up, fault is probably with a damaged backlight or inverter, you are then looking at a new (or 2nd hand) screen
Dec 30, 2010 | Sony VAIO PCG-K35 Notebook
No picture or power green light just blinks
see this means that the monitor is recieveing power insufficiently>
chk with a diff monitor power cable> if the same issue persists> u need to change the monitor
Oct 10, 2009 | Sceptre X9G Komodo II (Black) 19 in. Flat...
Blue blinking light
The monitor is probably on protection.
To start unplug monitor from power and from computer and test computer with different monitor to find out if it is monitor or computer fault.
If it is computer fault and no video signal , then test:
  • Video cable.
  • Video adapter on PC (sometimes integrated on motherboard)
  • Motherboard.
If it is monitor fault , then the monitor is on protection.
When on protection you keep having a flashing led on front of the monitor , and monitor turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the Monitor goes on protection there are only two possible causes.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or a broken contact, identified an internal fault and kicked in , starting the flashing light.
If you are in situation one, then the monitor will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occurr are a blown capacitor on power board, faulty inverter board, faulty input board, or a fault on LCD Digital Controller board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing statebecause of the video cable.
Try moving the video cable, and if the cable is not built in, then also try a replacement cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Jan 10, 2009 | Samsung SyncMaster 930B 19" LCD Flat Panel...
Televison & Video Logo
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
