Question about LG 32LC7DC 32 in. LCD HDTV
Lg 32 inch lcd on light flashing white but fast
As above . was working fine we turned off and now it won't come back on . powered off for 5 mins and still the same
    President:
  • 1,077 Answers
Sounds like it started "Protection Mode" because of a failed electronic part inside the TV. When this happens, the TV will keep turning itself OFF or will not turn ON at all. This keeps the other part inside from being damaged. Most likely the TV has a power supply related problem. It's possible that it maybe a badcapacitor or transformer on the power supply board. The common part to go bad for flat panel screens circuit board that powers the screen. Most manufactures call it a Backlight Inverter Board.
But, I can't say what is 100% the problem because I can't actually look at the tv over the internet. I can only make guesses with the symptom.
You have a few choices:
1. You can again try leaving the TV unplugged for 30 - 45 minutes so the TV can discharge and reset itself.
2. If by chance the TV is still under warranty, go that route.
3. If you have some electronic experience, if you can find and purchase a Service Manual over the internet; It will help you diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, schematics, test points, and part# lists.Usually, cost under $20. And most cases the new part cost less than $15 by searching on the internet with the part number.
4. Pay a TV shop to do the repairs. It maybe costly, but get an estimate of how much they will charge. That way you can decide if it worth repairing or replacing the whole TV.
I hope I shed some light on the subject for you.
Posted on Jul 21, 2009
I have an lg 32 in.lcd and somtimes when u turn it off and wanted to turn it on again it wont come on and the red light start flashing but if u unpluge it for 5 min. and repluge it it comes on
Posted on Aug 20, 2010
4 Suggested Answers
SOURCE: LG LCD TV 32LC4R BLACK SCREEN
same here How do you change the Power regulator?
Posted on Jan 28, 2008
ButtFuzz
  • 463 Answers
SOURCE: LG 37LF65 LCD TV BLINKS 3 GREEN THEN 1 RED THEN TURNS OFF.
Here's a link to the service manual for a slightly larger LG LCD TV. Perhaps it may be of some help? The troubleshooting section appears to be the same for many models of LG TVs...
http://www.observations.biz/MANUALS/LG_LCDTV/42LF66.pdf
Posted on Mar 12, 2009
  • 458 Answers
SOURCE: 37 inch LG LCD won't turn on due to power failure
Power failures can cause all types of problems, have you firstly checked the fuse in the mains plug? If that is ok then it may have blown an internal fuse in the power supply board, these are there to protect the rest of the circuit from power surges.
Posted on Mar 24, 2009
Hi my Samsung plasma tv turns off randomly after 20 min ,1 hour ,5 min and sometimes you can tap tap just above the power input and it comes back on
my tv do the same thing, it's my power cord, check and see if it's
loose where it plugs into the tv, if yes that's ur problem if not don't know
Jan 16, 2013 | Televison & Video
My ac on my vnl670 turns on and off after the outside temp goes above 85F
could be a bad thermostat control or temp sensor.My international car carrier did the same thing.It was called a thermostat control on it.Different manufacturers hav e different names for it.basicly it reads temperatures
Jun 04, 2012 | Volvo Cars & Trucks
My x5 3.0i 2006 t won't start this morning but temperature, gas level clock were wrong so I turn the engine off and restart a couple times it won't start and I saw message trans. false safe...
no. I'd suggest to disconnect a battery for 15 mins, reconnect, wait for 5 mins and try to restart. If it doesn't help (sometimes there's a program block to prevent stealing equipment) call a dealer
Aug 04, 2017 | 2003 BMW 5 Series
This is my 3rd year using intex 8110 sytem. I
That code means the unit is in standby. It should start working if you set the opperational hours that you want in the program. Use the program guide in the manual.
Please Vote !!
Jun 01, 2010 | Intex Automatic Salt Water System for ...
Power turns off
1. pls check buy plugging in some other pen drive or other usb device and check same power off happens after ten mins. If it is so, then the problem is with ur usb drive. Servicing might be needed.
2. If the above device works fine even after 10 mins, then the problem is with ur hard drive controller. You have to reach out to a service station or replace the controller.
3. If you are sure that the problem is not because of the above 2 scenarios, pls reply back
Thanks.
Mar 04, 2010 | Buffalo Technology (HD-HB250U2) 250 GB...
I lose the picture after 20 - 25 mins. I turn off the TV and turn it quickly back on and the picture works fine; then 10 - 15 mins goes by and I lose the picture again. I turn the TV off then quickly back...
it probablt needs power supply capacitors, if you can take it apart and inspect the power supply, the bad capacitors usually are expanded and have a bulge at the top, you would need to solder these parts in, so some skill is required.
Sep 07, 2009 | Polaroid FLM-4201 42 in. LCD Television
Power goes off
Try resetting the unit.
Make sure there is no disc in the unit. With the unit on, go to the front panel and look for the STOP (square) button.
Hold it down until the unit shuts off by itself. Turn it back on it shoudl work fine.
Jul 01, 2009 | Samsung HT-X40 System
Power button failure
  • Power Light Shuts Off
    If the power shuts off during game play (even as much as 30 minutes after the system is turned on), then turns off and won't turn back on or the fan isn't working, the system needs repair.
  • Power Light Flashes
    If the power light flashes once when power button is pressed, then turns off and won't turn back on, the system needs repair
  • Sep 11, 2008 | Nintendo GameCube Console
    Tv shutting off on its own.
    Was talking to one of the experts on the "chat live now" tab and he suspects a power supply problem. Who knows??
    May 02, 2008 | Panasonic PT-60DL54 60" Rear Projection...
    LG 32LC7DC 32 in. LCD HDTV Logo
    1,517 people viewed this question
    Computer Repairing
    Computer Repairing
