I need a remote control for a Ford MUD Slinger Model RF7A
    Top Expert:
  • Televison & ... Master
  • 75,169 Answers
If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. They can either give you a genuine remote control to your device, or can direct you, from where can you purchase a suitable one.
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability. Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the sites.
http://electrohelponline.blogspot.com/
http://remotesearch.blogspot.com/
Universal remote controls are available at most of the electronic spare part selling shops. Visit some on-line sites too, which deals with electronic spare parts.
If you wish to get further advice over phone; visit https://www.6ya.com/
Posted on Dec 13, 2016
I have a 2000 ford f350 what way does the oil slinger dose the tabs face the bearing
Go to ford parts .Com and look at the diagram of it you'll see the part
Dec 30, 2017 | Ford F-350 Cars & Trucks
Have a 90 ford f250, have power in 1st, 2nd and well 3rd gears but in 4th & 5th can't get it to 50mph.
Timing needs to be checked. If your engine has a distruber, check to make sure its tight.
Dec 13, 2013 | 1990 Ford F150
My brother's got his ford f150 standard truck stuck in the mud and now it wont start the battery is fine but when you try to start it all it does is click the first time then if you try again it wont do...
Hi, The only way the mud or water has got into the heads is if the engine or exhaust is stuck below the mud/water. Try to see if the exhaust is clear of mud or water if this is blocked then you will not start. But I think you may just have the starter motor has got mud into it, in which case you need to get vehicle pulled out & bump start it, IE: whilst either pulling or better to push the vehicle & get it to start. Do not turn it off until you have given vehicle a run as this will eliminate any mud around the flywheel which is why the starter will not work. Please leave me feed back: Malcolm Campbell, Thanks.
Nov 04, 2017 | Cars & Trucks
I have a 1966 mustang 3.3l. i just purchased a new engine & i can't get the harmonic balancer to fit right. it's scrubbing against the timing cover when its tightened down. it seems like there...
66 L6 200. Are the timing marks easy to see? I just did this last week on our 66 block. Just bring it to TDC on #1. Remove the pulley/dampner and the timing cover bolts. Remember to remove the front oil pan bolts to the timing cover.
I use an impact wrench on the cam bolt while holding the crank bolt so I don't slip out of TDC. You'll then have to remove the oil slinger. It just slips off the keyway on the crank snout. Carefully pry the cam sprocket to start wiggling it off the cam. Both the cam and crank sprockets are "keyed".
Get the new sprockets and chain aligned with their marks. Slip the crank sprocket on first until the cam sprocket needs mounted. Just remember to hold the crank, cam sprocket, and chain as an assembly when mounting. Once you get the cam sprocket started, start threading the bolt to hold it in place. Tap light a rubber mallet to seat it further on the end of cam.
I would then remove the cam bolt and coat it lightly with thread-loc and then thread it back in. You don't want it backing out later when your driving down the road. ( don't ask how I know). Remember to put the oil slinger back on.
Your Engine has an oil slinger.
Wayne
Jun 28, 2011 | 1966 Ford Mustang
I need to find a 19.2 V battery and remote for my Hummer H2 Mud Slinger. Where do I look?
A 1:14 Mudslinger requires a 6 Volt battery. Not a 19.2 Volt. Now when you go purchase this battery make sure it says 6 Volt not a 6 Cell. Here is the style battery you need. http://www.all-battery.com/6vrccarreceiverbattery.aspx
Starting from the top left you can choose the first 5 depending on the shape of the one you have for the RC and the mAh you want. The term mAh indicaters milliamp hours. Basically how long the battery will last. More bang for your buck basically. But they cost more too. They will all function the same. But the ones with less mAh will run out of juice sooner and have to be charged. All these connect the same way from the same style connector. So don't worry about that. Hope this helps.
Regards, Tony
Mar 24, 2011 | New Bright Bright 114 Scale Mud Slinger -...
Why cant i turn my manual hubs on a 2000 ford f250?
1 of 2 reasons-- If you have been in the mud, either your hubs are packed with mud and dirt, or your springs are broke inside the hub. Either way, you will probably need to take the hub apart. You will need a 1/4" allen head to take the hub out, after you take the tires off and even the brake assembly.
Apr 07, 2010 | 2000 Ford F250 Super Duty Crew Cabs
Exact location of the oil slinger/timing belt guide?
Hello.
I'm unemployed. Can't afford to pay Experts.
I think I figured out the way that the oil slinger must go, anyway. Thanks!
Dec 27, 2009 | 1985 Toyota Corolla 2 Door
Mud Flaps
It is'nt difficult at all theres a couple of bolts at the top of the flaps to hold them in place just take old ones out and put new ones in whith mud flaps on.
Jul 29, 2008 | 2006 Ford Focus
Televison & Video Logo
23 people viewed this question
Top Televison & Video Experts
