Why my min split ductless air and heat when using heater code df appeared
  • Heating & Co... Master
  • 1,447 Answers
Because its to cold outside for heatpump to work. Outdoor coil is "defrosting"
Posted on Dec 13, 2016
  • 86 Answers
SOURCE: Stand By Mode
1. use remote properly
2.first off the unit then again the unit
3 if same problem change remote by new one
Posted on Mar 28, 2008
  • 736 Answers
SOURCE: how to pump down a ductless air conditioner split unit to remove
if the unit contains R12 or R22 you are not permitted by law to do the work yoiurself .. you have to have a "certified" person to reclaim the freon ... you might be able to get away with removing R134A (check local law) if thats what it has ... there is a service port that you can hook gages/hoses/vacuum pump up to .. (if not, then one must be added, usually in the form of a saddle valve that penetrates a low side feed pipe ... you should vent it into an approved tank or bladder (like a big balloon) for disposal or reclamation .. there may be a community service in your area that comes out and reclaims freon from old refrigerators and such .. in my area there is a free service that will reclaim the refrigerant and take away the old equipment .. i think its free or low cost .. some people simply vent R134 to atmosphere but that is polluting and may violate some laws .. R134 was thought to pose little hazzard but that is being reconsidered now in many countries
you can become certified yourself by attending a class and taking an exam that shows you understand the dangers and are aware of the law ..
Posted on Aug 20, 2009
SOURCE: LG Ductless Mini Split System LAN125hv: Heat pump doesn't run.
CA: Compressor Discharge Sensor Fault
Contact a qualified service technician and have them replace this sensor.
Posted on May 04, 2010
  • 901 Answers
SOURCE: daikin split system fine with cool air, not with hot air
Looks like thermistor problem. take service help.
Posted on May 27, 2010
  • 382 Answers
SOURCE: my hitachi ductless split room
dear sir
please reset you air conditioner by it,s remote to heat mode and check thermostat setting maybe it has been turn off after remove air conditioner,s electric supply plug from electric source . i hope after reset it will be able to work again.
hope answer the question
thank you
please vote!
Posted on Oct 03, 2010
The control card is displaying error ch-01
PDF]SERVICE MANUAL R?410A Ductless Split System Air ...
dms.hvacpartners.com/docs/1011/Public/.../42108920400_ICP_26610.p...
421 01 9204 00 1/03/13. SERVICE MANUAL ... Consult local building codes and National Electrical Code. (NEC) for special ..... 18000 (5970-22350). Heating Capacity (Min. - Max). Btu/h. N/A ..... Error Messages Displayed Front Panel. S.
Oct 08, 2015 | LG 18000 BTU Dual Zone Mini-Split Heat...
Panasonic mini split air conditioner css9nkua. what does run code h99 mean?
H99: Indoor heat exchanger anti-freezing protection
Causes: - Insufficient refrigerant;
- Air filter dirty;
- Clogged cross flow fan.
Apr 29, 2015 | Panasonic CS-S9NKUA Ductless Mini Split...
I am not able to get the unit to change from air conditioning to heat
Unfortunately these units are not user fixable , beyond checking for power and checking battery in remote. You would need to call a pro who is able to get service information and has special digital logic meters to diagnose and repair .
Oct 04, 2014 | Mitsubishi MXZ-2B20NA-1 Mr. Slim Dual Zone...
What does a df error code stand for on a con-air heat cool split system wall mount
Friend!,
Please ensure with your model/brand and error code. To my knowledge and web search, I don't find tour model on market. Don't be angry, plz check once again and write back.
Dec 15, 2010 | LG LSC183VMA Split System Air Conditioner
My hitachi ductless split room air conditioner with heat pump is not heating my room , i have cleaned out the filters and unplugged the unit for 10 min and plugged in back in and it only blows cool air , i...
dear sir
thank you
please vote!
Oct 03, 2010 | Hitachi RAS-09UH Air Conditioner
Ductless minisplit in old mobile home
ductless mini split units are a very good choice!  they are obviously quieter, more efficient and easier to maintain than window units. the downside is the initial expense of buying the unit, but this is paid back in eletric savings and peace of mind. Good luck Peyton
Mar 07, 2009 | Soleus KFR12GWD 12,000 BTU Heat & Cool...
Installing a sump heater or cold weather use.
air conditioner can work at 0 deg C outside temp and you do not need a heater for compressor if is split system.
Feb 17, 2009 | LG LB1200ER Air Conditioner
Stand By Mode
Mar 18, 2008 | Sanyo 24KS62R Cool Mini Split Air...
New install. 40 seconds on. 20 seconds off.
Its normal that the air coming out is warm cause you set it to heat mode. Check your setting temperature, it is normal for the unit to shutdown when it will attain the setting temperature and operate when the temperature is lower than the setting temperature(heat mode).
Mar 05, 2008 | GE Quiet-Aire Ductless Split System Air...
20 year old central a/c heater not working
Check your thermostat and mode selector setting, thermostat setting should be set at warmer and mode selector setting should be at low heat or hight this is applicable for manual unit.
If it is a remote control just set the remote to heat mode.
sample only
Jan 02, 2008 | GE Quiet-Aire Ductless Split System Air...
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
