Question about Cub Cadet Garden
My cub cadet rzt s has 10.7 hours use the button to engage blades don/t response
SOURCE: My Cub Cadet 2135 PTO won't engage.
i had the same thing happen
found that the on/off switch had come unplugged from the wire harness just below the switch
had to attach the wires to something underneath so the weight did not pull the wires down and taped the two switches together to prevent it from pulling apart
it needs some kind of clip to hold them together
hope that this works for you
jo
Posted on May 24, 2009
  • 109 Answers
SOURCE: Cub cadet Z Force 48 inch zero turn blades won't engage
I hope this will help you...under the side panels on each side of the mower, there are "reverse lockout safety switches", they are supposed to stop the blades when both handles are pulled back. If one or both of the switches are out, the deck will not engage. Also, under the right side panel (when sitting on seat) there should be 3 relay switches, the one closest to the motor controls the PTO., if this is out, the PTO will not engage.
Posted on Jun 29, 2009
bbreton
  • 437 Answers
SOURCE: cub cadet lt 1018 blade will not engage when i
It sounds like the PTO is not engaging. This is the pulley on the bottom of the crankshaft and the belt for the deck goes around. It may be time to buy a new electric PTO to solve this problem.
Go to www.precisionope.com. and put your information in. you should find a part number you need there.
Posted on Sep 28, 2009
SOURCE: Cub Cadet RZT 50 Deck cable snapped
get a new one ours did the same thing its two boults
Posted on May 25, 2010
SOURCE: My cub cadet zero turn mower won't engage the
I have a cub cadet zero turn z force 48 yesterday i was cutting lawn and i heard a clink, the mower stopped, i was ablet o start the mower again but when i pulled the pto knob to engage the blades the mower turns off by its self, when the pto lever is pulled up i can restart the mower what is causing this and how do i fix it
Posted on Apr 10, 2012
Why aren't the blades engaging all the time?
Faulty connection or partially broken wire, from ignition to blade engage switch or from engage switch to electric clutch.
Aug 07, 2015 | Cub Cadet RZT L50 50" 23HP Zero Turn Mower...
HOW TO RESET THE BLINKING OIL LIGHT ON A CUB CADET RZT
The dashboard for Cub Cadet/MTD mowers includes hour meter, Low oil, or time for oil change, PTO, and other lights. If the oil light is flashing, it means 1 of 2 things. Low Oil Level, or it is time to perform maintenance by changing Oil and Filter. After this process, the light will reset itself after a few more hours of running.
Sep 08, 2014 | Cub Cadet RZT L42 42" 22HP Zero Turn Mower...
Will not move
The transmission is shot. A common problem. Mine died after 3 years and 200 hours of use. Estimate to fix was almost $2000. I scapped it and bought a better mower. There was a rtransmission design defect in the RZT series.
Jun 01, 2010 | Cub Cadet Street Sign- tractor lawn riding...
Cub cadet rzt 50, hit stump, blades wont engage but not bent
The blades on this cub cadet are activated with air pressure. Chances are that when you hit that stump, you either blew a fuse or the control module that allows the blades to spin. Begin by checking the fuses. J.
May 28, 2010 | Mustang Rzt 50" Zero Turn Riding Lawn...
Garden Logo
49 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
DarkfireVA
Level 1 Expert
Matt Olenzek
Matt Olenzek
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
