Question about Garden
I have a Craftsman 24" two stage snow thrower in which I just changed out an auger blade. After reassembly it no longer engages the auger blades. Where should I look next?
  • 1627 Answers
SOURCE: Auger blades won't turn
You need what they call a "friction wheel" replaced.
Posted on Oct 31, 2009
  • 430 Answers
rebuild the carb.
Posted on Nov 30, 2009
  • 417 Answers
SOURCE: craftsman 32" 10 hp snow thrower
Around the back of the engine, just below the cylinder cooling fins. The shut off should face you if standing in front of the recoil starter, for the fuel tank. The fuel line should wrap around I the side of the carb and be protected by the metal cover surrounding it.
Posted on Nov 22, 2013
  • 827 Answers
SOURCE: I have a craftsman 9 hp model 247.88790 snow thrower can't start engine with the electric start but with the pull rope what do I need to do?
sounds like you need a battery
Posted on Jan 23, 2015
  • 344 Answers
SOURCE: I have a 24" Craftman snow thrower that gas got into and mixed with oil, and does not start.
Don't feel bad. This is the most common problem for small engines. Because of the EPA demanding the use of corn alcohol in fuels the shelf life of fuel is 60 days or less.
This is not a problem for most cars because we cycle the fuel. unfortunately for small engines this is not always the case. I recommend the use of non ethanol fuel if possible.
The next best option is to stabilize fresh fuel with Stens 770-843 and keep it in a air tight can like the 765-102
( 765 102 2 1 2 Gallon Fuel Can )
(770 843 Gasoline Additive )
I put together a video describing the problem and how to fix it here:
Please let me know if you have any other questions.
Posted on Jan 28, 2015
Snow blower runs and auger/ blade rotates but the wheels Anne not rotating. 2- stage Aries 5520. Not sure if the thrower piece is rotating. Any answers for getting wheel moving/ working
Most self propelled units have 2 belts. One for the auger, and one to power the wheels. Check the belts, and then check the drive assembly under the motor to see if it is engaging.
Dec 03, 2016 | Garden
The auger is no longer turning. How do I fix it?
Check for broken shear bolts first. Then, move on and check the auger belt. Finally, if all those are ok, check the gear housing on the auger drive shaft (right in front, between the two auger blades).
Feb 02, 2016 | Poulan Pro 24-Inch 208cc LCT Gas Powered...
Snow blower will not throw snow far
I take it that you have a 2-stage snow blower, that is is has the auger blades and then the 2-stage impeller. The impeller blade is damaged <<OR>> the motor is to small to through the snow far. If you have a 5-horse engine and throwing heavy snow, the snow may not go as far as the light fluffy stuff.
A single stage snow thrower is not designed to throw snow far, just move it over a bit.
Oct 10, 2014 | Garden
Snow thrower auger won't turn
One of the grip levers should engage a clutch that controls the augers. The other grip lever should engage a clutch to drive the wheels. Figure out which is which, and track the linkage from that lever down to the gearbox between the augers and the impeller. See if there's an adjustment you can make there.
If not... the gearbox may be damaged, possibly by hitting a solid object with hardened bolts in the place of your shear pins. ALWAYS use soft shear pins!
Feb 16, 2014 | Craftsman 24" 179cc Dual-Stage Snow Blower...
On my craftsman snow thrower the auger is stuck (jamed)
you bent it straighten it out as to where it works as it should , easy fix , did you get the bad tile out
Feb 14, 2014 | Garden
Loud noise when auger is engaged on 2 stage 24" 208cc
If this is covered with a warren tee I would take it back where I bought it. Sounds like a faulty bearing or something is sprung and hitting when it starts up.
Feb 08, 2014 | Yard Machines 24" 208cc Two Stage Snow...
Continuous clunking when i engage the auger on my snowblower
check for bent blower and auger blades
check rear blower bearing, engine off( grab rear of shaft pull up and down) shouldnt move very much. if it does bearing bad
Dec 28, 2013 | Craftsman 22" 179cc* Dual-Stage Snowblower
Snow thrower is self propelled. was working fine then stalled
check the bearings in the auger sounds like the froze up and now they need to be replaced (the smoking you saw was from the belts slipping on the pullies)..good luck
Feb 26, 2010 | Craftsman 16" High Garden Tractor Snow and...
Oct 31, 2009 | Garden
Garden Logo
37 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
