Lb white flame is traveling down the gas pipe from the firepot. Is this correct?
L.B White heater. Flame is traveling down the large pipe from the firepot. Is this correct? it has a pilot.
  • paulcarew Dec 13, 2016
    Hi Clark Lupkes, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
  • Heating & Co... Master
  • 14,874 Answers
No it isn't. You need to get it serviced. It will cause parts to get hot that shouldn't.
Posted on Dec 13, 2016
New photocell but no fix.
Troubleshooting a Reddy Heater, HSI type
www.reddyparts.com/hsi_tips.htm
The photocell starts looking for a flame in the chamber; When the atomized fuel ...Water in the fuel - people love to buy parts... but this is a free fix, just drain the tank.... Not so with the new heaters- you adjust to suit the computer, not you.
Troubleshooting a Reddy Heater, spark plug type
reddyparts.com/sp_tips.htm
Troubleshooting tips for Spark Plug type heaters. ... In a perfect operational Spark Plug type heater: ... The photocell starts looking for a flame in the chamber. ... then take the heater to someone else to fix, because you will never make a heater ... on aheater,--- but if the air pump pressure is not correct....the heater will not run!
[PDF]Owner's Manual and Instructions - LB White
www.lbwhite.com/files/5913/1672/2821/125k-210k.pdf
Your new L.B. White heater incorporates the benefits from the most experienced ...Owner's Manuals and replacement labels are available at no charge.
[PDF]Forced Air - yourheater.com
www.yourheater.com/pdf/Forced%20Air%20E.pdf
Jan 03, 2016 | Heating & Cooling
IT TURNS ON THEN SHUTS OFF,DISPLAY FLASHES SERVICE AGS
Per your owner's manual:
AGS
(automatic gas shut-down)
1. Oscillating pump pressure.
1. Clean filter or identify and repair cause of pump oscillation.
2. Low gas supply pressure.
2. Identify and repair incorrect supply pipe size or pipe line blockage.
Refer to qualified service personnel.
3. No flame at burners.
3. No flame at burners. 3. Identify and correct loose wiring connections, or problems with igniter, flame sensor, gas valve, or ignition control.
For more info the manual is here:
http://www.jandy-downloads.com/pdfs/LXandLT_H02140B.pdf
John
May 29, 2011 | Jandy Laars LX Pool Heater / 400,000 BTU /...
On the jandy 400 lt its displaying the AGS code... what does that mean?
AGS
John
May 03, 2011 | Jandy Laars Lt 400,000 Btu Heater
I HAVE A VENLESS HEATER GLO-WARM HEATER THAT THE FLAME IS SHOOTING ABOVE THE BRICKS AND HAS EXCESSIVE GAS FUMES APPEARS TO HAVE A LARGE FLAME WHAT CAN IT BE
can you turn flames down with the control knob ,if not you need control gas valve,that if burning right gas for heater you got. Check the data plate.If not right gas your heater your living very dangerous.
Jan 22, 2011 | Vanguard International Blue Flame - Large...
Bosch SX 250 Lp. I get EA code and will not start. Was very windy last night. Does anyone know how to correct this issue?
EA & EC are telling you that the flame is not covering the flame sensor rod.
Take the front cover off by unscrewing the 2 phillips head screws about 1/2 way down the cover and may be covered by a plastic plate that unsnaps.
Locate the flame inspection glass window near the right side above the control panel. Prepare to observe the flame from start, until the error appears. Visually locate the flame sensor rod: there are 3 rods that pass through the plate below the burner - it is the right most of the 3, angle your head so you can focus on this single rod. Begin water flow by opening a valve or the pressure relief valve that should be outside the cabinet, at the bottom.
Did the flame ignite? it should make several tries before an error.
if it ignited, did the flame cover the flame rod, or did it jump up over it leaving the rod in clear gas below the flames?
In the LCD display, upper right corner, is an indicator in the shape of a flame. It is visably displayed when the flame is covering the flame rod, indicating that the flame is being detected by the electronics. If the flame covered the rod but the indicate is not on, the rod itself may be dirty. Remove it with the other 2 ignitor rods and careful clean the sensor rod with something like steel wool to remove the corrosion. Re-install and test again. If that didn't fix this condition, your control circuit is faulty.
If you find that the flame jumps over the rod and doesn't emerce the rod, check the draft vent pipe for any obstructions, water, bird nest, etc, and any obstruction of the combustion air supply. Check the the gas blower starts up, check for water or white dust in the clear tubing that attaches to the black blower intake from the gas meter.
Otherwise, you will need to follow the procedures to adjust the CO2 and this WILL require a combustion gas analyzer! If you are at an elevation above 2,000 feet, expect to make this adjustment.
Jun 05, 2010 | Bosch AquaStar Indoor Natural Gas Tankless...
On a patio heater why is the flame yelow and noisy
Your gas/air mix is not correct. Not enough air. You should be able to adjust the unit and correct this. Read the manual first to find the adjustment and procedure. When properly set the unit should have a blue flame with a white or very small yellow tip. Thanks for using FixYa and for the generous rating.
hardrocko
May 05, 2010 | Heating & Cooling
GOODMAN GAS FURNACE. IGNITOR GLOWS, GAS FIRES FOR 3-4 SECONDS THEN SHUTS OFF..CYCLES OVER AND OVER. SOMETIMES IT STAYS ON...THEN SHUTS OFF BEFORE TEMPERATURE GETS UP TO THE STAT SETTING...
I suspect that the flame is not traveling to all the burners within a given time so the flame sensor is shuting down the gas valve. Clean out the flame rail where the flame travels and carefully brush off the flame rod with an old tooth brush.
Oct 19, 2009 | Goodman GMS90703BXA Heater
Pilot light goes out when turning on the thermostat
Check your thermocoupling to make sure that it is sensing flame. You can tell if it is good or bad by the white on the tip of the flame sensor. The other problem would be a blocked or closed flue pipe. Make sure that the cap is not smashed down on the pipe on your roof
Feb 13, 2009 | Dayton (3E386) Heater
Blue flame heater pilot wont stay lit
There is a therma-couple that the flame burns against. When it is working correctly it allows gas to travel to the flame. When it goes out you get no gas, as a safety feature. Replace the therma couple and it should work again.
Oct 06, 2008 | Dyna-Glo D-E36 Infra-Red Wall Mounted...
Propane Reddy Heater
AIR MIXTURE ADJUSTMENT IS CRITICAL ON ALL GAS BURNING HEATERS. SOUNDS LIKE YOU HAVE INSUFFICIANT CUMBUSTION AIR WHICH WILL CAUSE A WHITE AND LAZY FLAME .... FLAME SHOULD BE BRIGHT BLUE WITH NO WHITE OR YELLOW TIPS ON THE FLAME.
Apr 06, 2007 | Reddy Heater RLP100 Portable Forced Air...
Heating & Cooling Logo
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
