Have a 1F88-290 White Rodgers thermostat that keeps resetting the heat to 60 degrees. How do I turn off the programming so that I can change the heat setting manually?
  • 38 Answers
SOURCE: trouble code "malf" on my white rodgers thermostat 1F89-211
you need a new thermostat
Posted on May 07, 2009
liteswink
  • 99 Answers
SOURCE: No Heat with new White Rodgers 1f85rf-275 Thermostat
The only way to resolve this problem and to distingush if its a thermostat issue on the system is to by pass the thermostat by putting a jumper between the hotwire and the heating wire if the system did run which happen most of the time. Call the HVAC technician to check your heating unit. Or call the White- Rodgers technical line at 18887259797 choose contrator division.
Posted on Oct 20, 2009
szanti
  • 36 Answers
SOURCE: How do I delete the program settings on my
Go to this web site.
Please let me know if this helped.
http://www.emersonclimate.com/Documents/White-Rodgers/0037-6175.pdf
Posted on Dec 06, 2009
liteswink
  • 99 Answers
SOURCE: My white-rogers 1F81-261 model thermostat keeps
MANUAL OPERATION
• HOLD TEMPERATURE — With the SYSTEM switch set to
HEAT or COOL, momentarily press HOLD button. HOLD
will be displayed. Use UP or DOWN to adjust the temperature.
The thermostat will hold the room temperature at the
selected setting until you press RUN button to return to
program operation.
This is on page 6 of the manual
Link: Installation Instruction
Posted on Apr 07, 2010
liteswink
  • 99 Answers
SOURCE: Keeps going to 62 like it's on a program
You need to manually operate the thermostat by using the hold button. You did not specify the model number but try this procedure:
MANUAL OPERATION
• HOLD TEMPERATURE — With the SYSTEM switch set toHEAT or COOL, momentarily press HOLD button. HOLD will be displayed. Use UP or DOWN to adjust the temperature.The thermostat will hold the room temperature at theselected setting until you press RUN button to return to program operation.
If you need further clarification please cal hometechline 18002842925. I hope this will help you a lot...
My thermostat resets itself
BE absolutely sure the batteries are good. This is what usually causes this symptom, even it the 'battery indicator' isn't asking for a new battery. It happens a lot on systems that are being turned off with the breaker, safety or service switch; DON'T do that. When you put a set of brand new alkaline or lithium batteries, with the thermostat off the wall, leave NO batteries in it for about an hour. Be sure that the power is on 24/7 to the system. To stop the system from running, always use the "Heat--Off--Cool" switch.
Nov 02, 2017 | White Rodgers White-Rodgers 1F85RF-275...
I have a White Rodgers thermostat series 1F78-151 that is displaying we at the top?
Hi. This is Aaron Moratalla from White Rodgers. For 1F78-151, "WE" means Wednesday. If left side temperature is stuck at 67F and there's no Hot air coming out then try ressting your thermostat by:
1. set system to Heat mode
2. press simultaneously the Up, Down arrows and Time button for 2sec.
3. the screen should blank out momentarily then show 62F in the right side.
4. set a higher temperature in the right side than the left side of LCD to have a call for heat.
If you are still having problems please don't hesitate to call our Tech Support line at 800-284-2925. Thank you for choosing White Rodgers!
Jan 24, 2013 | White Rodgers White-Rodgers 1F85RF-275...
How do I program my Whte Rodgers Thermostat to stay at 58 degrees. It keeps resetting itself to 62 degrees. thanks
Download a PDF version of the Operating Manual HERE. ___ *Disclaimer: I am not a lawyer, despite the handle. Words to live by: "Every creative act results from a sudden cessation of stupidity." -Edwin H. Land, inventor of the Polaroid Land Camera "The problem can always be solved with the materials in the room." -My college Physics Lab Professor
Jan 04, 2011 | White Rodgers White-Rodgers 1F85RF-275...
I have a problem with a White rodgers 1C20-101 thermostat. The lower heat setting for room temp goes up to 80 degrees when the thermostat is set at 70 degrees. Is this normal for this type of unit?
The Operating Manuals for many White-Rodgers thermostats can be found in PDF form HERE, however they are not indexed by model number so you will have to download each file in turn until you find the one you want. All of the file names beginning with "0037-" seem to be W-R products.*Disclaimer: I am not a lawyer, despite the handle. Words to live by: "Every creative act results from a sudden cessation of stupidity." -Edwin H. Land, inventor of the Polaroid Land Camera "The problem can always be solved with the materials in the room." -My college Physics Lab Professor
Oct 22, 2010 | White Rodgers White-Rodgers 1F85RF-275...
We have the white and rodgers thermostat model 1F81-261. The problem is that the ac unit will not work. We have reset and changed the batteries and set the point 4 degrees less than the actual room...
Set System Switch to Cool and lower setpoint below room temperature.
Verify thermostat and system wires are securely attached.
Diagonistic: Set System Switch to Cool and lower the setpoint below the room temperature. Within a few seconds the thermostat should make a soft click sound. This sound usually indicates the thermostat is operating properly. If the thermostat does not click, try the reset operation ( . If the thermostat does not click after being reset contact your heating and cooling service person or place of purchase for a replacement. If the thermostat clicks, contact the furnace manufacturer or a service person to verify the heating system is operating correctly.
Reset the thermostat by pressing , UP,DOWN and TIME at the same time.
Jun 28, 2010 | White Rodgers White-Rodgers 1F85RF-275...
The thermostat is a White-Rodgers 1F82-261. We have the very same thermostat on both the upstairs and downstairs systems. Both thermostats have all settings set exactly alike. The upstairs system has...
Steps that you need to do.
First is to reset the unit by pressing the reset button for two seconds right below the fan switch.
Second is to re- program the thermostat correctly, make sure that the unit work fine when the thermostat has been bypass.
Then monitor the thermostat operation, I think this will resolved the problem. If you need further assistance call this number 18002842925.
I have attached the link of the MANUAL
Jun 01, 2010 | White Rodgers White-Rodgers 1F85RF-275...
My white-rogers 1F81-261 model thermostat keeps rgoing back to a 62 degree setting after the furnace kicks on at a setting of 72 degrees. I have reset the program, but that doesen't seem to help. What can...
MANUAL OPERATION
program operation.
Feb 06, 2010 | White Rodgers White-Rodgers 1F85RF-275...
I have the thermostat set for 70 degrees on the white rodgers programmable thermostat. The heat runs until the room is 70 degrees, but then the heat stops and the room cools off and the heater doesn't kick...
Based on your explanation this is an erratic operation of the thermostat, first thing that you need to check is the wiring make sure that all the wires are proper looped on the under terminals then reset the thermostat if the problem still persist I think you need to replace the thermostat. If you need further support call the homeowner techline 18002842925.
Jan 03, 2010 | White Rodgers White-Rodgers 1F85RF-275...
MANUAL OPERATION
Oct 29, 2009 | White Rodgers White-Rodgers 1F85RF-275...
Heating & Cooling Logo
67 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
