Question about Refrigerators
WESTPOINT FREEZER & REFRIGERATOR RGK143
Manual
What is wrong with a Westpointe dehumidifier when it stops removing water and displays P1? It will run this way for hours and kick in and work briefly once in a while on continuous.
Usually the P1 error indicates that dehumidifier needs to be defrosted. The unit has detected ice build-up on the condenser coils.
Unplug the dehumidifier for several hours. Then plug it back in. If the problem recurs, check that the fan that blows air across the coils is working properly. Make sure that the room is not colder than the operating range of the dehumidifier. If the problems continues to occur, you may have a refrigerant leak in the system. That will require a service call to repair the dehumidifier.
If the unit is under warranty, contact Westpointe. The manual I have for a Westpointe 65 PT dehumidifier, https://www.appliancefactoryparts.com/content/pdfs/136333-1.pdf, indicates the unit is covered through year 5 after purchase for a refrigerant system. For Warranty service, the contact point is Midea Consumer Service at 1-866-646-4332. If the unit is not under warranty, consider whether to replace the dehumidifier.
I hope this helps.
(I have seen a dehumidifier develop a refrigerant leak. It constantly froze before the leak was repaired and the refrigerant topped off.)
May 15, 2017 | Dehumidifiers
Alarm light Westpoint Chest Freezer
is it getting cold inside .why would you want MAX temp tho turn to mid point as a startingplace
Nov 22, 2015 | Freezers
I have a westpoint tropical WRK1802g.1 the freezer always freezes but the fridge side stops working at times and then water runs out from the buttom of the fridge side
If you also have ice buildup in the freezer your temps are not as low as what they should be and your refrig compartment will be warm.
Jul 19, 2015 | Refrigerators
Hi, there! I have a WESTPOINT no Frost NF 120 and couple of days ago the fridge just stop working. The freezer is ok still working as usual, but the lower part is completly worm. The compressor is working,...
It's the Timer ..a device found on the left of the compressor at the back ..a few wires goes insinde. it has a watch gear mechanism..and a miniscule ant can stop it ..
May 14, 2011 | Refrigerators
WESTPOINT upright freezer...alarm light blinking
Sir,
I need to know how to adjust WESTPOINT UPRIGHT FREEZER WVR-300W temperature? There is alarm light blinking every time and the temperature is not changing from 4c!!!! Thats mean, the freezer
Sep 29, 2010 | Haier HSE12WNA Top Freezer Refrigerator
Refrigerators Logo
32 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
