Question about Garden
Blades will not engage when pushing button model rat s series has 10.7 hours use ????
  • 4 Answers
SOURCE: dies when blades are engaged
Is this on the grass, grass may be too long stopping blades from moving.
Posted on May 18, 2009
  • 226 Answers
SOURCE: Knocking in mower deck or belt clutch when engaging blades, motor bogs / slows down
Posted on Jun 01, 2009
  • 420 Answers
SOURCE: Mower blades willnot engage
make sure the battery is fully charged, check all electrical connections and clean them with vinegar and rinse well with demineralized water afterward.
Posted on May 27, 2010
  • 41 Answers
SOURCE: engine starts fine blade with
there is a burnt fuse or the clutch that drives the deck is toast or possibly the magnet that engages the clutch isnt working
Posted on Aug 26, 2011
  • 6468 Answers
SOURCE: Hi! We have a Craftsman DYS 4500 riding mower,
the clutch might have failed
Posted on May 30, 2012
Things to consider before trying to Start a Chainsaw, Gas powered blower, Weed...
When starting a Chainsaw, Gas Powered blower, Weed eater or Lawn Mower; here are a few things to keep in mind.<br /><br />1. Does it have a priming bulb? If so pump it 3 or 4 times before trying to start.<br />2. Do you have the choke pulled out or pushed down? <br />3. Is the Chain brake engaged? <br />4. Is it turned on.<br />5. Do you have it flooded? If so let it set for a 5-10 minutes and try again.<br />6. Do you have gas in it? Most saws recommend a 50:1 ratio. That equals a 2.6 oz of mixing oil to 1US Gallon of mid grade gasoline. <br />7. On bigger saws there is a decompression button located on the top, make sure it is pushed in. <br />8. While the choke is pushed down/pulled out, crank the engine until it "hits". On some saws, after it hits the choke will automatically go back in, but for the ones that don't manually push it in or up, then crank it again. It should fire. <br />9. On Poulan brand saws the choke is a little bit tricky on getting pulled out. It actually pulls out and up. You should fell it catch. When pulling it out and you think you have it out correctly, let off pressure from pulling it and see if it retracts back into the housing. If so, you didn't have it set right. <br />10. On mowers, do you have the blades engaged before trying to start? Mowers with a PTO button the engages and disengages the blades, pull up on the knob to disengaged. <br /><br />Finally, I know someone may look at this and be saying to their selves, "do you think I don't already know this?" Well, you would be surprised at how many items get taken to the repair shop and the mechanic find out it was one of the simple steps above as to what caused the item not to start. Most mechanics will charge an hours labor fee just for a one minute fix. The labor fee can range from $10-$40/hour depending on the small engine shop.
on Nov 15, 2010 | Garden
I have a John Deere LA145. It has 50 hours on it. I mowed the yard with it and then it wouldn't back up with the blades engaged and the rio button pushed. I turned off the PTO button and backed
With everything you said I never heard you say you checked the oil or put in oil Hope it didn't run tight on you.I'm not sure if your model has one but some also have safety switches under the clutch pedal . If not have you checked the hydrostatic oil im not sure if your is hydro but that could also keep it from shifting in gear and possibly keep it from starting to protect transmission. Just some ideas good luck
Apr 09, 2012 | John Deere 420,1020,2010,2020,2510,2520...
I have a Porter Cable biscuit jointer, model 527 and I'm an amateur woodworker, NOT a mechanic. I can't locate my owner's manual on this tool and have the smaller blade in the tool currently. ...
Model 557 is shipped with a 4" diameter blade installed. This blade is used
for all operations except for the "FF" biscuit. The "FF" biscuit requires that
the 2" blade (furnished with the tool), be installed as follows:
1. Loosen four blade cover retaining screws (A) Fig. 10, and remove blade
2. Depress and hold spindle lock button (B) Fig. 11, while rotating blade by
hand until spindle lock engages.
3. Continue to hold spindle lock button while using the 5/32" hex wrench
(furnished with tool), to remove blade retaining bolt and flange, (by
rotating counterclockwise).
4. Remove blade and store in a safe place for future use.
5. Place 2" diameter blade (furnished with tool), onto blade mounting
flange (orient with teeth facing in same direction as directional arrow
cast in housing, see Fig. 14).
6. Position blade retaining flange (flat side out), to spindle, insert blade bolt
and rotate clockwise until hand-tight.
7. Depress and hold spindle lock button (B) Fig. 11, while rotating blade by
8. Continue to hold spindle lock button while using the hex wrench
(furnished with tool), to tighten blade retaining bolt securely, (by rotating
9. Rotate the "quick set" depth adjusting turret (A) Fig. 12, to the "FF"
10. Lift safety lever (A) Fig. 13, fully retract the plunge mechanism, and
reposition the safety lever as shown in Fig. 14. Slowly release pressure
on plunge mechanism.
11. Reposition blade cover plate to tool, and secure in place with the four
retaining screws (removed in step 1).
Sep 06, 2017 | Masonry Tools
How do you tighten the blade bolt on skilsaw model 5150? Thw shaft just turns and won't tighten.
There is a button on side that lock blade . Push on button turn blade by hand till you feel button engage now you can tighten bolt left hand threads
Jan 26, 2011 | Garden
Describe how you put a blade in FatMax model 10-778
The model in your picture is a fixed blade utility knife (model 10-816). Your question asks for instructions for model 10-778, which is a retractable knife. I'll guide you through the 10-778 which you asked for, if you need instructions for the pictured 10-816 please re-post the question.
Push the thumb slide forward as far as it goes exposing the blade. Press the blade change button on the side of the knife (the small button on the left side near the blade) and pull out the old blade.
Insert the new blade and slide thumb slide back to fully engage blade in the internal lock.
Dec 26, 2010 | Stanley Fatmax Xtreme Retractable Utility...
Craftsman 18hp riding mower runs & stalls when engage the blades
motor off= deck engaed turn blade should turn motor and belt fairly easy, NO remove the belt from the motor pulley with deck engaged blades should turn freely.
most decks have breaks on the pullies so if the deck is not engaged the break will be on
May 27, 2017 | Craftsman Garden
Blades not engaging
Tim, first turn key on engage and disengage blade button. See if you can hear the clutch making a clicking noise. If not check switch., if not your problem is in the clutch.
May 29, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Dies when blades are engaged
May 18, 2009 | Garden
Garden Logo
26 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
