I put the wrong disc in the envelope and mailed it today. Just found the correct disk. I can put Serena in the next envelop I get but how do I get my Curious George disk back?
    Top Expert:
  • 4,740 Answers
Who ever you sent it to ring them up and tell them what you have done and they should send it back to you.
Posted on Dec 12, 2016
I don't know how to put an envelope in to print it out.
Please follow the steps below on how to print on an envelope:
  • The print side of the envelope is faceup.
  • The paper guides rest against the edges of the envelopes.
  • You print the envelopes with Landscape orientation. Note: If you are mailing within Japan, then the envelope can be printed in Portrait orientation with the stamp in the lower right corner or in Landscape orientation with the stamp in the lower left corner. If you are mailing internationally, then print in Landscape orientation with the stamp in the upper left corner.
  • You select the correct envelope size. Select the next biggest size if the exact envelope size is not listed, and set the left and right margins so your envelope is correctly positioned.
I hope this information has been helpful. Thanks.
Oct 22, 2011 | Lexmark Interpret S405 Wireless All-in-One...
I cannot find a template using Microsoft Word - Envelopes & labels for Avery label #6873.
Try this:
  • On the tools menu, point to letters and mailings, and then click on mail merge
  • Under select document type, click envelopes the active document becomes the main document
  • Click Next: Starting document.
Aug 06, 2008 | Office Equipment & Supplies
WHERE DO I INSERT AN ENVELOPE ON MY X6170 LEXMARK COMPUTER.
Follow these guidelines when loading envelopes on your model:
  • The print side of the envelopes faces you.
  • The envelopes are loaded vertically against the right side of the paper support.
  • The stamp location is in the upper left corner.
  • The paper guide rests against the left edge of the envelopes.
  • You choose to print the envelope with Landscape orientation.
  • You select the correct envelope size. Select the next biggest size if the exact envelope size is not listed, and set the left and right margins so that your envelope text will be correctly positioned on the envelope.
Aug 10, 2011 | Lexmark X6170 All-In-One InkJet Printer
Envelope jam HP Officejet 8500
Try to print envelope through Microsoft Word
Steps:-
1) Click Tools , click Letters and Mailings and then click Envelopes and Labels .
2) Type the Delivery and Return address information.
3) Click Options .
4) On the Envelope Options tab, set the following options:-
  • Envelope size : set to match the loaded envelopes.
  • US only : if desired, select the Delivery point barcode to make it easier for mail sorting machinery to correctly route the envelope.
  • Return address : for Size 10 envelopes only, set the Return Address position .8 inch in the From left section.
5) Select the Printing Options tab and verify that the following settings are selected:
  • Select the Feed Method option that shows the envelope on the far right side with the short edge first.
  • Select Face down .
  • Examine the selected feed method image and verify that the envelope flap is on the left side of the envelope. If it is on the right, select or deselect Clockwise rotation.
6) Click OK and then click Print .
As envelop can not feed correctly every time, it depends on the weight, flap design, paper type and other factors & cause jam, To prevent those you can do.
  • Print envelopes at a higher quality setting so envelope is pulled through the unit more slowly. e.g:- Switch fast to slow mode or slow to best mode.
  • Tuck the flap inside the envelope before loading it into the printer.
Have a nice day...don't forget to rate the solution.
Feb 20, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
Envelopes trigger ''wrong paper size'' every time in hp 1510
Have you made sure to choose the correct (matching) envelope size in your software?
Dec 01, 2009 | Office Equipment & Supplies
How do I print addresses on #10 envelopes?
    1. Click Tools on the menu bar in Microsoft Word, and then do one of the following:
    2. Word 2000: Click Envelopes and Labels .
    • Word XP: Click Letters and Mailings , and then click Envelopes and Labels .
    1. Type the Delivery and Return address information.
    2. Click Options .
    1. On the Envelope Options tab, set the following options:
    2. Envelope size : set to match the loaded envelopes.
    • S. only: if you want to, select the Delivery point barcode to make it easier for mail sorting machinery to correctly route the envelope.
    • Return address: for Size 10 envelopes only, set the Return Address position to .8 inch in the From left section.
    • Click the Printing Options tab and verify that the following settings are selected:
      • Select the Feed Method option that shows the envelope on the far right side with the short edge first. For example, in the graphic below, the fourth image shows the envelope in the correct position.
      • Examine the selected feed method image and verify that the envelope flap is on the left side of the envelope. If it is to the right, select or clear Clockwise rotation .
      • Click OK , and then click Print .
  • Jul 22, 2009 | HP Officejet 5610 All-In-One InkJet...
    Trouble printing envelopes on kodak esp3 printer
    Have you tried this procedure?
    Loading Envelopes
    You can load plain envelopes into the paper tray of your Kodak ESP 3 All-in-One printer.
    Important Do not use envelopes with cutouts or cellophane windows.
    1 Remove any other paper from the paper tray.
    2 Insert one or more envelopes into the right side of the paper tray with the print side down and
    the envelope flaps on the right, pointing left.
    3 Squeeze the paper-width guide and move it to its right-most position up against the envelopes.
    4 Leave the paper tray open while the envelopes are loaded.
    If you have and it's not printing correctly, there is probably a problem with the document you're trying to print.
    Jan 16, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
    I have a hp 2849 all in one printer. When I print envelopes they print blank.
    When you print an envelope, let the printer print on a regular sheet of paper to see if it's printing in an area not in line with the envelope.
    This example is from Open Office. Microsoft is pretty much the same. What this is showing is the position of the envelop feeder so you know which one to select so that it can print correctly. The software must be set up correctly. The arrows show the path of the paper feed.
    To find this in Office, click on TOOLS, LETTERS AND MAILINGS, ENVELOPES AND LABELS.
    Click on the envelope in the FEED box.
    This window will show the feed position of the envelope using an 8x11 as a point of reference.
    Aug 04, 2008 | Office Equipment & Supplies
    Printing Address on Envelops
    E-mailing you the info I am finding
    Apr 04, 2008 | Xerox Phaser 7300DN Laser Printer
    Help
    Hi, solution for your envelope
    10 envelopes The print side of the envelopes faces up.
    The stamp location is in the upper left corner and printed with landscape orientation.
    NOTE: For Japanese customers: If you are mailing within Japan, the envelope can be printed with portrait orientation with the stamp in the lower right corner or with landscape orientation with the stamp in the lower left corner. If you are mailing internationally, print landscape orientation with the stamp in the upper left corner.
    You select the correct envelope size. Select the next biggest size if the exact envelope size is not listed, and set the left and right margins so that your envelope text will be correctly positioned.
    Oct 25, 2007 | Dell 810 All-In-One InkJet Printer
    k24674
