Question about Ovens
Hi i cant get my oven to go again after the power went off i tried turning dials it is a older style paprika model
  • 10,263 Answers
Check your power panel to see if the circuit breaker for the oven is supplying power.
Posted on Dec 13, 2016
5 Suggested Answers
  • 6 Answers
SOURCE: Hi my Fisher & Paykel Paprika stove (Model
Yes the regulators/simmerstats are stuffed but are not hard to replace...but please turn off the power 1st when removeing the backing plate as you will kill yourself....yes you will.
Use a multimeter set on volts ac or a volt detector stick, test tester on a known live sourse 1st like a power point....switched on
Posted on Sep 13, 2009
kojak18
  • 31 Answers
SOURCE: My Fisher & Paykel Paprika oven has
check the ignitor and the oven thermost. the oven control board may be out.
Posted on Jun 22, 2010
SOURCE: I have a Fisher and Paykel Paprika oven and have
Hi you need to down load the manual and look on page 5 to reset. http://www.fisherpaykel.co.nz/admin/pdfs/pdf_usecares/599450A_RA_Freestander_ugm_NZw.pdf
Posted on Jan 20, 2011
  • 251 Answers
SOURCE: I have a fisher & paykel paprika and i cant get
Hi - Are you able to provide model number of the oven - or describe the front controls as they have about 6 different types of controls regardless of the brand name 'paprika'
cheers
Posted on Jul 01, 2011
I have a kenmore oven. Just got an F2 error and the oven element will not turn off. Even when powered down, it heats back up when oven is in off position.
Range "Older Style"
F2 Oven too hot Replace relay board (if present) or oven temperature sensor
Range "Newer Style"
F2 Oven temp sensed; over 600F sensed by control in time of day mode, bake mode, or over 900F sensed in clean mode. Ohm test the oven temperature sensor, if OK, change power relay board.
Oct 17, 2012 | Kenmore 40494 / 40495 / 40499 Electric...
cheers
Jul 01, 2011 | Fisher and Paykel Ovens
STOVE WORKS BUT OVEN WILL NOT HEAT UP - GAS OVEN
There are 2 high likelihoods as to what your problem may be. When you turn your oven on, does the ignitor begin to glow within 15 to 30 seconds? If it doesn't, there is no power going to the ignitor and the control mechanism is going to need to be replaced. If you have a manual dial thermostat control, you can order this on-line at parstdirect.com. If you control is electronic, you will be required to have an appliance technician come out in order to send the old controller in to be rebuilt.
If your ignitor is glowing when you turn on your oven, but it has a very dull orange glow, you have a bad ignitor and it needs to be replaced. This is the most common problem with older gas ovens. The ignitors just burn out after time and do not draw the amperage needed to open the safety valve.
Replacing the ignitor is a fairly easy procedure. Replacing a dial thermostat control can be a little rough due to rerouting the thermocoupler back through the oven body. Unfortunately, the electronic style oven controls can only be sent in for rebuilding and the company that you use will need to be able to handle "Retforrepr Rebuilds".
May 01, 2011 | Magic Chef 9122 Gas Single Oven
I have an older jenn air model ww30430 and I cant get the fan to turn off or the upper oven to work. any suggestions
if your unit is switch position is the upper heating element is have convection? you cannot turn off the fan,but if your unit have separate option to choice the other option to oparate separately the upper heating element this one can be use.
Dec 24, 2010 | Jenn-Air 30 in. Pro-Style Electric Single...
Timer starts beeping and flashes F1
Hello there:
if this is the newer style oven then follow the gujide i have provided below and if it is a older style follow the guide i have provided below the first one ok
newer style
F1 Power to element relay energized during time of day display Wiring harness shorted or change power relay board (PRB)
Note: for double ovens, change second oven board
older style
F1 Defective touch pad or membrane Replace touch pad or membrane (this problem is usually the touch pad)
Jul 23, 2010 | Jenn-Air JGW8130A Electric Single Oven
Need to reset my whirlpool 2000+ cooker
Do you have a push button in the centre , between 2 dials and under display? If so, try pushing it twice then turn oven dial
Nov 14, 2009 | Whirlpool RBS275PD Electric Single Oven
Hi my Fisher & Paykel Paprika stove (Model FPRA6102AW) Needs a New Oven element, and 3 of the plates stay on Hot. Are these parts available and how much would they cost please: x1 Oven Element x3 Switch...
Mar 05, 2009 | Fisher Ovens
MAJIC CHEF DOUBLE OVEN NOT WORKING
I just had a model 976-4CX put in...I have no manual...I'm trying to find one. I thought I had a problem with the element, dial or thermostat. The bottom worked, but the top stopped working. There are 2 timers with dials next to the clock labeled Start and Stop, and Push for Manual. Come to find out my problem was solved by adjusting the Start and Stop dials and/or pushing in for manual!?!
If I had a manual I'd know how these timers worked.
Nov 29, 2008 | Magic Chef 9522 Electric Double Oven
Amana gas range bake burner does not heat
Pull the bottom of the oven off. You will see 2 to 4 screws that hold the panel on. The ignitor is under there. Look at the ignitor carefully for breaks. I say carefully as the ignitor is very easy to break.
Feb 03, 2008 | Ovens
Ovens Logo
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
