2 or 3 of my channels have a picture but no sound......when I use the remote to change the channel I hear sound for the channel for a split second and then it's gone
    Top Expert:
  • Televison & ... Master
  • 74,844 Answers
Do a reset to this set, and then check. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Posted on Dec 13, 2016
Have 40" Flat screen TV, first time use, have sound, and can switch channels, but the picture only stays on for a split second, Brand new just out of box.
read instruction manual and or call the customer service for the brand you have, last resort call the store where purchased and see if they will help.
Dec 03, 2012 | Televison & Video
How to setup picture in picture function on my tv. panasonic viera 42-px600u
This is controlled by the Split and Swap buttons on the remote; the size of the second picture can be adjusted with the Aspect button. First press split and use the Input button to select the source of the right picture of the split screen (TV channel or video inputs). Then press Swap and use the input button to select the source of the second screen. Swap again if desired or press Aspect to change the size of the main screen window. However, it is not available if you are using the HDMI, PC and SD Card viewing mode. Since the TV doesn't have dual digital tuners, you can't watch two different digital channels on the split screen.
The manual for the Panasonic TH-42PX600U is available from from Panasonic here: http://www2.panasonic.com/consumer-electronics/support/Televisions/Plasma-HDTVs/model.TH-42PX600U . See page 18 of the manual, page 10 of the PDF.
I hope this helps.
Mar 14, 2011 | Televison & Video
Dish network changed to snow when I tried to change station to channel 13. I pressed "power" for 5 seconds with no change.
Hi, Mary with Dish Network Customer Service here. It sounds like when you try to change channels with your remote, it is changing the channels on your TV and not your Satellite Receiver. In the top left corner of the Dish Network remote is an SAT button. When you try to change channels on the Satellite receiver this button should be lighting up. If the TV button lights up, it means the remote is working the TV. Press and release the "SAT" button after you have the picture back on the TV and it should work normally. I hope this resolves your remote issue!
Jan 12, 2011 | Toshiba Televison & Video
Picture splits into two halves
Change the box it will solve the problem.
Jun 02, 2009 | Sony Bravia KDL-37M4000 37 in. LCD HDTV
Lost audio on channels 24 - 28. All others OK.
Try the audio button on the remote. Make sure the SAP is off.
I hope this helps you.
Apr 10, 2009 | Sansui CDVD9000
TV won't work with any remote control
you have to reprogramme the remote, here is the offical site with instuctions and codes for your device:
http://www.universal-remote.net/philipsmagnavox.html
regards and dont forget to rate us!!!!!
Nov 27, 2008 | Philips Magnavox Learning Universal Remote
Remote control
Is this a new condition?
Or has it operated differently in the past?
If you are connected to any kind of box (satellite for example), there is only one channel that the TV sees; usually 3 or 4.
The channel changes are limited to the box.
Aug 22, 2008 | Initial HDTV-322 32 in. LCD Television
Tv/remote input problems
Try plugging your cable box in using a/v cables (red,white,yellow) and see if you have a picture on a different input from the box. If so, go into your general settings in the box and change the output channel to 4 instead of 3. Then try your TV on 4 and see if your picture comes in. I have seen TV tuners go out on just one channel before.
Feb 24, 2008 | JVC AV-27230 27" TV
NetCommand remote control
make it sure you're on the right atenne, if not you can use both...
Oct 13, 2007 | Mitsubishi WD-52525 52" Rear Projection...
Sony FWD-50PX1 no picture
try changing the channel with the original remote or by the tv's physical controls. It sounds like it has switch to an AV channel.
Oct 09, 2007 | Sony FWD-50PX1 50 in. HD-Ready Plasma...
Televison & Video Logo
Top Televison & Video Experts
