Question about Blenders
I have a hinari genie model MB280 the rubber beneath the blade has worn down so blades will not turn can you get a new attachment
swami nathan
  • 208 Answers
SOURCE: Older Vitamix Problem
I want you to try this,
1.Remove the blender jar from the blender motor .
2. Check the jar by turning the shaft by hand to see if it rotates easily. .If not, disassemble the blade and ring. Check for obstructions or misalignment. It is better to change the shaft which holds the blade......
If it fails you again, you have to contact with the service center or visit this site
www.vitamix.com/household/service/service.asp
Hope my info helps you,
Thanx for using fixya,
Waiting to help you from your comments.....
Posted on Oct 01, 2008
ThaMp3Doctor
  • 8596 Answers
SOURCE: CA 4203 model #, Smoothie 700 Pro
Here's the parts order form:
http://www.focuselectrics.com/finditem.cfm?itemid=4287
-Tha Mp3 Doctor
Posted on Mar 27, 2009
EwingElect
  • 276 Answers
SOURCE: Kitchen Aid Blender - blade not rotating
You will definitely need to change the clutch blade i.e. the black rubber rotating bit. Chaging it on the base unit may be difficult, I would check with your local Kitcheaid repairer for spare parts and repair advice.
Also check the clutch blade on the jug itself.
Posted on Apr 07, 2009
SOURCE: Rubber coupler on blender sheared off
Yes, it is very easy to fix. You will need a new coupler, which is part number 9704230. There is a set of instructions with video here: http://www.kaparts.co.uk/Howtoremoveablendercoupler/tabid/219/Default.aspx
Posted on Feb 13, 2010
SOURCE: A blade on my immersion blender was bent slightly.
If you have a model with the detachable blades. Otherwise, you'd need to purchase the blending rod from www.wpcookware.com.
Posted on Mar 17, 2010
Why doesn't blade spin?
Either the coupling from the motor with the fingers on it is not really attached to the motor shaft or the drive on the blade that engages with it is not attached to the blade shaft. One other thing is that on some models if the rubber jar seal between the beaker and the blade carrier is in the wrong place it can raise the blade drive to not engaging properly with the motor coupling. The gasket goes between the jar and the blade carrier, not under the blade carrier.
Sep 04, 2015 | KitchenAid KSB3 Classic Work Top Blender
I can manually turn the blades inside the glass pitcher and I can turn the piece on the top of the motor base into which the pitcher blade attachment fits.
One of the parts is not being driven properly. Either the clutch on the top of the motor is not really attached to the motor shaft OR the clutch on the bottom of the blade is not engaging with the motor clutch OR the blade clutch is not properly attached to the blade shaft. On some models if you put the rubber sealing ring in the wrong place between the beaker and the blade housing it is enough to lift the clutches apart. The rubber wing goes between the beaker and the blade housing, not between the blade housing and the blade retaining ring.
Jul 14, 2015 | Blenders
Hinari multi blender mb280 instruktion guide
Request the instruction guide directly from Hinari.
Jan 04, 2015 | Blenders
I have just purchased a hinari genie blender model mb280 can i ask where the on /off swith is please ?
To activate it, you have to have a top / cup screwed on and press down. That activates the switch, and releasing the pressure should turn it off again. Hope that helps. Thanks.!
Jun 11, 2014 | Blenders
Leaks at the bottom of the glass holder
I'm no expert but in my experience if it leaking at the bottom then either the jar /carafe has a few chips or cracks around the hole in the bottom that the blade fits through and in that case you need to replace the jar and your blade assembly may still be good and can be moved to a new jar/carafe. Or the blade assembly has come loose a little and need to be tightened or some the washers (usually the rubber ones) have worn out and need to be replaced. There's plenty of explanation here at amazon and else where on how to replace the assembly blade, move it to a new jar and tighten it down, etc. Hope this helps!
Sep 26, 2013 | Waring Blenders
Blade not turning
Ouch. That doesn't sound good.
Is the blade seating & locking on the spindle? Try turning it with your hand (unplug the blender first!).
Examine the underside of the blade, and the spindle, for cracks.
If you find a problem here, it may be a simple matter of replacing the blade assembly.
If not, try running it dry... no blade, no container. Just short shots of one second. Is the spindle turning? If it turns, then put the container & blade back on... but just put water in the container.
If the blade turns, whipping the water (but doesn't turn if you put something more dense in it), that suggests that your bearings are going out.
In summary:
  • If the spindle turns but the blade doesn't turn, look at your blade assembly. (Plastic can hide a crack.)
  • If the spindle turns "sometimes", but not when subjected to resistance, then it's probably worn bearings.
  • If the spindle doesn't turn at all, then your blender will need to be professionally repaired or replaced.
Mar 03, 2011 | Cuisinart BFP-10 7-Speed Blender
Grease build up around blade and where it attaches to base
Grease can only creep into the blender vase if the oil seal has worn out, or the blenders blade shaft is worn and wobbling. Try cleaning all parts in alcohol to soften the seals. Rebuild kits and replacement blades can be found here (http://www.brevilleusa.com/breville-parts/blending.html)
Mar 09, 2010 | Breville BBL600XL. 5-Speed Blender
Leaking blender
Mine also leaked from day 1. I just read in the manual to first place the bottom and blade assembly on the counter, then seat the gasket around the blade assembly, making sure it is just under the lip of the blade piece (careful, you have to maneuver around the blades). Then place the jar on the assembly and screw in tightly. This worked and I have no more leaks.
This is different than other blenders where you place the gasket on the jar and then attach the bottom. It is a poor design, but after what I paid for it, I am glad to be able to use it and not just trash it.
Jan 27, 2009 | Blenders
I have a K-TEC HP3 blender (2004 model). The jar started leaking bellow the blade. I tried to take out the blade and seal out, could not figure out how to. Any help is appreciated.
Usualy there is a rubber ring araound the bottom of the blade. If it gets worn out or out of posistion it may start to leak. Also if you dont have everything screwed in tight enought it could leak as well
Jan 01, 2009 | K-Tec Champ HP3 Work Top Blender
Blade not turning
the top rubber piece could be worn enough that it is not engaging the pitcher. look at it carefully and see if the "teeth" of the rubber disc on top of the base has not cracked and worn away. a picture of the new one can be seen on the parts websites to compare I spent $10.00 for my replacement but i found them at other sites for $6.00. you will need a very skinny 7mm open ended wrench to get the old one off and it is left handed threads that means clockwise will loosen not tighten the part.i ground down my wrench but an ignition wrench from an auto store will usually be thin enough to reach the flats on the shaft under the rubber disc
Feb 21, 2008 | KitchenAid KSB3 Classic Work Top Blender
Blenders Logo
90 people viewed this question
Top Blenders Experts
eyecam
Are you a Blender Expert? Answer questions, earn points and help others
